Xj 650 turbo 1982
Discussion in 'XJ Technical Chat' started by Rammstein86380, Oct 9, 2023.
  1. Rammstein86380
    Rammstein86380 Member
    France
    Hi
    I have a xj 650 turbo of my Friend to restore.
    I dont know very well this bike.
    Do you have tips to restore this bike ?
    What i need to see ?
    What is problems on this bike ?
    What Can i need to look about the turbo (lubrification?)
    For the story, the bike have 68 000KM. She had a rebuilt engine (except clutch). My friend had a clutch problem and send the bike in another shop to repair the clutch. But low time after, a rod get out the engine.
    An expert look the bike and said it was a problem of oil because parts of new clutch block the strainer (
    disk thickness problem).
    The expert said the shop need to rebuilt the bike to have a funcionnal bike. But the shop put a XJ 650 (not turbo) engine on the bike with manifomd and turbo on the wrong engine).
    The bike never run well and today, the bike have a 4KO engine.
    Tne project of restoration is put a used engine 11T with
    reconditionedreconditionned turbo
    Thanks a lot
    I'am french, my english is not very well. Sorry
  2. Simmy
    Welcome to the forum @Rammstein86380 always fun to focus talk on the Turbos.
    Of the OEM Turbo bikes the Yamaha is the most basic and easiest to work on.
    Much of the running gear is standard XJ stuff, however you really need to study the supplementary manual for the Turbo.
    If you send me a private message with your email I can send you a pdf copy, Canadian actually so it has French and English text.
    After you study the manual you need to go through the bike and make sure all the auxiliary stuff for the turbo is still there.
    The fact it has a standard 650 engine installed raises questions;
    There is oil feed to the turbocharger coming from the crankshaft oil galley.
    Did they drill and tap the cases to accept the oil check valve?
    The oil return from the turbocharger enters the oil pan and a scavenge pump is piggy-backed onto the main oil pump.
    This combo turbo oil pump (and oil pan) could be installed into the standard motor but the chain and sprockets are different.
    To install the turbo oil pump and the proper chain and sprockets requires splitting the cases, did they do this?
    The turbo has special short duration camshafts, did they install these?
    The standard XJ motor has higher compression, this will probably be ok if the knock sensor and ignition advance is functioning.
    Is the knock sensor installed? It is at the front of the cylinder block between cylinders 2/3.
    YICS motors have the boss for this and can be drilled and tapped to accept the knock sensor.
    Non-YICS motors do not have the boss, so it would need to be weld built-up then machined, drilled and tapped.
    Post lots of pictures here and we can help with your assessment.
  3. Rammstein86380
    France
    I will make more photos but i think they put the oil case of XJ turbo on normal engine to have the turbo oil hose (i see one metalic hose under the oil case to the turbo)
    But i think the camshafts are normal camshafts and the normal oil pump
    For the moment, i must restart the engine and took compression. I think i will sold this engine to buy a turbo engine
    Carburetor are very dirty
  4. Rammstein86380
    France
    I want to post photos but i have an error message
  5. Simmy
    you need 5 posts before it will allow you to send pics
  6. Rammstein86380
    France
    Ok thanks 5 post on my topic or 5 post on other topics ?
  7. Dan Gardner
    Minneapolis, MN
    The posts can be anything.
  8. Rammstein86380
    France
  9. Rammstein86380
    France
  10. Rammstein86380
    France
  11. Rammstein86380
    France
  12. Rammstein86380
    France
  13. Rammstein86380
    France
  14. Rammstein86380
    France
  15. Rammstein86380
    France
  16. Rammstein86380
    France
  17. Simmy
    interesting that is a standard motor installed or at least the head.
    In one pic you can see mechanical tach drive not hooked up to anything.
  18. Simmy
    that makes it a non-YICS motor.
    If the knock sensor is not installed then it won't run right.
  19. Simmy
    a peculiar fact with the XJ650's yics and non-yics
    the Turbo is an 82 650YICS but it's valve cover interchanges with the 650 non-YICS
    the 650 YICS motors do not interchange so those turbo air scoops are still there in one pic
  20. Rammstein86380
    France
    Thanks simmy. I think i will put a Real turbo motor.
    Can you send me the manual please ?
  21. Simmy
    ok working on it
  22. Rammstein86380
    France
    Thanks a lot simmy
  23. Rammstein86380
    France
    Hi. Where Can i find the reference on mikuni carburetor assy to be sure it's a Turbo carburetor ?
  24. BallAquatics
    BallAquatics Active Member
    Ohio, USA
  25. chacal
    The simplest way to verify the Turbo carbs is to pull off the float bowl and see whether there is a FLAT GASKET or an O-RING that seals the bowl to the carb body......very few carb sets used this method (although there are a few others). Also, under the choke plunger valve brass SCREW-IN SEAT there will be an o-rings.........I don't think any other non-Turbo carbs featured an o-ring in that position.
  26. Rammstein86380
    France
    Hi
    Do you have a photo of knock sensor please ?
  27. Simmy
    here are schematics below.
    it's a small microphone device that screws into the cylinder block, at the front between 2&3
    Look for 2 wires coming from there which plug into the wiring harness.
  28. Simmy
    I took this pic to show a 900 block can be drilled to accept the knock sensor shown.
    The non-YICS motors do not have this boss so I don't know what they did on your motor
    Franz and chacal like this.
  29. Rammstein86380
    France
    Hi
    Good news, i find a Turbo motor to change.
    And the turbo is in workshop to be repair.
    I will post photos.
    I search 3 parts :
    The metal bracket for fuel pump
    The Switch lead on the master cylinder
    The center cap of handlebar cover
    If you have that.
  30. Rammstein86380
    France
  31. Simmy
    There are 2 different bolt patterns for XJ650's I think you're already aware if I understand your question.
    if the new replacement turbo motor has the intake drillings like the 2nd pic below this is correct.
    If you're going to use non-Turbo intake rubbers you have to make sure you specify for the YICS XJ650, otherwise you can end up receiving the ones to fit the 1st pic.
    I suspect you can make them fit. If you can't find Turbo replacements its probably the best option.
    Note that the Turbo intake rubbers have an O-ring for extra sealing under boost pressure.
    For your case I would smear both sides of the gasket with silicone to help hold the boost.
  32. Rammstein86380
    France
    Thanks simmy.
    I have the second cylinder head.
    I found intake rubber for xj 750 who have the cylinder head with 2 intake rubber right and 2 intake rubber left. I will order that and put silicone.
