XJ HELL!! Fouls Plugs, Can't Ride More Than 5 Minutes Ever!
Discussion in 'XJ Technical Chat' started by Spiderface, Jul 23, 2013.
  1. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Dude, sorry if i offended you. But here's the thing...
    We have all told you what to do multiple times. YOU JUST DIDN'T DO IT. I really hope those jets + valve shims were the problem, + now you can continue with getting a nice finely tuned bike. Trust me... We REALLY do want to see you succeed.
    However, Every year, we get one or two people on here that just won't listen to what we have to say. Then they get pissy and one of three things happen:
    1. they disappear
    2. they realize we were right and apologize
    3. they realize we were right and come back with a new username
    Do what you want to do. THE DIFFERENCE IS THAT WE'RE RIDING OUR BIKES and you spent countless hours accomplishing NOTHING.
    PS. Polock and I are sarcastic as hell.
    PSS. I went through the same thing you did. I "pulled and cleaned" my carbs 8 times, before doing it the way Fitz and Rick told me to do it (including valve shims). Suprise - their way works.
  2. bigfitz52
    You forgot:
    "They sell the bike rather than adjust the valves." (It's happened more than once.)
  3. jmilliken
    Dillsburg, PA
    Doesn't that usually correspond with disappearing from the forum?
  4. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    you could be like me & hang on to your bike for 30+ years......& keep working on it until you get it right......I will admit.....I have neglected my own bike over the years......only to go back to it years later & find that I have to do all the work that is mentioned in these posts...brakes, lines, carbs, tires, valves.....etc.....
    At least, I know who the previous owner was ( me )......& what he did or mostly didn't do.....
  5. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    Or be the third owner of a bike. And know that neither of the two previous owners took care of it.
    Grandpa purchased it in 1981
    Father acquired it from him in 1993
    I acquired it from him in 2007 with only 3257 miles on it.
    It had never had the valve adjusted prior to my ownership (not that the bike had that many miles on it requiring new shims)
    now the bike has over 17k on the odo. And it runs better than I received it.
    Trust these guys. They know what they're talking about. (for the most part) Rick and Fitz really know their XJ's. Their information has helped me out alot in the past. And you can't beat Len's available stock for parts on these machines. This site is THE XJ knowledge base. No other place compares.
  6. fiveofakind
    San Diego, CA
    3257 miles on it.....probably no need to adjust shims......but probably needed a good carb clean thou ......you are fortunate to know the previous owners...ALL IN THE FAMILY
    I know my bike pretty well after having this long.....since I have neglected it...it is time to put the money back in it & the time as well.....repair manuals speak for themselves.... everyone who has one of these bikes should have one & follow it along with forum advice......hands down......
    Problem is is that people buy these bikes on the cheap expecting not to have problems but don't realize the true cost of keeping them running correctly....
  7. Spiderface
    Spiderface New Member
    Wausau Wi
    OK so I'm back actually I did not go anywhere just waiting for parts.
    I know you guys probably assume Im going to disappear but I am not , I hate people that do that.. Thanks for the words of reconciliation, I appreciate it
    Soooo.......
    I got new main fuel jets , pilot fuel jets, and pilot air jets, just cause I found something else this idiot did to the bike..
    He took the 40 pilot fuel drilled it out to like 150 and put it in the main fuel spot gouging the numbers off , then took the main fuel put it in the pilot fuel spot and also gouged through the numbers! When I initially looked at it I thought hey big hole, main jet, small hole, pilot jet, done....WRONG
    Yes, My eyes are damaged from years of grinding and getting nitro methane sprayed in them, long story good excuse..
    Ok so jets are in, my carb bowl is leaking cause of bad gasket, wet set float height, bench synched carbs, 2.5 turns out on pilot screws and.....
    Starts and Idles good but sputters backfires through carb, intake area, during idle and full range, Plugs are bare no soot nothing, Im guessing way to lean?
    My air filter looks lightly dirty...
    After i got the parts installed I only had about 20 Mins to tune it...
    Tonight is the night...unless someone calls the cops on me for noise....
    Looks like my problem from HELL is almost solved...Thanks
  8. RickCoMatic
    FUEL Jets: O Large Main
    FUEL Jets: o Small Pilot
    AIR Jets: O Large Pilot ... (The LARGE Air Jet is Pilot)
    AIR Jets: o Small Main ... (The SMALL Air Jet is Main)
    Preset the Mixture Screws BEYOND 2.5 Turns Out.
    Go the 3 Full Turns Out.
    TWEAK back IN ... 3 "seconds"
    A stopwatch has 60 Seconds for a Full Turn
    15 Seconds would be a Quarter Turn.
    After you get the Pilot Mixture Screws 3 Turns Out.
