For Sale XJ PARTS FOR SALE---FOR ALL MAXIM, SECA, AND TURBO MODELS
Discussion in 'For Sale, Trade/Swap, Wanted' started by chacal, Nov 10, 2006.
  1. fjpish
    fjpish New Member
    New Jersey
    Re: XJ PARTS FOR SALE---FOR ALL MAXIM, SECA, AND TURBO MODEL
    Thanks, Len.
    My order arrived promptly and as expected. I appreciate your advice and personal service. I'll let you know how it goes with the carb t-fitting.
  2. AMCWood
    AMCWood Member
    Black Mountain, NC
    Just got my order consisting of dyna coils plug wires and spark plugs. Chacal replies wickedly fast and professionally. Answered all my questions. I wish more people did business like Chacal. Thanks again. My bike now dosent sound like a twin and actually accelerates.
  3. chacal
    Hey guys, thanks for the feedback and I'm always glad to help out!
  4. bill
    bill Active Member
    Raleigh, NC
    Hi Len I lost count 4 or 5 orders at least and always great service. Ordered my stuff Thursday afternoon, received them at lunch time today and installed them this afternoon.
    Thanks again, I'm sure there will be more orders coming....
  5. chacal
    Hey Bill, wow, you're quicker at installing those parts than I am at shipping them!
    I better go kick some butt back in the shipping department! :D
    Thanks again for your business and feedback!
  6. CaptNemo
    CaptNemo Member
    Reno
    Len,
    The Eagle has landed! Again.
    Next order list is almost ready.
    Have you ever heard the Johnny Cash song "I built it one piece at a time"
    Any way the carb tune looks like a great piece of equipment, can't wait to use it instead of doing it the cave man way.
  7. chacal
    Captain......you are funny guy. You mean like one of those Geico cavemen, or just a run-of-the-mill, garden-variety caveman? :lol:
    Thanks, let me know what's next.
  8. CaptNemo
    CaptNemo Member
    Reno
    That would be the "Shade Tree" variety...one vacuum guage and some tape.
  9. Hack
    Hack Member
    Ontario, Canada
    The manual arrived in perfect condition. Thanks, Chacal!
  10. somecallmemike
    somecallmemike Member
    Eau Claire WI
    Hey Chacal,
    How much for a new set of float needles for my 82 seca xj650?
  11. Grynen
    Grynen Member
    Holland Landing
    Got my intake boot and yics tool. fast and easy Thanks Chacal.
  12. chacal
    Hey Mike, I sent you a PM with that info, but here it is again:
    CARB FLOATS & FLOAT NEEDLE VALVES:
    NOTE on float needle valve Seats and Needles:
    - original seats had a fuel inlet boss (where the inlet filter screen sits) of either 5.10mm (and uses a flat screen) or a 6.57mm boss with a 7.30mm "lip" (this style uses a domed screen).
    - The HCP1 kit comes without a screen but the float seat has a 5.10mm screen mounting boss, so an original FLAT screen can be used with these if you still have your original flat screens. The needle is slightly longer (about 1mm) than on the HCP10 needle. The needle seat Washer is made of a stiff fiber material, as opposed to the original metal washer.
    - The HCP10 kit comes with a flat screen and the float seat has a 5.10mm screen mounting boss. The needle is slightly shorter than on the HCP1 needle. The needle seat Washer is made of copper as original.
    - The HCP872 and HCP2776 kits comes with a screen and the float seat has a 4.53mm screen mounting boss. The needle is slightly longer (about 1mm) than on the HCP10 needle. The needle seat Washer is made of metal like original, but it's aluminum rather than copper.
    - There is a third style of seat and it uses a "domed" style screen. The mounting boss for the screen on the seat is 7.25mm OD and it is "stepped". This style seat and screen are not currently available.
    - The HCP870 Needle Only uses a needle that is slightly taller (about 1mm) than stock. It is the same needle as used in the HCP872 complete kit.
    QUESTION: does it matter which style float seat/needle/etc. is used in your carbs?
