For Sale XJ PARTS FOR SALE---FOR ALL MAXIM, SECA, AND TURBO MODELS
Discussion in 'For Sale, Trade/Swap, Wanted' started by chacal, Nov 10, 2006.
  1. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    Re: XJ PARTS FOR SALE---FOR ALL MAXIM, SECA, AND TURBO MODEL
    Name one parts dealer that is available Sunday evenings when your hands are dirty and you think you might have a problem......I'll name the only one I have ever heard of.... Chacal!!!
    Order from Chacal he'll have the part you need and the knowledge of how to install it. Plus he will have it at your door quicker than anyone.
    Len, thanks for the help this evening
    Rob
  2. chacal
    De Nada.........
  3. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    That's what you think :wink:
  4. chacal
    Thinking.....a bad habit I gave up a long time ago.
    There's a 12-step process involved.............. :D
  5. TheBikeDoc
    TheBikeDoc New Member
    XJ4ever.com spin on oil filter adapter review.
    I had the opportunity to install two www.XJ4ever.com spin on oil filter adapters to my two 1982 XJ750RJ Secas. Len Chacal provided prompt service with the ordered kit arriving in about 5 days. Len’s enclosed instructions are very detailed and quite helpful. Do read them first and make sure you have all the required tools. Torque wrench I had, 30mm socket I needed so I held off on doing the switch until I got a 30mm socket. I will get into more details regarding the 30mm socket below when I came to that step in the instructions. Below is a composite of my installation experience on the two Secas, the first being the “learning curve”, the second being, “that went well.”
    I went through the instructions before starting and got all the recommended supplies. With the installation of the stud, I did the thread locking fluid for the first 4-5 threads on the engine side of the engine case stud then anti-seize half-way up the engine side of the stud. The stud threaded in easily by hand about 1/4 of the way. I then inserted the installation tool pins into the U side of the stud and attempted to torque to the specifications of 20 foot-pounds. Before I ever reached recommended 20 foot-pounds of torque, the stud start to turn with extreme difficultly. I decided not to force it and attempted to remove the engine case stud. The U cuts could not take the torque with my attempting to remove the stud and bent making it impossible to remove the stud with the tool. I had to use a channel lock to remove the stud. The stud was thoroughly trashed. Fortunately, the threads in the oil passage did not strip and were undamaged. As I had ordered two kits one for each of my 750 Secas, I got the engine stud from the other kit. With the second stud, I first sounded the depth of the oil passage then applied the thread-locking fluid to new stud again to the first 4-5 threads to the engine side of the stud and then applied the anti-seize to level of the sounding of the threaded oil passage and no further to avoid over driving the stud too far into the engine. I then reinserted the stud into the oil passage hand tightening; I then torqued it down using the Yamaha recommend torque specs for the oil filter bolt (11 foot-pounds) which the engine stud replaced. When I did the second Seca, I used my micrometer and measure a total depth to the oil passage hole, 37mm, but found only a threaded depth of 23mm. I subsequently measured 22mm up on the replacement stud Len sent me (no additional charge, thank you Len!) and applied masking tape as a visual check not to over drive the stud into the engine oil passage. I applied the thread-locking fluid to the first 4-5 threads to the engine side of the stud and then applied the anti-seize to remaining 22mm of exposed threads. I then inserted the stud into the oil passage hand tightening, then torqued it down using the Yamaha recommend torque specs for the oil filter bolt (11 foot-pounds) which the engine stud replaced. The masking tape was removed and anti-seize was applied to the remaining threads. The oil adapter plate and 30mm nut were applied as per steps H), I) & J) written instructions.
