For Sale XJ PARTS FOR SALE---FOR ALL MAXIM, SECA, AND TURBO MODELS
Discussion in 'For Sale, Trade/Swap, Wanted' started by chacal, Nov 10, 2006.
  1. TrebolSUD
    TrebolSUD Member
    Rabun Gap, GA
    Re: XJ PARTS FOR SALE---FOR ALL MAXIM, SECA, AND TURBO MODEL
    Len, my thanks go to you again for the great service you are offering.
    After getting the new stainless steel brakes lines on you provided and after installing the new fork tube seals my bike's front end is almost in tip top shape.
    I have to tell you that the new rear blinker mounts are SO much nicer than the ones I had on the bike. Before when I hit a bump the mounts would bounce the tailights all over the place. Now, hitting a bump the lights stay still and look great.
    The hardware for the grab rails (items that are really hard to find on most websites) came in a day after I ordered them from you.
    I really appreciate all you are doing and hope to be ordering a few more things from you in the near future.
  2. tdegler
    tdegler New Member
    TREMONT PA.
    Just wanted to let you guys know that I ordered parts on saturday and they came today wensday. Thanks Len for the good prices and the fast service.
  3. chacal
    Thanks guys, glad to help.
    Mark, sorry I overlooked your message! I'll check on those items for you tomorrow, I know I have the front wheel axle, not sure about the bolt.....
  4. Grynen
    Grynen Member
    Holland Landing
    I just got my first order. Was fast even though it felt like forever as I couldn't wait for it to get here. Already have my second order in.
    Thanks,
  5. ItsMikey
    ItsMikey Member
    Warren, MI
    Len, Thanks again for the great service. You E mailed info to me over the week-end, I placed an order on Sunday night, you shipped it Mon. morning, and I had it on Wed.! The best part was that it was 100% correct and packaged properly.
    Anyone who needs parts for their XJ should go to you first. I know I am from now on. Thanks again, Mike
  6. EdinaDad
    EdinaDad Member
    Edina, MN
    Len,
    I just sent an email for some parts request but I saw something in another post that had me thinking.
    Do they have a spin on oil filter for an 83 XJ750 Midnight Maxim, or is there only that little hockey puck thingie?
    Also, are there any braided steel brake lines for my bike? I know it isn't in keeping with the Midnight version, but, I think they would be safer.
    Thanks, Dan
  7. chacal
    Thanks guys.
    Edina........yes, I do have the spin-on oil filter kit available and in-stock for immediate shipping. It's not "original" for any of these XJ series of bikes, but a worthwhile addition/upgrade to them.
    OILING SYSTEM PARTS:
    os1) Reproduction Spin-On Oil Filter Adapter Kit....okay, the original Yamaha cartridge oil filter system is "adequate", but for real oil filtering capabilities and ease of filter replacement---not to mention a certain cool-factor!---you really want to upgrade the factory system to an automotive-type spin-on "can" filter. Doing so not only gets you better oil filtration, easier (much easier) oil changes, but also eliminates the oil cleaner cover, the easy-to-strip by-pass bolt, and all the other associated o-rings and seals needed when performing an oil change using a stock system.
    This system consists of six pieces:
    a) a precision-machined aluminum filter Adapter Plate and mounting Nut.
    b) a threaded mounting Stud and a corresponding stud installation Tool.
    c) a plate-to-block O-ring Seal.
    d) your choice of a Purolator, K&N, or Amsoil spin-on mini-can oil filter.
    e) installation instructions.
    This kit contains everything you'll need to replace your original set-up on any XJ550, XJ650, XJ700, XJ750, or XJ900RK models. NOTE: will work on both all original non-oil-cooler equipped models, as well as on all factory oil-cooler-equipped models (XJ650 Turbo and XJ900RK), without the use of any additional parts.
    The Adapter Plate in this spin-on filter kit replaces the entire outer filter cover (and all its mounting and internal pieces) on all models, and is only about 1" longer in overall length than the stock filter system---so clearance against the frame rails and exhaust headpipes is not an issue. All of the can filters that we offer are approximately 2-3/4" in diameter, and should "fit" easily in-between the two central exhaust header pipes on a stock exhaust system (you may wish to verify clearance on your own bike).
    Additionally, all of the can filters that we offer measure only about 2-3/4" in diameter, which means you should NOT have any problems with accessing them via through the clearance in-between the #2 and #3 exhaust header pipes on stock system. Aftermarket systems MAY pose some challenges in this regard, and due to the variety of different systems on the market, you should measure your system to determine the ease of access.
    HCP1284PL aftermarket Spin-On Oil Filter Adapter Kit, with a Purolator Pure-One mini-can filter. Each:
    $ 54.95
    HCP1284KN aftermarket Spin-On Oil Filter Adapter Kit, with a K&N mini-can filter. Each:
    $ 59.95
    HCP1284AM aftermarket Spin-On Oil Filter Adapter Kit, with an Amsoil mini-can filter. Each:
    $ 64.95
    Periodic replacement parts (the only ones you'll ever need) for either kit above:
    HCP277 replacement Purolator One spin-on mini-can Oil Filter. This gold Purolator can filter is an excellent choice that balances low-cost with good filtration ability, and it has a coarse-texture finish on the can to make the installation and removal simpler. Each:
    $ 7.95
    HCP278 replacement K&N spin-on mini-can Oil Filter. This K&N filter features a high-flow rate with excellent filtration ability. Additionally, this filter has a welded-on hex-nut on the top to aid in installation and, especially, removal. Each:
    $ 12.95
    HCP2798 replacement Amsoil spin-on mini-can Oil Filter. Amsoil ultra-high-performance filters are recognized as the "gold standard" in oil filtration, showing both an extremely high-flow rate with exceptional filtration ability. Each:
    $ 19.95
    HCP2283 spin-on oil filter adapter plate-to-block O-Ring Seal, for the HCP1284PL, HCP1284KN, or HCP1284AM adapter plate kits. Each:
    $ 3.50
  8. Jon81550Maxim
    Jon81550Maxim Member
    N.Ontario
    The colour tune I ordered arrived today. When I saw the box I giggled like a little school girl. Thanks Len.