    ANSWER: Not really, although it's probably best (but not absolutely necessary) to make sure that all 4 carbs use the same style set-up. Also, while it states that the kits that have the same height needles "may not" require float level re-adjustment after installation, I wouldn't count on it. You should ALWAYS check and adjust your float levels anytime you go into your carbs----and periodically even if you don't! I know, it's a pain-in-the-tail light to adjust the float levels----but correct float levels really will help make sure that your bike performs at its best.
    fs17) OEM Hitachi FLOAT NEEDLE VALVE ASSEMBLY---contains the float valve Needle with retainer clip, float valve needle brass screw-in Seat, and the metal seat Washer. The seat DOES include the filter screen, but this kit does NOT include the idle mixture screw block-off cap. NOTE: the float Needle that comes with this set is approximately the same height as the factory Yamaha needle, and it may not be necessary to re-adjust the float level height after installation.
    For all XJ650 (except Turbo), all XJ750, and all XJ700 (except "X") models:
    HCP10 OEM Hitachi Float Needle VALVE ASSMEBLY, single:
    $ 64.00
    HCP10SET4 OEM Hitachi Float Needle VALVE ASSMEBLIES, set of 4:
    $ 239.00
    fs3) Aftermarket Hitachi FLOAT VALVE NEEDLE ONLY (includes the retainer clip)...for those who wish to do an extreme-budget rebuild, you can buy the rubber-tipped float valve needle by itself (without its brass seat). Needle includes its hanger/retainer arm clip. NOTE: this Needle is approximately 1mm taller than a factory Yamaha needle, and will require that you re-adjust the float level height after installation. For use on all XJ650 (except Turbo) models, all XJ700 non-X models, and all XJ750 models.
    HCP870 Aftermarket Hitachi float valve NEEDLE with clip, each:
    $ 7.50
    HCP870SET4 Aftermarket Hitachi float valve NEEDLES with clip, set of 4:
    $ 28.00
    jj) Aftermarket Hitachi FLOAT NEEDLE VALVE ASSEMBLY---contains the float valve Needle with retainer clip, float valve needle brass screw-in Seat, and the metal seat Washer. The seat DOES include the filter screen, but this kit does NOT include the idle mixture screw block-off cap. NOTE: the float Needle that comes with this set is approximately 1mm taller than a factory Yamaha needle, and will require that you re-adjust the float level height after installation.
    HCP872 Aftermarket Hitachi FLOAT NEEDLE VALVE ASSEMBLY, single:
    $ 11.00
    HCP872SET4 Aftermarket Hitachi FLOAT NEEDLE VALVE ASSEMBLIES, set of 4:
    $ 39.00
    nn) Aftermarket Hitachi carbs LOWER END STANDARD REBUILD KIT---contains the float needle with retainer clip, float valve brass screw-in seat, a fiber seat washer, idle mixture screw block-off cap, and an aftermarket bowl gasket. The float needle seat does NOT include the filter screen. NOTE: the float Needle that comes with this set is approximately the same height as a factory Yamaha needle, and it may not be necessary to re-adjust the float level height after installation.
    For all XJ650 (except Turbo), all XJ750, and all XJ700 non-X models:
    HCP1 Aftermarket Hitachi carb LOWER END STANDARD REBUILD KIT, single:
    $ 19.00
    HCP1SET4 Aftermarket Hitachi carb LOWER END STANDARD REBUILD KITS, set of 4:
    $ 69.00
    fs2) Aftermarket Hitachi carb LOWER END DELUXE REBUILD KIT---contains the float needle with retainer clip, float valve brass screw-in seat, a metal seat washer, and a factory bowl gasket. The float needle seat DOES include the filter screen. NOTE: the float Needle that comes with this set is approximately 1mm taller than the factory Yamaha needle, and will require that you re-adjust the float level height after installation.
    HCP2776 Aftermarket Hitachi carb LOWER END DELUXE REBUILD KIT, single:
    $ 24.00
    HCP2776SET4 Aftermarket Hitachi carb LOWER END DELUXE REBUILD KITS, set of 4:
    $ 88.00
  13. martinfan30
    martinfan30 Member
    Carson City, Nevada
    Thanks Chacal! Got all my parts early this week and can't wait to start replacing and rebuilding!
    :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
  14. chacal
    Thanks guys!
  15. BrianC
    BrianC New Member
    Niagara Falls, Canada
    looking for a seat grab bar for my 82 650 maxim, also interested in a rear rack i could mount a trunk if u have one
  16. chacal
    Hey BrianC----sent you a PM. Sorry, no help on the rear luggage rack.
