xj 400 special master cylinder/other model fitment
Discussion in 'Hangout Lounge' started by XJ4/550, Jul 16, 2019.
  1. XJ4/550
    XJ4/550 New Member
    South Wales, UK.
    Hi peeps, would anyone know if the xj400 special shares the brake/clutch levers with another model?
    Having a hard time trying to find a replacement master cylinder / lever! It's a 1/2 Nissin 6 (4 c) ???
    Just hoping that another model may have used the same MC???
  2. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
  3. FJ111200
    Mods please delete this.
  4. XJ4/550
    XJ4/550 New Member
    South Wales, UK.
    Holy price tag Batman!!!! 209 or 256 Euros!!!!
  5. FJ111200
    Is that the same part? Is it nearly the same bike?
    There's plenty of other ½" master cylinders around.
  6. XJ4/550
    XJ4/550 New Member
    South Wales, UK.
    I have been looking, found a few aftermarket ones on Ebay with American sellers, and looking for different model cylinders, the XV 700/750/1100 are similar but are 5/8"
    The reason i'm looking to change it is because the site glass has been removed and a bolt with rubber/plastic washer has been fitted in its place!
    As there was no fluid in the MC, i'm speculating that this could have been the source of the leak?
    Anyway, for now I have ordered an aftermarket one from china, just to fit and see if there are any other issues with the front brake?
  7. XJ4/550
    XJ4/550 New Member
    South Wales, UK.
    Here is the master cylinder off the xj400 special.
    does anyone recognise it ?
  8. XJ550H
    www.partzilla.com allows you to look up parts and cross reference the numbers. I do not think it lists your bike
    chacal sells the window and related parts but that would be costly
  9. XJ550H
    does not look like a 550 mc they are box shaped no angle on bottom
  10. Polock
    i think chacal has the sightglass and gasket
  11. Toomanybikes
    Tsawwassen bc
    Very similar to 400 maxim I’ll see if I have one
  12. XJ4/550
    XJ4/550 New Member
    South Wales, UK.
    Polock, he has sight glass for the xj550 and the sealant and also refurb kit, I will have to cross reference sizes with him.
    Toomanybikes, that would be great, if it matches at least I will have a better chance of finding one?
  13. Toomanybikes
    Tsawwassen bc
    Just about any single disc brake master will work.
  14. XJ4/550
    XJ4/550 New Member
    South Wales, UK.
    I will look into it, thank you.
    I will also be buying parts to refurb the one I have from Chacal :)
