For Sale XJ PARTS FOR SALE---FOR ALL MAXIM, SECA, AND TURBO MODELS
Discussion in 'For Sale, Trade/Swap, Wanted' started by chacal, Nov 10, 2006.
  1. AutumnRider
    AutumnRider Member
    Raleigh, NC
    Thanks Len I got my rest of my order yesterday, that was quick...
  2. theWoolf
    theWoolf Member
    hey i need a gas tank mine has alot of shit in it how much for one that is spotlis and ready to go on my 81 yamaha seca 750???
    tHANKS, THEwOOLF
  3. chacal
    Thanks guys, we appreciate the feedback and the business!
    Woolf, I sent you a PM with info about the tank.
  4. thehasty
    thehasty New Member
    Looking for a replacement seat. Not sure what terminology to use, but currently I have the the high passenger back section. It is aged and dry. Was wanting to go with the smoothing looking seat with no noticeable passenger section. Any suggestions? 82 Maxim 650.
  5. chacal
    Hi Hasty, thanks for writing. All we have available is the original style seat cover for your bike:
    SEATS AND SEAT COVERS:
    Original and reproduction seat parts allow you to restore one of the most important parts of your entire bike: where your butt is placed! There's nothing worse than a worn, torn, faded, destroyed, ill-fitting seat to inspire ridicule amongst friends and to make your bike look old.
    Our reproduction, original style seat covers are made from a durable, marine-grade vinyl that duplicates the original material grain and pattern, and has the original di-electrically heat-impressed ribs and simulated "stitching" where applicable. Made from marine-grade vinyl which is treated for both water- and mold-resistance for the ultimate in longevity.
    Please note that reproduction seat cover material is not available in the same incredibly shiny gloss-black finish that original seat covers were (most people have never seen an original, brand-new XJ seat cover; but trust us-----the original materials had an almost unbelievable level of gloss and "sheen" to them which is simply not available in the aftermarket materials). People who wish to get closer to the original ultra-sheen appearance can dye these covers using our Vinyl Prep (HCP10918) and High-Gloss Vinyl Dye (HCP10349) to come very, very close to the original appearance, although, truthfully, 99.9% of owners will never notice the difference.
    Although the replacement of a SEAT COVER is not a mechanically difficult task, the proper building or rebuilding of the underlying foam support IS an important factor in terms of comfort, fit, support, and durability of the finished seat and cover unit. For this reason, unless you have experience in this area, we suggest you allow an experienced upholstery shop perform the installation for you. Since our seat covers are cut and structured just like the originals, it will be a simple, trivial job for an upholstery shop to install your cover in an absolutely correctly and professional manner.
    If you choose to install a cover yourself, you'll need a supply of 1/2" standard (or stainless) steel staples for the installation of the cover onto the seat pan. Such products, along with a heavy-duty staple gun, can be obtained at most hardware or home-improvement stores (Home depot, Lowe's, etc.).
    By the way, since many people are curious, our experience shows us that without a LOT of effort, neither seat covers nor seat pans are interchangeable between different XJ model (for example, neither an XJ650 Maxim seat cover nor the complete seat will fit onto an XJ750 Maxim model). The seat pans are too different and have very different attaching points, brackets, and shapes to make interchange between models anything even approaching "a simple swap".
    all XJ400 (4G0) and XJ550 models:
    HCP13402 Reproduction of original SEAT COVER, with original style di-electrically, heat-pressed ribbed seams and padded backing, ready to install. The main shaped and sculpted seat foam is NOT included with the seat cover. Includes the hold-down strap, but not the strap hardware. Fits XJ400 (4G0 models) and all XJ550 Seca models.
    $ 109.95
    HCP4331 OEM original COMPLETE SEAT ASSEMBLY, cover, foam, and pan, ready to install. Seat under-brackets and insulating pads are not included and should be transferred from your original seat. Fits XJ400 (4G0 models) and all XJ550 Seca models.
