XJ 700 petcock fuel leak
Discussion in 'XJ Technical Chat' started by ddanielf, Apr 24, 2022.
Tags:
  1. ddanielf
    ddanielf Member
    Denmark
    Hey all! My Xj 700 was leaking fuel that ended up dripping all the way to the back wheel.
    I've noticed that it was coming from the petcock. It seems like the leakage comes from the part that is connected to the tank (see photos), given the damage it did to my tank.
    Do you guys think I should replace the rubber seal or apply some rtv?
    Thanks!
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    yes replace the rubber seal, you would have to take the tap off anyway
  3. ddanielf
    ddanielf Member
    Denmark
    The seal looks very old, so I'll just replace it.
    But one thing I've noticed when removing the tank, was that the petcock did not hold in the fuel. As if the vacuum system was not working. Big mess.
    Could the vacuum hose be also faulty? or is it because there was air leaking from the seal part?
  4. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    It is not a fault with the vacuum hose. If there was no vacuum you would have no fuel flow. It looks like you need to replace the diaphragm and other parts in the petcock after you take it apart to inspect and clean.
  5. bensalf
    yorkshire ,england
    theres a HOW-TO write-up on here if you do a search, to renovate the petcock, the diaphragm may be ok ,it could just be the valve seat needs refurbishing, but if it needs a diaphragm , theres usually a new petcock to tank seal in the kit anyway
  6. Huntchuks
    East Rochester, NY
  7. ddanielf
    ddanielf Member
    Denmark
  8. ddanielf
    ddanielf Member
    Denmark
    Update: I've replaced the o-ring and the 2 washers. And that seems to have fixed the problem. No more leaking. Didn't need to redo the petcock.