    Tweak back-in ... 3 ~ 4 SECONDS.
    About the width of a Nickel.
    If it Backfires ... you're too Lean.
    Add a couple of seconds out.
    "Boggs-out" too Rich.
    Once you arrive at where the Mixture needs to be ... the Fine Tuning will only be a matter of within <--- 3 ~ 5 --->.
    A quarter turn will go right beyond it.
  9. adrian1
    adrian1 Active Member
    Well done...welcome back! You make a change from all the vanilla players :)
  10. remo
    remo Member
    Northern New Mexico,usa
    Re: XJ HELL!! Fouls Plugs, Can't Ride More Than 5 Minutes Ev
    Hmm. wow, makes me wonder if I pissed y'all off and that's why I get no response. Or maybe you were just too busy helping the tenderfoot. Just kidding!SpiderI hope that u gain wisdom as a mechanic from this thread before I die on an unsafe bike or something. :lol: Thanks guys for your undying dedication in keeping us on the road. Getting a new battery tomorrow ,so I wont have to waste your time with dumb questions about regulators, I hope. goodnight. :wink:
  11. adrian1
    I think your float levels are still out. Carry out wet set and report back pls.
  12. bigfitz52
    I got $5 (USD, sorry) that says he STILL HASN'T CHECKED THE VALVE CLEARANCES. (I see no mention.)
    Are your valves in spec yet???
  13. Spiderface
    Wausau Wi
    Right after i installed the new jets I double checked and then wet set the floats...
    Re adjusted mixture, tweaked idle screw a bit and bam..
    Fires right up every time, barley need to touch the gas, idles at about 950, on the road mucho balls feels like the front end s gonna lift off in first when you pin it...Its f@#kin great..
    Still gotta shim the valves as they are in fact tight, as you could see in my previous post....
    plugs look faded paper bag brown on ceramic, clean tip though..
    Thank You, Thank You, Thank All Of You....Your persistence paid off for me.
    Is it just me or was this bike built for a asian?
    The damn seat is too far forward!
    Any seat options? That still fit two?
  14. TIMEtoRIDE
    Sculpt a "solo" seat for yourself.
    Get another seat pan off Ebay or make a plywood base.
    Shape foam with a bread knife - $1.00 at the thrift store
    Look for a discarded black sofa and razor the back material off.
    use a $10 staple gun to assemble. You could even use the sofa foam for extra softness, but seat foam is about 2X stiffer.
  15. Reason
    Reason New Member
    Benton, ky
    so??? did you ever get your bike going? im going through this exact same rat race with my 81 650
  16. Hotcakesman
    Hotcakesman Active Member
    South Dakota
    not to beat a dead horse
    but you spent all this money and did all this work, however
    the main thing that needs to be done is still not done?
    all this time.. all this time and the shims are still tight?
    are you aware that Hogfiddles runs a shim pool?
    you figure out which ones you need and send him the ones
    you have.. bingo bango you get them fixed
    Fitz is not kidding.. tight valves burn out and then the engine is
    toast
    you are driving a time bomb
    congrats on the other work, however I think it would have been
    easier to buy a used set of carbs off Ebay
    just my 2 cents
    coming from a guy who followed everyone' advice
  17. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    Valves
    Carbs
    Sync
    Colortune
    Sync
    Colortune
    Ride
    In that order
  18. kodell
    kodell New Member
    Pekin, IL
    I don't know what bike you have but I have a xj700 and I had the same problem come to find out the two air jets at the top of the carb under the top had were reversed. Engine ran fine just fouled plugs emediantly and went though a ton of gas. The bigger air jet is the one closer to the engine that's the pilot air jet the main is actually the smaller of the two and it's farther away from the engine.
    FtUp likes this.
  19. FtUp
    FtUp Well-Known Member
    pacific northwest
    this is exactly what I was thinking when I read the first post.
    CN
  20. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    Dude,
    I am glad you got your bike running, before you burn a valve or worse get your valve shims within specification. You do not need the tool, all you need are some zip ties.
    Like people have mentioned before, stop wasting your time trying to fine tune the carbs. Once you replace valve shims you will have to do it all over again anyways.
    Best wishes.
  21. hogfiddles
    If, after your valves are back in spec, and the carbs have all the correct jets in the correct places, and they have been synced/colortuned.............the problem persists---then I'd say that I'd next start suspecting the TCI.
    Dave Fox
  22. XJ550H
    that would be the pilot jet mixture screw . ontop of the carb ?
    pilot fuel jets reside in the carb bowl area with the main fuel jet.
    air jets are under the diaphram under the carb hats
  23. XJ550H
    bf advice your doomed. lol. then he will get pissed when your right.;)