    At step J, on both Secas there was great difficulty in getting the socket to seat over the 30mm nut due to the narrowness of the recessed portion of the adapter plate that the nut seats into. The original 30mm socket I procured at AutoZone Auto Parts was “Great Neck” brand and though the socket fit the 30mm adaptor plate nut, the walls outside diameter were too thick (42mm) to fit into the recessed portion of the adaptor plate (39.5mm). I got an S-K 30mm deep socket (www.sears.com part # 00996787000). This has an OD diameter of 39.4mm, giving a close fit. The short comings are the thin 30mm nut edges are machined down slightly giving a taper to the edge to the nut and the similar machined down inside lip of the S-K 30mm deep socket. It is a two person job one to secure the adaptor plate nut: one applying direct downward pressure on the socket wrench over the nut to keep it from slipping off and the other applying the torque to the wrench (my son was quite helpful here). If a there is a thin walled 30mm deep socket that does not have recessed edges, that would make this job far easier; I am still looking. The other option would be to grind the edges down on the thin walled 30mm deep socket to get a flat, not tapered contact surface to get more bite of the 30mm thin adaptor plate nut. My home grinder is too small to reasonably tackle this job so I did not try it but may have a machine shop do it for me if I ever need to replace the adapter plate engine side O-ring. Len has communicated to me that he has adjusted the adapter plate nut recess cavity to have straight sides at 40.5mm diameter which will now easily accommodate the narrow wall 30mm deep socket such as the S-K 30mm with 39.5mm OD.
    My recommendations would be to add the following steps to the instructions:
    1) Measure the threaded depth of the oil passage hole after removing the oil filter and filter bolt. Mark that depth less one mm less than the measured depth for buffer with masking tape on the non notched side of the threaded stud (22mm up on 1982 XJ750RJ Secas). Apply thread locking compound to the first 4-5 thread and anti-seize to the remaining exposed thread. Hand screw in to snug, then torque the engine stud with the installation tool pins into the U side of the stud to the Yamaha recommendations level for the torque of the oil filter bolt of 11 foot-pounds.
    2) Remove the masking tape then apply anti-seize to the remaining exposed threads on the studs.
    3) Follow steps H), I) & J)
    4) At step J use a thin walled 30mm deep socket ideally OD no greater than 39.5mm without recessed edges to allow maximal seating of the socket on the thin 30mm adapter plate nut. Torque to the recommended 12 foot-pounds.
    I have put several miles on both bikes with the new XJ4ever spin on adapter plate without any problems or oil leaks. I am using the AmsOil filter. The oil & filter change with the adapter plate now in place will save 15 minutes every oil & filter change. Given that I rack up 1000+ miles a month this will be a great time saver for me. Oil filters are cheap compared to cost of rebuilding an engine that dies too soon.
    Len was very receptive of my constructive input on the installation process and he has made adjustments in the instructions and the design of the adaptor plate based on my experience. I am overall very satisfied with Len’s product and his service and willingness to work with me was top notch. When I get the next roll of film shot and digitized, I will add some picture positing of how the unit looks. There is no problem with stock exhaust clearance. I can easily get my hand to the oil filter and spin it on and off between header pipes 2 & 3.
    Paul K. Nolan, MD
    Amarillo, TX
    The Bike Doc
    1982 Yamaha XJ750RJ Seca "Sweet Scarlet" http://tinyurl.com/5lnc2c
    1982 Yamaha XJ750RJ Seca "Gray Ghost" http://tinyurl.com/55j5mu
    Central Texas Carb Clinic & Seca Camp Trip http://tinyurl.com/5k3ck7
  6. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    Hey BikeDoc
    Good to see you on the boards, now oil changes will just be a simple occasion
    PS Len you are great. No charge replacment of the bolt and helping to improve your product.
    Im glad I have an XJ and not some "other" bike.
  7. cturek
    cturek Member
    O'Fallon, MO
    I ordered my valve shims this last Sunday evening from Chacal. Today is Thursday and I have them in hand already! Len's reputation for quick shipping is proven on every order I have made with him.
    My friend at work who is restoring a 79 CB650 is continually amazed at how easy I can get parts.
  8. chacal
    Thanks Carl, and thanks Paul for the detailed feedback!
  9. Fishmaster
    Fishmaster Member
    Spring, TX
    I ordered the wrong Airbox rubber boots for my XJ700. I sent a PM to Chacal explaining the problem. He sent me the right parts pretty fast and with no shipping or re-stocking fees. The new rubber boots fits like a glove in the carbs and the airbox.
    XJ4ever is my XJ parts vendor, don't look anywhere else. Len has everything you need for your XJ at reasonables prices and the best service in the planet.
    Thank you so much Len for all your support and appreciated honesty.
    Fish
    P.S. I'll keep you informed about the prototypes parts, so far so good.
  10. Ass.Fault
    LEN IS AWESOME AND WILL GET MY REFERRAL ANYDAY!!!!
    I have ordered many time from XJ4Play and been a satisfied client.
    Recently I ordered throttle shaft seals, mixture screw o-rings, and fuel rail o-rings.
