XJ 650 engine quit.
Discussion in 'XJ Technical Chat' started by DriftRacer23, May 26, 2014.
  1. DriftRacer23
    DriftRacer23 New Member
    New York
    Hi,
    Just today I was out driving and my bike quit running while going down the road. The bike is an 82 XJ 650. After the bike quit I was able to get it into a parking lot and tried to start it again, nothing happened. I can't get it to turn over and it wont pop start.
    I'm thinking that my timing chain went and the motor is seized and might be ruined.
  2. hogfiddles
    Don't jump to big conclusions like that.
    First, check your main fuse. Start there.
    What makes you think the engine is seized?
    Next, where in NY are you? If you're near Utica, I'm just south of there.....
    Plus.....Central NY Carb Clinic is coming up June 14..
    Dave Fox
  3. DriftRacer23
    New York
    I'm in Morrisville NY, I believe it was the timing chain because it has been making some noises from that.
  4. DriftRacer23
    New York
    Thanks Hogfiddles,
    Just checked the main fuse and that fixed it, now I just have to get the noise that the engine has been making fixed.
  5. hogfiddles
    I'm just over the hill in North Brookfield. I'm going to send you a message (pm) check your Inbox in a couple minutes.......
    Dave f
  6. hogfiddles
    I just sent you a pm..... Give me a call --I'll be up til Bout 11pm
    Dave
  7. chacal
    A loose cam chain typically makes a buzzing or growling sound rather than a metallic "clang".
  8. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    Here's what happened to me when I was riding my 82 650 Maxim... It just quit running, it turned out to be the kick stand switch, it was "sticky". A shot of WD-40 fixed it. Remember this if it happens again and your fuse isn't blown.
  9. DriftRacer23
    New York
    Ya it makes the buzzing growling noise at around 5-6 thousand rpm, I am hoping it is just an adjustment and I don't need a new chain and guides.
  10. hogfiddles
    I'd be more inclined to think that it's:
    1 a loose heat shield
    2 a loose exhaust collar
    3 a pipe inside has separated
    But ill take a listen and see if I can narrow it down
    Dave
  11. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    Lucky you that can have Dr. Fiddles check your bike. It is an 11 hr. drive from me.
  12. DriftRacer23
    New York
    Ya thankfully he is right down the road from me, he took one look at it and found that my right heat shield was loose. Took him next to no time to diagnose it. If I was by myself I would probably be tearing the engine apart by now to do a full rebuild. :D
  13. hogfiddles
    Hey, glad I could help! Hopefully you can make the Carb Clinic on the 14th!
    Dave
  14. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Lucky you. :D