  17. yamaha4life
    yamaha4life Member
    OH---IO
    got my parts Monday 8) i will now call you jesus...chacal "jesus of the XJ" i bow down to thee and praise his xj part having ability.... :lol: but really it was and will be great to buy from you again
  18. chacal
    Hey thanks 4life..........but truly, my son, you should give praise to the Part Gods whom Art, unfortunately, mostly in Japan and China.
    But I am a mere Moses, leading you out of parts desolation and servitude, and into the Promised Land of quick shipping and items that are actually correct and function properly for an XJ bike (rather than a generic one-size-fits-all item).
    Amen. :D
  19. ricklees
    ricklees Member
    St. Louis, Missouri
    Whoa, ordered Sunday evening shipped Monday, in hand Tuesday!
    10 minutes later parts were on the bike.
    True to form chacal is top notch.
    Thanks,
    Rick
  20. chacal
    Darn Rick, you're quicker than me!
    Guess I'll have to start working quicker...........
    Thanks!
  21. xjasfirst
    xjasfirst Member
    I ordered a turn signal from chacal, and it was shipped the same day! I got it in 6 days using parcel post and took the bike out with it that night. This was my first order from chacal and the experience lived up to the hype!
  22. chacal
    Thanks1
  23. avengingllama
    avengingllama Member
    Columbus, Ohio
    I don't get it. I ordered my oil filter bolt on Thursday night but it didn't get here until Monday!!! Good grief, 2 WHOLE business days, couldn't teleport it to me or something could ya. LOL, just kidding Chacal, I did get the part Monday in much better packaging than I expected for a piece of metal ( i did have to hide those little peanuts from my daughter though, 13 and still loves those dumb things)=) thanks again for the fair pricing and superior service
  24. chacal
    Llama, we tried, but our molecular transporter was broken, and our supplier takes FOREVER to ship us replacement parts for it......
    Thanks, and let me know if we can have a shot at doing better next time!
  25. dqnjuan
    dqnjuan Member
    bmore, md
    Once again great service and fast delivery Chacal, parts just came in and you had them shipped same day as order...think this is my 3rd or 4th week in a row and ive always got them by thurs for my weekend wrenching.
  26. Fongdingo
    Fongdingo Member
    Charlottesville VA
    hey chacal you sell breake front pads for my bike?
  27. chacal
    Thanks dqnjuan, happy wrenching!
  28. maxim82
    maxim82 Member
    Farmers Branch, Texas
    I'm PUMPED! I ordered various parts from Chacal for my bike on Tuesday afternoon and there they were in my mailbox Thursday. Great timing, just in time for weekend wrenching! Now I can get rid of the half-arse nuts, bolts, in-line fuel filter I put on the bike from my local hardware store to get me by. All the parts look right and so much "purdier" than what I had.
    Dude I'm not even going to tell you how much my local Yamaha dealer wanted for the carb drain bowl screws. Suffice it to say it went something like this, Me: "For the set of 4?"; Him: "No, each screw." And of course it would be 2-3 days before the dealer got them and I got to fight Dallas traffic 30 miles (round-trip) to go pick them up. No thanks.
    Now I can say, "I got a guy...."
    '82 XJ650J Maxim
    Happy! :D
  29. chacal
    Hey '82, great to hear, hope you got lots of wrenching done this weekend.
    Yeah, let the postman fight the traffic for you, that's a much better idea than you doing it!
    Thanks gain for your business, let me know if I can be of further assistance.
  30. skoobasteve
    skoobasteve New Member
    Philly
    wondering if you have complete carbs for an 81 xj650?
  31. chacal
    Hey Skooba.....unfortunately, no. I have lots of rebuild parts, and occassional major component (used) pieces, but no compelte sets.
    For those, the forum FOR SALE lists or eBay are your best friends.....
  32. A_Dawg
    A_Dawg New Member
    Utah
    Hey Chacal,
    Got my parts today (carb rebuild kits). You have one more satisfied customer here! Great job on getting my stuff out to me so fast. I'm certain that I will be ordering more in the future, I have just begun to tear into this beast.
    Keep up the good work bud!
  33. chacal
    Hey Dawg, thanks! Let me know how I can be of assistance in the future.
  34. MrParadox
    MrParadox New Member
    Lodi, WI
    Hey Chacal,
    I got my stuff today! I wasn't even expecting it until tomorrow at the soonest. Boy did that make my day!
