XJ Alternator Rotor Removal Bolt
Discussion in 'XJ Technical Chat' started by Franz, Feb 29, 2020.
  1. Franz
    Silverline PC70 Nut Splitter Set 2-15mm/15-22mm - 2-Piece Set
    £5.42 from Amazon UK. The larger one has a bolt that removes the alternator rotor on XJ engines.
    Andyam5 likes this.
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    hmm, do you mean you can remove the end bolt from the nut splitter, and then use that bolt to screw into the rotor to remove it.?
    :rolleyes:o_O.
    stu
  3. Franz
    Yes a cheap rotor remover. As Trigger said to Del, bensalf here is a picture of it what more proof do you need lol? Rotor Removal.jpg
  4. Andyam5
    Andyam5 Member
    Luton, UK
    Good info, cheers
    Franz likes this.
