XJ mileage
Discussion in 'XJ Technical Chat' started by Colin 85 700, Jul 7, 2018.
  1. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    I have a 1985 XJ 700 maxim, it has 33,000km on it, I regularly rev it to 6000, and never hesitate to bounce it off redline. I see some threads say that these motors will last 3-4x that mileage, I know yamahas are awesome, but will it handle that abuse for that long? I was thinking of rebuilding it with 750 big bore if possible, is it a waste of time? And are parts available regardless? I can't find new Pistons anywhere... Thanks for any feedback!
  2. hogfiddles
    As long as you keep good oil in it, and do your regular valve clearance maintenance, you'll be fine.
    Stumplifter, Franz and Toomanybikes like this.
  3. Toomanybikes
    Tsawwassen bc
    Lots of xj750 motors around to swap. Cheaper than a big bore kit.
  4. Simmy
    XJ700 and 750 are the same bore.
    The 700 is a hybrid of 750 bore and 650 stroke.
    Colin 85 700 likes this.
  5. kerriskandiesinc
    NY
    When I was a despatch rider/courier, back in the UK, 80's,90's,........XJ's......CX500/650, GT550 Kwaks, and the occasional BMW were THE most popular bikes used, the XJ's were (mostly) my weapon of choice, and apart from the dreaded ( but hi mileage) Alternator chain rubber guide breakup/gear dogs interface nightmares, most of my XJ's were running happily well North of 120,000 miles.......one went to 240,000....original driveshaft, rebuilt motor (once), most hit 90,000 without ANY major problems.......and these bikes were ABUSED, time and mileage= money, so running around town, million gear changes per day, or cruising down the motorways and A roads.....at close to 95+MPH, day in, day out, all weathers, certainly tests a bikes reliability!!
    If I had to do it all over again, I'd pick an XJ.....given the choice, over almost ANY other bike of it's genre out there....
  6. Colin 85 700
    Thunder Bay, ON
    Thanks a lot for the info guys! I usually run Castrol GTX 10w40, should I run anything special, I've never had a issue with Castrol, also anyone know the shim diameter? I have some but I know there are different diameters, if I pull it apart I want shims on hand. :)
  7. Colin 85 700
    Thunder Bay, ON
    Also, is it worth swapping a 750? My 700 is Pretty spooky if your not carefull, and it runs mint, should I just leave it?
  8. Toomanybikes
    Tsawwassen bc
    Same diameter shim as bmw “k” bikes and some of the older cars. Any shop that services bmw cars will have them.
  9. Simmy
    My Kawasaki KLR also takes same shim size as the XJ's.
    Back to the question of keeping the 700 mill, if it's working well don't mess with it.
  10. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    If it ain't broke, don't fix it. Unless you'd rather wrench than ride. Summer is pretty short around here...
  11. k-moe
    Oil thread in my signature.
    29mm shims.
    Keep the 700. Yamaha stuck it to the man with that engine. There was a big tariff on engines over 700cc that year, so they built a 700 that made more power than the 750. :)
  12. Simmy
    As k-moe stated the 700 was the Japanese manufacturers solution to beat the US tariff on any imported motorcycle bigger than 700, an effort to help HD. A peculiar aspect to this is that Canada still received real 750's during this time except your XJ700n which continued in Canada another year or 2 beyond it's availability in the US or presence of any US tariffs.
    Call it an XJ700RR. (Ronald Reagan)
  13. Colin 85 700
    Thunder Bay, ON
    I heard the story of the tariffs to help HD in the 80's guess I'll keep her stock, if not just to Ride some history :)
  14. MattiThundrrr
    The Canadian air cooled xjs were 700cc, but the water cooled Genesis 5 valve engine was 750cc. They will not easily swap, and the Genesis definitely makes more power!
    Simmy likes this.
  15. kerriskandiesinc
    NY
    Were the w/c Maxim 750's?? also 5 valve early genesis motors??
  16. ads1987
    ads1987 New Member
    Newmarket, Ontario
    If I recall correctly, Castrol GTX is a standard engine oil, and I don't think it's JASO MA certified. You should be using oil with the JASO certification, otherwise clutch damage might occur.
  17. k-moe
    The Maxim-X was a 700 in the U.S., and a 750 in Canada.
    kerriskandiesinc likes this.
  18. Colin 85 700
    Thunder Bay, ON
    I ordered some Ipone 10.4, semi synthetic, will run that for a bit then I'm gonna change to Ipone Katana full synthetic. my oil goes black quick, probly from clutch slippage (I'm a mechanic I should know better for wet clutches) so I wanna flush with $35 gallon oil before I put in $70 dollar oil. I'm okay to run a synthetic in an old bike right?
  19. Colin 85 700
    Thunder Bay, ON
    And yes the X models were all liquid cooled not air, both using the 5 valve head.
  20. Colin 85 700
    Thunder Bay, ON
    And ummmmm after watching threads on clutches, and knowing I've now abused mine, what brand is the best for new discs! Lol! ;)
  21. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Synthetic oil tends to cause the starter clutch to slip or at least it can. You may be fine. Just putting it out there
  22. k-moe
    The key is to make sure that the oil is JASO MA certified, or compliant.
    See the oil thread link in my signature.
  23. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    I wouldn't use that Apple stuff...
