XJ-750RJ front fork options
Discussion in 'XJ Technical Chat' started by lupz, Jul 16, 2018.
  1. lupz
    lupz New Member
    I'm thinking of getting rid of the anti-dive forks in favor of something newer.
    What are my options, I was led to believe that most all Yamaha triple trees are the same height so does that mean almost anything can go on?
  2. Jetfixer
    The seca anti dive was cutting edge, Kawasaki, and Suzuki , all used a similar set up . The thing about changing them out is fork diameter, some have fitted yamaha R1 front end anything is possible ,BUT this can effect handling could be better ,could be worse . Changing to a newer bike brake rotors and calipers would need changes or modified good luck .
  3. lupz
    lupz New Member
    Well the real question is I guess does the anti dive actually work. and its it worth my time to rebuild.
    My main concern is they are kinda ugly.
  4. Toomanybikes
    Tsawwassen bc
    You could use an xj750j front fork with same leading axle without anti dive
  5. k-moe
    Yes it does, and yes it is.
    Can you see them while riding?
  6. lupz
    lupz New Member
    Do you know if they are the same length?
    When the front wheel is up in the air I guess I can. :p
