Xj 650 ko model UK bike 1982
Discussion in 'XJ Technical Chat' started by mike shannon, Nov 27, 2019.
  1. mike shannon
    mike shannon Member
    uk
    HI
    can someone tell what this is and better still what is does rebuilding a barn find can't find ant lose push one plug every works electrically carbs of so can't start engine
    Mike
  2. jayrodoh
    jayrodoh YimYam
    Cleveland
    That is the diode pack and is located in the headlight bucket. You can see the connection in the attached picture.
    It has three functions:
    - Allow Oil Light to light up when start button is pressed
    - Provide DC current from generator to latch the headlight relay on once motor starts
    - Allow neutral/side stand/clutch safety circuits to work properly
  3. mike shannon
    mike shannon Member
    uk
    Hi
    Thank you all lights work inc dash lights hi beam works /indicators dash light works / oil light goes out as engine turns over no side stand switch on this xj UK model. Strang thing is no make plug to fit it into
    Mike
    Now you say allows oil light to come on let me recheck and get back say Friday as bike not at my home
  4. kerriskandiesinc
    NY
    Pretty sure the UK XJ came with both side stand and clutch cut outs...??
    1980's......but, I think all mine did, originally, may have been 'surgically removed'....(? hmm...might be one of my old ones, lol !! )
  5. mike shannon
    mike shannon Member
    uk
    Hi this xj 1982 has micro switch at clutch lever no side stand switch only oil level switch in the sump I am baffled to where it plugs in to
    last owner must have had a thing for ref coloured wire has every other wire was red and twisted to make the connection and taped over the joints
    Forgot
    neutral switch works
  6. XJ550H
    there is a connector in the head light bucket it is green square in US bikes it is part of the starter safety relay makes it so bike does not start in gear with out clutch pulled in. if it has not been jumpered bike will only start in neutral
    if you look at photo from Jayrodoh (jay rode Ohio?) you will see this
  7. XJ550H
    27 clutch switch
    28 oil level switch
    29 neutral switch
    30 starter switch
    from UK manual
    for starter safety relay #31 to close and send power to solinoid #29 must be closed or #27 must be closed
    Franz and chacal like this.
  8. mike shannon
    mike shannon Member
    uk
    HI thank you will recheck Monday 2nd
    Mike