    Priority mail brought them to my door only a few days later.
    Len, keep up the great work. One day we need a kick a*$ web site so we can ogle the parts before we order.
    All in good time :)
  11. XJDriver
    XJDriver Member
    Sacramento, CA
    Len is the man! I ordered my parts on Sunday, paid on Monday, Len shipped them on Tuesday and I had them in hand and installed today (Thursday). There isn't better service anywhere, and the shipping times are crazy fast. I will never go anywhere else to get my parts. Thanks a bunch :)
  12. chacal
    Thanks Driver, hope your project goes just as smoothly! Let me know if I can be of any further help.
  13. chevys
    chevys New Member
    Surrey, B.C. Canada
    Just got my order today, fast shipping, honest and fair service.
    So convenient, might be too easy to order more!!!!!!!!
    Thanks Len, will be ordering more soon.
    Charles :D
  14. chacal
    Thanks Chevys, let me know if I can be of further assistance.
  15. iadubber
    iadubber Member
    Dubuque, IA
    I need the right hand electronics for my 81 maxim 650. My starter button broke off and is currently taped on. Do i need the whole assembly? Do you sell just the starter button?
    Can I also get a price on front. rear, and swingarm bearing kits? thanks,
    chad
    chad.harwick@gmail.com
  16. chacal
    Hey Chad.......youve got mail!
  17. iadubber
    iadubber Member
    Dubuque, IA
    Thanks for the prompt email chacal....I have one more request. Do you have any rear grab bars for my 81 650 maxim?
  18. chacal
    Dubber............sorry, no help on that part.
  19. dqnjuan
    dqnjuan Member
    bmore, md
    Chacal
    Always impressed with your service, got a email reply on a sunday!!(even god took the 7th day off) and today wednesday my package came in already.
    Thanks as always.
  20. cgb123
    cgb123 New Member
    Forsyth Ga 31029
    I just recieved my third order of parts from Len, thank you for such great service. I can't beleave I ordered on Monday and recieved a box load of parts on Thursday. One can't beat that .As soon as the weather warms some I'll get back to work on my pet project. The clear SS brake lines look great. I replaced and painted the front and rear finders (Forrest Green Pearl Metalic eight coats and six coats of high temp clear ) Replaced the rims with a set of 1980 XS1100 Gold, Midnight the same design as the 1982 Maxim.
    Rebuilt the front M/C and both Calipers, Changed the engine, head light,
    tires, carb boots,carbs, right and left handle bar switches with Nos parts from E bay
    Time to replace the brake lines strip and repaint the Gas tank and I'm sure I'll be replacing the petcocks and some electrical By the way the color tune plug and carb sticks work great.
    Having your store you are a life saver for all of us that have a love for the XJ bikes
    Greg
  21. chacal
    Thanks guys! I appreciate your business. No better way to stay warm than to work on your bike. From what I can tell, you guys are going to be really warm come spring..............!
  22. iadubber
    iadubber Member
    Dubuque, IA
    Chacal,
    I just submitted my order for bearings and the starter switch. I didn't read further down on the email and didn't include my quote number, it is 011309022T. Sorry and thanks,
    Chad
  23. XJDriver
    XJDriver Member
    Sacramento, CA
    yet another great parts shipment from Len. The gaskets and seal fit like a glove and some long over do projects are getting done. Look forward to more orders in the future. :) Thanks again
  24. chacal
    Thanks Driver!
    Chad, you're order is floating thru the air, on the way to ya!
  25. iadubber
    iadubber Member
    Dubuque, IA
    Got it! Thanks! Fast shipping even with the cheapest option. I will definitely be doing business again.
  26. Jeremyah20.9
    Jeremyah20.9 New Member
    Just wanted to say that I recently ordered some parts from Chacal and I was blown away. I bought the oil filter conversion kit for my 81 XJ650 and it was easy to install and will save me lot of time in the future! Also bought some other stuff and the shipping was very quick, the products were top notch, and the service was outstanding! I plan on buying everything I need right here!
  27. chacal
    Thanks guys!
  28. kontiki
    kontiki Member
    Columbia, SC
    I have some part on the way from Chacal. Not the first time I've ordered stuff from him either. He is the very definition of customer service... how nice it would be if all businesses were run like his.