    $ 399.95
    HCP16463 OEM rebuilt original COMPLETE SEAT ASSEMBLY, cover, foam, and pan, ready to install. Seat under-brackets, hinges and hinge plates, latches, catches, document holder tray, hardware, and bumper pads are not included and should be transferred from your original seat. Fits all XJ400 (4G0) and 1981-83 XJ550 Seca models. This is an original (used) seat that has a new seat cover properly installed, the seat foam rebuilt to original contour and density, and is completely ready to install once your hardware and bumpers are transferred from your original seat pan. Since original seat pans and foam structures are used in the construction of this replacement seat, you can be assured of a proper look and fit of this seat onto your bike.....the drop it on and ride! NOTE: original seat trade-in required. A core charge of $125.00 required with order (not included in the price below), which is completely refunded when an original XJ400 (4G0) or 1981-83 XJ550 Seca model seat pan and foam is traded back in to us. Trade-in core pan must not be damaged (cracked, burned, melted, broken, stripped-out studs or threaded inserts) and must have the original seat foam or it will be refused and returned to you!
    $ 339.95
    all XJ650 Maxim models:
    HCP13987 Reproduction of original SEAT COVER, with original style di-electrically, heat-pressed ribbed seams, simulated seam stitching, and padded backing, ready to install. The main shaped and sculpted seat foam is NOT included with the seat cover. Fits all 1980-84 XJ650 Maxim models. NOTE: is not correct and does not fit XJ650 Midnight Maxim model.
    $ 99.00
    HCP16347 OEM rebuilt original COMPLETE SEAT ASSEMBLY, cover, foam, and pan, ready to install. Seat under-brackets, latch bar, and bumper pads are not included and should be transferred from your original seat. Fits all XJ650 Maxim models. This is an original (used) seat that has a new reproduction seat cover properly installed, the seat foam rebuilt to original contour and density, and is completely ready to install once your hardware and bumpers are transferred from your original seat pan. Since original seat pans and foam structures are used in the construction of this replacement seat, you can be assured of a proper look and fit of this seat onto your bike.....the drop it on and ride! NOTE: original seat trade-in required. A core charge of $125.00 required with order (not included in the price below), which is completely refunded when an original XJ650 Maxim seat pan and foam is traded back in to us. Trade-in core pan must not be damaged (cracked, burned, melted, broken, stripped-out studs or threaded inserts) or it will be refused and returned to you!
    $ 329.95
    all XJ650RJ Seca models:
    HCP516 OEM original SEAT COVER, with original heat-pressed seams and padded backing, ready to install. The main shaped and sculpted seat foam is NOT included with the seat cover. Fits all XJ650RJ and RJC Seca models, and all XJ650 Euro (4K0 and 4K1) models.
    $ 149.95
    HCP16461 OEM rebuilt original COMPLETE SEAT ASSEMBLY, cover, foam, and pan, ready to install. Seat under-brackets, hinges and hinge plates, latches, catches, hardware and bumper pads are not included and should be transferred from your original seat. Fits all XJ650RJ and RJC Seca models, and all XJ650 Euro (4K0 and 4K1) models. This is an original (used) seat that has a new seat cover properly installed, the seat foam rebuilt to original contour and density, and is completely ready to install once your hardware and bumpers are transferred from your original seat pan. Since original seat pans and foam structures are used in the construction of this replacement seat, you can be assured of a proper look and fit of this seat onto your bike.....the drop it on and ride! NOTE: original seat trade-in required. A core charge of $125.00 required with order (not included in the price below), which is completely refunded when an original XJ650RJ, RJC, or XJ650 Euro (4K0 or 4K1) model seat pan and foam is traded back in to us. Trade-in core pan must not be damaged (cracked, burned, melted, broken, stripped-out studs or threaded inserts) and must have the original seat foam or it will be refused and returned to you!
    $ 329.95
    all XJ650 Turbo models:
    HCP16464 Reproduction of original SEAT COVER, with distinctive original di-electrically, heat-pressed dual "raised inserts" and seams, ready to install. The main shaped and sculpted seat foam is NOT included with the seat cover. Fits XJ650 Turbo models.
    $ 109.95
    HCP16468 OEM rebuilt original COMPLETE SEAT ASSEMBLY, cover, foam, and pan, ready to install. Seat under-brackets, hinges and hinge plates, latches, catches, hardware, document holder, side grab handles, and bumper pads are not included and should be transferred from your original seat. Fits all 1982 XJ650LJ Turbo models (does not fit 1983 models). This is an original (used) seat that has a new seat cover properly installed, the seat foam rebuilt to original contour and density, and is completely ready to install once your hardware and bumpers are transferred from your original seat pan. Since original seat pans and foam structures are used in the construction of this replacement seat, you can be assured of a proper look and fit of this seat onto your bike.....the drop it on and ride! NOTE: original seat trade-in required. A core charge of $125.00 required with order (not included in the price below), which is completely refunded when an original XJ650LJ model seat pan and foam is traded back in to us. Trade-in core pan must not be damaged (rusted, burned, twisted, cut, stripped-out studs or threaded inserts, or have the seat cover mounting tabs broken off) and must have the original seat foam or it will be refused and returned to you!