    Got the new pilot jets in, and the brake switch is the perfect length!
    It's truly a blessing to have someone with parts for these vintage bikes and sell them at a very reasonable price!
    I'll definitely buy again. :) Thanks!
  35. chacal
    Thanks Paradox!
  36. johno8
    johno8 Member
    Dartmouth, Nova Scotia, Canada
    Chacal:
    As our riding season up here is drawing to a close, I'm loking at my winter projects and need to know the availability/cost of these parts:
    Ignition coils and wires
    Clutch
    Starter brushes
    thanks again!
  37. chacal
    Hey Phil, good to hear back from you!
    And, you have mail in your PM box!
  38. supero1
    supero1 New Member
    Smyrna, Georgia
    Hi, I'm looking to order the following items for the 1983 Yamaha Seca xj900 and are all the items in stock?
    HCP895 - SET OF 4 O-RING $ 3.00
    HCP896 - SET OF 4 O-RING WASHERS $5.00
    HCP563 - SET OF 4 AIR BOX TO CARB RUBBER BOOTS $52.00
    HCP1284PL - SPIN ON OIL FILTER $54.95
    HCP1601 - 6" +POS BATTERY CABLE $7.50
    HCP7376 - SET OF 4 RUBBER PLUGS FOR MIXTURE SCREW $14.95
    HCP6279 - SET OF 4 BOWL DRAIN SCREWS $24.00
    HCP2827RU 29.95
    HCP2828RU 29.95
    HCP2829RU 29.95
    HCP7591RU 21.95
    HCP7592RU 21.95
    HCP2856RU 49.95
    HCP4231 SET OF 12 9.00
    HCP2832 1.50
    HCP2965 53.00
    HCP3522 9.95
    HCP3503 NEED 2 2 X 8.95
    _______
    TOTAL : ????
    Robert
    supero1
  39. chacal
    Hey Super, I sent you a PM!
  40. squarejer
    squarejer New Member
    I just received my order from Chacal (Len). It arrived two days after I placed my order. That was fast!
    All the parts arrived as I had expected, and I found the instructions that came with the brake lines I ordered were very helpful. They are narrative instructions with helpful tips included, not just poorly written steps that leave out most of the really important information.
    Ordering from Len provided a lot of value to me. I knew the parts would work with my XJ700S because he specifically stated so. I ordered stainless steel brake lines, something that would have required more shopping and research work on my part to ensure I had the right parts that would fit if I had tried to order them from a parts warehouse.
    I'm hoping my brake line replacement job this weekend goes as smoothly as getting this order!
  41. chacal
    Thanks Squarejer, glad to be of help, let me know what else I can do for you, good luck with those brakes, let us know how it goes.
  42. windlover
    windlover Member
    Vancouver USA
    Hey Chacal,
    Just want to let everyone know how great your service is. Quick and prompt ordering and shipping. Keep up the great work. I will definitely any and all parts I can through you.
    Thanks again,
    Windlover
  43. cturek
    cturek Member
    O'Fallon, MO
    Chacal:
    Just like my last order, this week, my parts arrived within days of my order. Just wanted to say thanks for the great service.
  44. chacal
    Thanks wind & cturek, always gld to help, and I appreciate your business!!
  45. mfchapman
    mfchapman Member
    Bodymore, Murdaland
    What I like most about buying parts from Chacal (other than the fact that he has damn near all the parts you might need for XJ's at fair prices and will ship them to you in no time flat) is that he knows these bikes really well and can answer useful questions about their installation, something you will NOT find elsewhere.
    Great stuff.
  46. jtalafous
    jtalafous Member
    Austin, TX
    Hey Chacal,
    Thanks for the great advice and quick delivery on all parts I've ordered so far. Could not have done it with out you, man.
    A loyal customer,
    Joe from Austin
  47. chacal
    Thanks guys! It's a pleasure to be able to help, and I appreciate your business!!
  48. CaptNemo
    CaptNemo Member
    Reno
    Chacal,
    Parts are in, thanks again!
  49. chacal
    Great Capt! Now off you go to wrench your problems away! Good luck, thanks again.
  50. SecaMaverick
    SecaMaverick Active Member
    Northeast Ohio
    Absolutely pleased! The parts I ordered were in my mailbox yesterday, and are top notch. The YICS tool looks great, too. Can't wait to use this stuff. Thanks Chacal!
