Xj 750 82 maxim blowing main fuse while igniting
Discussion in 'XJ Technical Chat' started by Laurensvdm, Mar 17, 2022.
  1. Laurensvdm
    Laurensvdm New Member
    Belgium
    Hi Everyone,
    I bought a 82 xj 750 Maxim in pieces as a project. Owner said it was running when he took it apart. I have no experience with working on motorbikes. (only riding them)
    I want to see if the engine starts and runs before i buy new parts for the makeover to caferacer. So i started by putting the engine in the frame and checking out all the electrics. There are some weird wirings but most seems fine. When i connected everything the lights and blinkers would work after i put my keys and put it ON.
    When pressing the RUN symbol i hear the cut off relay clicking and when pressing IGNITE the main fuse burns out. I also hear the starter working for one milisecond.
    The main fuse is a 20A one close to my battery. Not the main fuse from the fuse box.
    I started pulling out things in the circuit to see what gives me a short circuit.
    Currently no lights are connected and the rectifier is also off. So only the basic ignition parts are connected. However i still get the fuse blowing part.
    Bike is in neutral and i grounded the neutral wire.
    No kickstand or clutch switch are connected.
    I think its something obvious for an experienced motorbike technician. However for me..
    I tested the starter relay seperately : measured it out and it clicks also.
    Also i think it works because i hear the starter when pressing IGNITE.
    Battery is ok, bought a new one.
    Today ill try to do tests on all the connected parts seperately to see if one is damaged.
    But if someone could point me in the right direction that would be awesome!
    Ive been thinking on redoing the whole harnass but i think it will give me much more work and costs in the end..
  2. Dan Gardner
    Minneapolis, MN
    Sounds like you just have to work your way through the possible causes of the short circuit - sounds like you have gotten a good start.
    One part that seems strange to me is that you said the rectifier is off. Not sure if that would cause your problem or not, but seems strange. Do you have the TCI unit connected?
  3. XJ550H
    there is only 1 main fuse battery positive runs to solinoid and a second wire from the battery runs to the main fuse.
    then from main fuse to ignition key when you turn on the ignition key it sends power back to the other 3 fuses .
    serch this site for minimum wiring diagram it will show you how to wire ignition system to start bike motor
  4. Laurensvdm
    Belgium
    Okay i think i'm on the right track :)
    I tested my coils again : primary measurements were around 2.5Ohms and secondary around 12.5k Ohms. -> Okay
    I narrowed it down to the following :
    Battery , starter solenoid & starter motor.
    Red from battery to red from starter solenoid. ( in between i place a 20A fuse )
    Then black cable from starter solenoid to starter motor.
    Then from the frame black to the negative side of the battery.
    It all makes good connection. I tested it for resistance.
    When shorting the starter solenoid ( with a piece of metal so current can flow ) , i hear the starter motor for a bit.
    Then directly the fuse blows
    Now what does this means ?? o_Oo_O
  5. Fuller56
    Fuller56 Well-Known Member
    My first thought is the starter motor has a problem, drawing too much current to turn. Next step is to take it out of the motorcycle and test it on the bench. It could have bad bearings or just need to be rebuilt. XJ4EVER has kits to do this, if needed.
  6. Rooster53
    If I understand that correctly you have a 20 amp fuse trying to power the starter, that's not going to happen and it's going to blow. There should be a direct (large wire) between the battery and the starter solenoid
    Here is a link for the Maxim showing the hookup for the positive lead
    https://www.ebay.com/itm/304396462922?hash=item46df716b4a:g:AIkAAOSwlitiLnoh
    chacal likes this.
  7. chacal
    Yep, as Rooster53 says, the starter motor draws a LOT of current, and in the stock electrical systems, is not fuse-protected.
  8. Laurensvdm
    Belgium
    Thanks for the answers !
    I figured it out also yesterday that the startermotor indeed draws alot of current so makes no sense to fuse it! Rookie mistake :)
    Removed the fuse and hooked everything up again..
    Got the engine running for the first time and damn it felt and sounded good !:D
    Learned alot about the electric parts, now time to start assembling it and ordering parts for the caferacer look :cool::cool:
    Thread may be closed.
  9. Dan Gardner
    Minneapolis, MN
    Alright! Good job!
