XJ 650 speed, rpm, gearing general questions.
Discussion in 'XJ Technical Chat' started by willierides, Nov 1, 2007.
  1. RickCoMatic
    It OK to run the Bike with the "Tach-in-the-Black" ...
    All day and night.
    24/7/365
    Just stop for gas and check the oil when you do!
  2. wizard
    Could you run a larger diameter wheel, or is that just plain stupid?
  3. Gwyndwr
    Gwyndwr Member
    Vancouver, Canada
    A larger diameter wheel would give you better highway speeds for sure. Of course you're speedo would be inaccurate.
  4. TIMEtoRIDE
    No, your speedo would be fine, as it reads from the front wheel on XJBikes.
    Changing rear tire size on a CAR changes the speedo.
    And I'll buy an overdrive 5 TH gear from you also.
  5. Gwyndwr
    Gwyndwr Member
    Vancouver, Canada
    That was a rookie mistake on my part. But in my defence it was Canada Day yesterday and I overindulged.
  6. Stamplicker
    Stamplicker Member
    London Ontario
    EDIT: Never mind you got it...
    But Yes a higher 5Th would be great. I've done it many times here looking for that extra invisble gear. Can nail all the invisble one's before 5th.. just never a 5-1/4 5 - 1/2 5 -3/4 gears =)
  7. Gwyndwr
    Gwyndwr Member
    Vancouver, Canada
    I'll get on it September the 3rd
  8. bluepotpie
    bluepotpie Member
    Londonderry, NH
    sept 3rd seems random... unless i missed something.
    haha.
  9. TheHound
    TheHound Active Member
    Scotia, NY
    Read his sig he's going to tour europe.
  10. bluepotpie
    bluepotpie Member
    Londonderry, NH
    oh yea! i remember that now. haha.
  11. Gwyndwr
    Gwyndwr Member
    Vancouver, Canada
    The way things are progressing though I may have to change the signature to pushing his XJ650 through Eastern Europe.
  12. bluepotpie
    bluepotpie Member
    Londonderry, NH
    Oh no, I hope it's not that bad.
  13. Gwyndwr
    Gwyndwr Member
    Vancouver, Canada
    No. I'm just running out of time. I degreased the engine last night and I'm having a quilting bee with a couple of friends friday night. We'll disassemble the top end of the engine. Take bore measurements and start lapping valves. I'm hoping it will all go smooth. But if I have to bore 1 size over that adds days to my schedule. The rolling frame is practically back together. Just a little cosmetic work, my viper fairing/cowl just arrived so I'll need to get that painted up. New tail light and signals (LED thus new relays). Plus my ammo cases arrived and I need to fab up mounts for them to be used as saddlebags.
    Actually when I write it down it doesn't seem too bad. All things being equal and I don't open up a hornets nest when I crack open the engine.
  14. bluepotpie
    bluepotpie Member
    Londonderry, NH
    Good luck man! post your results.
  15. Phazer
    Phazer New Member
    Ottawa, Ontario
    Anyone heard back on this thread?
    I'd love a taller 5th, too!
  16. maxim82
    maxim82 Member
    Farmers Branch, Texas
    Not on this topic but I was glad to see he must've returned "home" safely since he posted here on October 3, 2008 http://www.xjbikes.com/Forums/viewtopic ... tml#110188
    Maybe he had too many beer donations on his trip and forgot about this idea. :lol:
    I have no clue if I could afford to buy one if he made one but I'd sure like to know what his calculations/possibilities were on the subject.
  17. RickCoMatic
    I guess you missed the other Thread ...
    "Showing Pictures of My Bike To Europeans!"
    Put me down for 5-Bucks on betting he made it.
    I hope he did.
    I was rooting for him.
  18. nealsxj
    nealsxj Member
    Philadelphia
    lets say he could build one for all of us.... would it be as simple as pulling the tranny and swapping the old 5th out for his modded one?
    i guess what i am asking is, what all does this entail?
  19. wamaxim
    wamaxim Active Member
    Vancouver, USA
    Should just be a swap of the 5th gear drive and driven gears. The only thing that would change would be the number of teeth on the two gears.
    Every thiing else would stay the same.
    I'm going to look at the "other" thread mentiioned above. Hope there is tri story there!
    Loren
  20. wamaxim
    Vancouver, USA
    Hound, You had better opt out of the 5th gear overdrive program. 65 mph in 3rd and you were disappointed......... If you had an overdrive gear how would you be able to keep that surplus change in your back pocket??? 8O
    Or better yet, overdrive the first four gears and underdrive 5th gear. She'd be a dog off the line and just as you got her up to speed the tach would peg as you shifted to 5th
    140 mph is just too fast for school zones!!!
    BTW My other ride has an LCD display next to the digital clock that shows what gear you're in. Doesn't say much for Beemer riders does it? :oops:
    Loren
