Xj 750 A Japanese Market ID
Discussion in 'XJ Technical Chat' started by Rsk_141, Apr 25, 2018.
  1. Rsk_141
    Rsk_141 Member
    Scotland
    Hi
    Need some help to Identify a
    XJ750 A seca Japanese market 4k0 with 750 engine
    From a
    XJ650 RJ seca 4k0
    Please.
    Engine No. Frame No. Production No's. Etc, anything,
    So I don't get burned in a purchase.
    Could easily be a 650 with 750 badges on, it got a YICS engine but with out, numbers it hard to tell. I Know the 650 in Europe are 4k0 but any help would be great.
    Tried researching but keep getting the other seca with the teardrop tank, not the RJ seca with the 750 engine in it.
    Many Thanks
    Regards
    G.
  2. chacal
    http://www.xjbikes.com/forums/threads/tech-topic-model-id-and-vins.14577/
    COUNTRY: JAPAN
    MODEL NAME: XJ750A
    STREET NAME: 1981 XJ750
    MODEL ID CODE: 5G8
    FRAME ID: 5G8
    SERIAL NUMBER STARTS AT: 000101
    NOTE: uses the 750cc engine in the XJ650RJ frame, and looks like the North American XJ750 Seca, and comes equipped with an oil cooler.
    MODEL NAME: XJ750E
    MODEL ID CODE: 5G9
    FRAME ID: 5G8
    SERIAL NUMBER STARTS AT: 010101
    NOTE: this model uses the 750cc engine in the XJ650RJ Seca frame and styling.
    COUNTRY: EUROPE
    MODEL NAME: XJ650
    STREET NAME: 1982 XJ650
    MODEL ID CODE: 11N
    FRAME ID: 4K0
    SERIAL NUMBER STARTS AT: 055101
    NOTE: styling and features the same as North American XJ650RJ Seca model, has dual front disc brakes and an oil cooler. UK model.
    MODEL NAME: XJ650
    MODEL ID CODE: 11T
    FRAME ID: 11T
    MODEL NAME: XJ650
    STREET NAME: 1983 XJ650
    MODEL ID CODE: 27F
    FRAME ID: 4K0
    SERIAL NUMBER STARTS AT: 070101
    MODEL NAME: XJ650
    MODEL ID CODE: 27G
    FRAME ID: 4K0
    SERIAL NUMBER STARTS AT: 200101
    MODEL NAME: XJ650
    MODEL ID CODE: 30K
    FRAME ID: 4K0
    SERIAL NUMBER STARTS AT: 300101
    NOTE: styling and features the same as North American XJ650RJ Seca model, has dual front disc brakes and an oil cooler. Sold in Switzerland only.
    COUNTRY: GERMANY
    MODEL NAME: XJ650
    MODEL ID CODE: 11R
    FRAME ID: 4K0
    SERIAL NUMBER STARTS AT: 050101
  3. k-moe
    As a secondary check: The engine displacement is cast into the base of the cylinders, front and center of the engine. This woud help you to make sure that the engine displacement matches what is declared by the short VIN on the engine
  4. Rsk_141
    Rsk_141 Member
    Scotland
    Cheers Guys, think I'll try and buy it,
    Regards
    G.