    $ 369.95
    all XJ750 Maxim models:
    HCP13985 Reproduction of original SEAT COVER, with original style di-electrically, heat-pressed ribbed seams and padded backing, ready to install. The main shaped and sculpted seat foam is NOT included with the seat cover. Fits all 1981-83 XJ750 Maxim models. NOTE: this seat cover is not correct and does not fit XJ750 Midnight Maxim models.
    $ 109.95
    HCP16346 OEM rebuilt original COMPLETE SEAT ASSEMBLY, cover, foam, and pan, ready to install. Seat latch brackets, hardware, and bumper pads are not included and should be transferred from your original seat. Fits all XJ750 Maxim models. This is an original (used) seat that has a new seat cover properly installed, the seat foam rebuilt to original contour and density, and is completely ready to install once your hardware and bumpers are transferred from your original seat pan. Since original seat pans and foam structures are used in the construction of this replacement seat, you can be assured of a proper look and fit of this seat onto your bike.....the drop it on and ride! NOTE: original seat trade-in required. A core charge of $125.00 required with order (not included in the price below), which is completely refunded when an original XJ750 Maxim model seat pan and foam is traded back in to us. Trade-in core pan must not be damaged (cracked, burned, melted, broken, stripped-out studs or threaded inserts) and must have the original seat foam or it will be refused and returned to you!
    $ 339.95
    all 1981-83 XJ750 Seca models:
    HCP13986 Reproduction of original SEAT COVER, with original style di-electrically, heat-pressed ribbed seams, simulated seam stitching, and padded backing, ready to install. The main shaped and sculpted seat foam is NOT included with the seat cover. Fits all 1981-83 XJ750 Seca and all XJ750 Euro models.
    $ 109.95
    HCP16345 OEM rebuilt original COMPLETE SEAT ASSEMBLY, cover, foam, and pan, ready to install. Seat under-brackets, hinges and hinge plates, latches, catches, document holder tray, hardware, and bumper pads are not included and should be transferred from your original seat. Fits all 1981-83 XJ750 Seca and all XJ750 Euro models. This is an original (used) seat that has a new seat cover properly installed, the seat foam rebuilt to original contour and density, and is completely ready to install once your hardware and bumpers are transferred from your original seat pan. Since original seat pans and foam structures are used in the construction of this replacement seat, you can be assured of a proper look and fit of this seat onto your bike.....the drop it on and ride! NOTE: original seat trade-in required. A core charge of $125.00 required with order (not included in the price below), which is completely refunded when an original 1981-83 XJ750 Seca or XJ750 Euro model seat pan and foam is traded back in to us. Trade-in core pan must not be damaged (cracked, burned, melted, broken, stripped-out studs or threaded inserts) and must have the original seat foam or it will be refused and returned to you!
    $ 339.95
    all 1984 XJ750RL Seca models:
    HCP522 OEM original BLACK SEAT COVER, with original heat-pressed seams and padded backing, ready to install. The main shaped and sculpted seat foam is NOT included with the seat cover. Fits all XJ750RL and XJ900RK, RL, N/FN, and F models.
    $ 239.95
    HCP4344 OEM original COMPLETE SEAT ASSEMBLY, black cover, foam, and pan, ready to install. Seat underbrackets and insulating pads are not included and should be transferred from your original seat. Fits all XJ750RL and XJ900RK, RL, N/FN, and F models.
