xj n600 n oil seal fitting (1996 ) uk model
Discussion in 'XJ Technical Chat' started by andy willi, Oct 24, 2021.
  1. andy willi
    andy willi Member
    doncaster UK
    hi can someone advise me is it possible to replace the right hand outer crank oil seal without stripping the engine as mine started leaking and have now removed it but the new one has a lip and wont fit ,
    thanks
    andy
  2. Toomanybikes
    Tsawwassen bc
    No way unless you find a seal without a lip. Or do it correctly and do the starter clutch, chain and guide that are notorious problem while you are in there.
  3. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    you should be able to find a seal without a lip, but you may have to troll around the seal shops to find one , plenty of those shops around the Shefield area.
    how did you get the old one out if it has a lip, did you destroy it?. as you will need the measurements embossed on the seal to get a new one , then cement it in.
    not aware of any starter clutch issues with a 1996 (diversion) model
  4. Franz
  5. bensalf
    yorkshire ,england
  6. andy willi
    andy willi Member
    doncaster UK