  29. beanflicker_98
    beanflicker_98 Member
    east petersburg pa
    looking for brakes for xj seca 750 rear drum
  30. chacal
    Hey Bean......I sent you a PM with the info you need. Also, you might want to check and considering replacing the rear wheel bearings while you've got everything apart back there to do the shoes...........especially if the bike has some miles on it.
  31. kontiki
    kontiki Member
    Columbia, SC
    Got the fork and carb parts today Chacal, Thanks buddy!
  32. Kiwi
    Kiwi Member
    New Zealand
    Just a quick note to let you know that the carb parts and the rubber foot peg rubbers arrived safely "down-under" today. The new foot peg rubbers look beautiful! :D
    Excellent and rapid service (less than a week) to the far ends of the earth, the local Yamaha agent would still be struggling with my request. I ordered new screws for the front brake master cylinder and a rubber diaphragm for the same back in December from them and I'm still waiting :(
  33. chacal
    Thanks guys. Wow, local Yamaha agents leave a lot to be desired, I suppose...................
  34. Switz1
    Switz1 Member
    Central Illinois
    Good deal.....Fast shipper CHACAL IS A POSITIVE CONTRIBUTOR TO OUR COMMUNITY.
  35. rhys
    rhys Member
    Columbia, MO
    Ours was so bad that they went out of business a few years ago amid a bait and switch scandal.
    By comparison, I've done over $500 business with chacal JUST THIS YEAR and been perfectly satisfied with all my parts. THANKS BUDDY!
  36. chacal
    Thanks guys, I appreciate your business!
  37. CaptNemo
    CaptNemo Member
    Reno
    Chacal,
    My parts have arrived, thanks for combining those two orders.
    Do you have pictures available of your aftermarket brake rotors?
    I am thinking of getting a set and would like to see them.
    Thanks for everything.
  38. chacal
    Hey Nemo, thanks for the feedback.
    Send me your real-world e-mail address, and I'll send you some images (or, if your patient, Fitz will be posting some images soon!)
  39. iadubber
    iadubber Member
    Dubuque, IA
    Chacal,
    In my haste to hurry and get bearings last week. I forgot a couple things. I forgot one bearing kit...
    How much for the triple tree bearing or bearings
    and
    Fork Seals
    81 Maxim 650
    thanks!
  40. bill
    bill Active Member
    Raleigh, NC
    Hi Len - got my seals and valve tool - Ordered Friday arrive on Monday - great service as always. Thanks!
  41. chacal
    Thanks Bill!
    Chad.....I've sent you an e-mail, thanks!
  42. MrParadox
    MrParadox New Member
    Lodi, WI
    Got my idle mixture screw set today! Shipping was quick as always. Even with a slight mixup, you got things back on track painlessly. Thanks for your great business. :)
  43. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    Placed the order on Thursday, the parts arrived on Saturday.
    Len, I suppose if you told me how you do it you would have to kill me?
    Great service as always
    thanks
  44. chacal
    Yes, I would, and I truly despise even the thought of that kind of violence............ :D
    Thanks guys!
  45. Don_A
    Don_A Member
    Shakopee, MN
    Chacal, you've done it again!
    I ordered nearly $200 worth of bits and pieces for my valve job and carb rebuild project on Wednesday. Priority mail got the stuff to me today! Everything looks great.
    The only thing that would make this better is if Chacal, himself, came with the parts and did the work for me.
    Amazing service, once again.
  46. chacal
    Thanks Don! I'm working on shrinking myself right now.........that way, it will be more affordable to me to ship myself around the country.
  47. NZXJ750RIDER
    NZXJ750RIDER Member
    new zealand
    hi do u have any side covers for 83 and 84 xj750's?
  48. 600ccmicrob1
    600ccmicrob1 Member
    South Central PA
    I am now a true believer. Ordered on Thursday and received them on Saturday. Thanks!
  49. chacal
    Hey 600cc, thanks., glad we were able to help!
    NZ750.....do me a favor, can you post an image (or send to me via e-mail) what your side covers look like on your bike? I might have some, but some of the non-North American 750's are a bit different from the USA versions, and I'd to observe which style of side cover your bike actually uses........
  50. CaptNemo
    CaptNemo Member
    Reno
    Hey Len thanks for the parts again.
    My wife always knows when I'm expecting a shipment from you because I keep looking for the mail man, I'm like a kid on Christmas.
    Front brakes and fork parts will be next!
