Xj 550-ish?
Discussion in 'XJ Technical Chat' started by Mipeko95, Aug 9, 2021.
  1. Mipeko95
    Mipeko95 New Member
    Salt Lake City, Utah
    Hi all! Been following this page for a long time and got myself an '81 550 so I think.. the previous owner told me a put a 750 head onto the 550 block and what I want to know is if that's even possible and if so, how would I be able to tell without needing to take the head off (easy task I know, but I'm trying to save most of the heavy work for this winter when I have down time).
    It runs a bit rough when hot and I'm thinking they didn't change coils when or if a larger head was installed which I could assume would be needing more V for spark? She's a franken-XJ that I'm trying to give all the love I possibly can to make her beautiful again without insulting puritans thank you guys and gals and others!
  2. Dan Gardner
    Minneapolis, MN
    John Trevino and Mipeko95 like this.
  3. XJ550H
    he lied to you
    Noahsxj and Mipeko95 like this.
  4. Mipeko95
    Mipeko95 New Member
    Fair enough lol. I'm mechanically inclined enough to take care of most things and have a friend who's some type of Yamaha certified who helps me with more things but he directed me here to get more expert opinions from people who work on these every day. I'm just trying to figure out what exactly it is that I have
  5. Mipeko95
    Mipeko95 New Member
    I found it to be a 550 block and frame. The head is what I'm wondering about is if it is even possible to interchange the two
  6. Noahsxj
    Noahsxj Active Member
    SW Missouri
    Upload a pic of the heads?
  7. Simmy
    it is not possible. The bore centres are tighter on the 550/600 in comparison to the 650/700/750/900 which are all same bore centres
    Mipeko95 likes this.
  8. Dan Gardner
    Minneapolis, MN
    I suppose that with enough JB Weld anything is possible, but it seems unlikely that there are 750 heads on a 550 block.
    I can't really help identify which head it actually is, but I can't wait to find out. The suspense is killing me.
  9. Simmy
    The bore centres are tighter spaced on the 550.
    It’s simply impossible. The previous owner is an idiot.
  10. Dan Gardner
    Minneapolis, MN
    Somebody out there will accept this challenge.
  11. Dan Gardner
    Minneapolis, MN
    Yes, yes they are. 99.9% of the time.
    The only thing that seems to differ is how much of an idiot they were. And that translates into the length of the Period of Atonement, where thou shall atone for the sins of the Previous Owner lest there be much weeping and gnashing of teeth.
    Andrew Nichols and d-moe like this.
  12. Mipeko95
    Mipeko95 New Member
    I will post pictures when I get home and see if anyone can tell by looks maybe?
  13. Mipeko95
    Mipeko95 New Member
    I like a challenge sometimes and these bikes are worth the weeping lol
  14. Mipeko95
    Mipeko95 New Member
    By bore centers, you mean like the crank is longer on 650+?
  15. Noahsxj
    SW Missouri
    Looks to me like a regular xj550 head
    hogfiddles likes this.
  16. Noahsxj
    SW Missouri
    It also looks like a maxim converted to a seca
  17. Mipeko95
    Mipeko95 New Member
    Oh Christmas I gotta rerun the VIN to see
  18. Noahsxj
    SW Missouri
    I should look closer I guess…
    if the vin is 5k5 it’s a maxim, and if it’s 4G0 it’s a seca..
    It’s definitely got maxim forks
    but a seca tank and engine?
    I have a maxim I rebuilt with a seca tank
  19. Noahsxj
    SW Missouri
    The only interchangeable motor heads and sleeves are the xj550, Yamaha radian 600, and fz600.
    There might be more but those are what I know.
    but the 650+ Xj’s are entirely different
  20. Mipeko95
    Mipeko95 New Member
  21. Noahsxj
    SW Missouri
    So you have a maxim with a seca motor, and a stock one at that.
  22. Mipeko95
    Mipeko95 New Member
    Is there anything worth improving from stock? Not necessarily performance wise, but any specific issues or things I should be aware of with a goofy swap like how you say?
  23. Noahsxj
    SW Missouri
    Honestly the more stock the better, they’re identical besides jets in the carbs I believe.. as far as the motor goes
    I’m also not sure what other surprises lie within that build..
  24. chacal
    Camshafts are also different in the Seca motors.....higher lift, probably more duration.
    Noahsxj likes this.
  25. chacal
    Where was it determined that the engine is out of a Seca model? The only way to determine that is to look at the machined pad, on the upper engine case, that has the original bike's ID code and last 6 of its serial number.
  26. Mipeko95
    Mipeko95 New Member
    So I could assume coil size, plug gap, cap resistance, and some other things would be different from maxim to seca?
  27. Mipeko95
    Mipeko95 New Member
    Would that be this?
  28. chacal
    No, that is the cylinder jugs size indication, 550 engines actually displace only 528cc's. You can read more about the various component (and engine) ID at:
    http://www.xj4ever.com/catalog/frame-engine-id.pdf
    All of those items are the same between all XJ550 models.
  29. Mipeko95
    Mipeko95 New Member
    Oh ok awesome thank you very much! I'll get that tomorrow and continue the quest from there :)
  30. Noahsxj
    SW Missouri
    I definitely assumed, but only the secas came with the the factory black painted motor right?
  31. XJ550H
    no like left to right the spacing is wider on the 750 from center of bore to center of bore
  32. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    Doesn't the 550 have a shorter stroke than the 600's?
  33. Simmy
    it does
    550
    528.5 cc
    57mm bore x 51.8mm stroke
    600
    598.5 cc
    58.5mm bore x 55.7mm stroke