    $ 449.95
    HCP16462 OEM rebuilt original COMPLETE SEAT ASSEMBLY, cover, foam, and pan, ready to install. Seat under-brackets, hinges and hinge plates, latches, catches, document holder tray, hardware, and bumper pads are not included and should be transferred from your original seat. Fits all 1984 XJ750RL Seca and all XJ900 RK, RL, N/FN, and F models. This is an original (used) seat that has a new seat cover properly installed, the seat foam rebuilt to original contour and density, and is completely ready to install once your hardware and bumpers are transferred from your original seat pan. Since original seat pans and foam structures are used in the construction of this replacement seat, you can be assured of a proper look and fit of this seat onto your bike.....the drop it on and ride! NOTE: original seat trade-in required. A core charge of $125.00 required with order (not included in the price below), which is completely refunded when an original 1984 XJ750RL Seca or a XJ900 RK, RL, N/FN, and F model seat pan and foam is traded back in to us. Trade-in core pan must not be damaged (cracked, burned, melted, broken, stripped-out studs or threaded inserts) and must have the original seat foam or it will be refused and returned to you!
    $ 369.95
    all XJ900 models:
    $ 239.95
    $ 449.95
  6. XJPilot
    XJPilot Member
    Sarnia, ON
    Hey Len,
    Got my order today. Valve shim, YICS port blanking tool, and SS braided brake lines. Severely impressed!! Great products and great doing business with you! Thanks again!
  7. snowyroads
    snowyroads Member
    Tacoma, WA
    Re: XJ PARTS FOR SALE---FOR ALL MAXIM, SECA, AND TURBO MODEL
    Great quality!
    super fast shipping
    thank you so much!
  8. rustysavage
    rustysavage Member
    Belvidere
    Another perfect transaction!! Shims all arrived quickly and were perfect! Thanks for another smooth deal!
  9. pabstblueribbon
    pabstblueribbon Member
    Norristown, PA
    thanks for the great transaction! Headlight relay arrived quickly, and now I have a working headlight :)
  10. macros10
    macros10 Member
    Newport News, Virginia
    Hey Len,
    Received my order from you today. After-market fuse box with many accessories, oil filter, and the JIS screwdriver set!. Very pleased with it all and can't wait to get to work on the bike!! Thanks for being so communicative and helpful and getting it out to me so fast! Nice doing business with you! Thanks again!
    Mac
  11. etg29
    etg29 Member
    Normal IL
    Hey Len thanks for the great service. Parts arrived on time and it one of things i bought fixed the bike!
  12. quikcobra
    quikcobra Member
    Orlando Fl.
    So far I have dealt with XJ4ever only once, However it was really smooth, great communication, fast shipping. Helped change my mind about my 82 XJ550. I thought it would be a nightmare to find anything... But thanks for them so far (Alot more business to get this bike perfect in the future for sure) Its going to be easier then expected....
  13. JameyP
    JameyP Member
    Princeton, NC
    Hey Len,
    New fork supplies arrived today in great packaging. Looking forward to getting this done so I can ride!
    Thanks,
    Jamey
  14. chevy314
    chevy314 New Member
    Had a heck of a time finding jets for my 86 XJ700 Maxim. Len had them at a fair price and fast shipping. Thanks!
  15. shangovi
    shangovi Member
    Burtonsville MD
    Just got home to find my parts waiting - 3 days from order to recieve! Great service. getting my next order ready ;)
    Thanks Len...
  16. Joel07
    Joel07 Member
    Durham, NC, USA
    Thanks again for the quick shipping and the great parts!! You will continue to be my first stop for all my bike parts with service like this!!
  17. smuv
    smuv New Member
    I cant begin to thank you enough, chacal! I ordered 3-5 day, it got here in 2 days, everything was packaged in such a way that it took moments to inventory everything and see that it was all there and correct.
    You will be the man behind all of my XJ projects from here on out!
  18. adrian1
    adrian1 Active Member
    Long may Len the king of customer service reign!! When my Progressive fork springs didn't arrive in OZ for quite sometime (thanks USPS), Len sent me another set just like that. By the way I want to re-sell the 1st set that eventually arrived and give the proceeds to him. PM me if you're in the market! (XJ 900)
  19. AutumnRider
    AutumnRider Member
    Raleigh, NC
    WOW! I placed an order on Sunday with Len for a set of parts that covered nearly all areas of my bike, not an easy order to fill. I had several questions and had ordered some parts incorrectly. Len got it right and the parts are ALREADY on their way.
    Len, thanks for all your advice and patience,
    Kent
  20. wwj750
    wwj750 Member
    central minnesota
    I just recieved my order today-Thank you very much for your prompt service & at a fair price. I will most certainly be a return customer!
