xj 650 k wires
Discussion in 'XJ Technical Chat' started by mike shannon, Jun 22, 2018.
  1. mike shannon
    mike shannon Member
    uk
    hello all
    are all xj 650 wires like this or is this the last owners work i have started to sort thing out xj 650 wires 2.jpg
    mike
    the factory does use crimps like that, but those look messy.goes to
    the blue/white wire goes to solinoid(starterswitch) diode block, and starter button
    wiring diagram implies a 3 way split as you have. in main harness
    Dark green runs from front blinker to meter connector to turn selector to rear blinker. may be another split oon it
    brown to many to count
  3. mike shannon
    mike shannon Member
    uk
    hi
    thank you i will solder and sheath wrap them last owner was a big fan of cut and shut then tape over
    mike
  4. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    If you solder them make sure you use a stiff sealed heatshrink to stop corrosion and snapping cores - its more common than you'd think. I honestly prefer the simple crimp, its no wonder the factories all? Do it this way.
  5. XJ550H
    yes common pratcice but I hope that brown wire crimp is not from the factory
  6. Minimutly
    West Wales, uk
    Eh? Why not, it's no different to the others? Is it, or have I just not looked too closely?
  7. chacal
    The multiple brown wires crimped together appears to be the internal "split" that powers the 3 circuits in the fusebox (except the MAIN fuse).....one of the thick brown wires comes from the key switch, and it then "splits" into 3 separate wires for each fuse circuit "input"
  8. XJ550H
    if that is a factory crimp it must have been done on a friday or monday. it is poorly done, excessive wire exposed and some wire strands that did not make the crimp.
    If I found that on a harness I would redo the crimp.
  9. Minimutly
    West Wales, uk
    You'd better start stripping your harness then, sure you'll find more like that.
  10. chacal
    That actually looks like one of the better ones that I've seen on these harnesses.............