  9. chacal
    Oh my, I didn't think my boxes had that affect on people any more......good to know that it still happens! Hope you put it to good use Jon, thanks again!
  10. 85maximxj700
    85maximxj700 New Member
    galesburg illinois
    All I can say is WOW!!!!!! First time order arrived today......awsome comunication, fast shipping-----went with priority mail
    I WILL BE BUYING FROM YOU AGAIN!!!!!!!!
    Thanks again
  11. chacal
    Thanks 85 Max! Let me know when you're ready for more goodies!
  12. scribetree
    scribetree New Member
    San Jose, CA
    Add another to your long list of satisfied customers, chacal. I ordered a mess of stuff for my carbs and other bits to get the bike up running, and even though there was some early confusion, chacal bent over backward making everything right. And I've never had stuff show up so FAST!!! I'll be putting another order in real soon, that's for sure.
  13. chacal
    Hey Scribe, thanks....you're really being too generous! Glad that I (finally) was able to get all those confusions remedied, and I really do appreciate your patience and "konstant" understanding through this! :D
  14. zixxerluv
    zixxerluv New Member
    Ottawa, Ks
    Len you are The Man!! Thanks for the fast delivery and minimal packaging. Everything fit perfect and looks great! Thanks again Len. My 700 X wouldn't be running without your service.
  15. johno8
    johno8 Member
    Dartmouth, Nova Scotia, Canada
    I don't know how you do it Ln, but you have the best connections for all things XJ that I've ever seen. XJ owners need more folks like yourself who are so dedicated to keeping customers happy!!
  16. chacal
    Thanks guys!
  17. crath
    crath Member
    Peoria, IL
    Chacal,
    Can you PM me a quote for two ignition coils and a set up plug wires for my 82 650 Maxim.
    Thanks, Christian
  18. chacal
    Hey Christian, I sent you a PM on the coils........
  19. BCXJ
    BCXJ New Member
    Ferrum, VA
    Hey Len, Just a quick note to thank you for your extraordinary effort on my brake hoses and accessories. It is greatly appreciated. Buddy Carter
  20. Kiwi
    Kiwi Member
    New Zealand
    Hi Len.
    All the parts arrived safely down under, thanks again for the excellent service.
  21. chacal
    Hey Buddy and Kiwi, thanks for the notes.
    Kiwi, you should post some of the pictures of all those nice bikes you're hiding down there..........
  22. zixxerluv
    Ottawa, Ks
    I would like to amplify that statement, and say that all bike owners need more specialist like Len, in their friends/buddy lists.
    U Da Man Len!!
  23. flash1259
    flash1259 Member
    W.R. Wisconsin
    1982 yamaha maxim xs400j
    I need front brake caliper and master cylinder do you have these???
  24. Grynen
    Grynen Member
    Holland Landing
    Just received my new air and oil filter.. Another satisfied customer :) As soon as I figure out whats next to fix I will be back.
  25. crath
    crath Member
    Peoria, IL
    I sent you a payment for the coils. Thanks for the quick quote. ....Jeeze, you have EVERYTHING!!!
  26. chacal
    Thanks for the notes and all the orders....you guys are keeping me busy!
    Frank, sorry but I can't be of any help to you on the xs400 parts, unless they interchange with any of these XJ models????
  27. juliecut
    juliecut Member
    Hi Chacal,
    I need to pick up the following and wonder if you can help?
    Wire harness for 82 XJ650
    Colortune plug kit
    very small bulbs for dash indicator lights
    in tank fuel filter
    Let me know if you can help?
    Also, don't know if you are looking for parts, but have 83 XJ650 for teardown here if you're in need.
    Julie
  28. chacal
    Hey Julie......you've got mail!
  29. Madone1
    Madone1 Member
    Hey flash,
    I just got a new caliper for my XS400J at APF motorcycle salvage. They are at http://www.apfmcsalvage.com/. I also had a new master cylinder installed, but my friends at Clawson Motorsports did that. It's a new unit. They are at www.clawsonmotorsports.com. They might be able to at least point you in the right direction for sourcing some parts.
  30. tumbleweed_biff
    tumbleweed_biff Active Member
    Gahanna Ohio
    Chacal,
    would you by chance have a windshield appropriate for an XJ650J? If so, how much would it be?
  31. chacal
    Hey Tumble,
    This is the closest thing I'd have available for an XJ650 Maxim:
    Rifle Fairing off a XJ650 Maxim, painted black, USED, very nice shape, with a shorty 12" windscreen. You can see this fairing at:
    http://www.rifle.com/stores/showdetl.cf ... axim%20650
    It has the headlight insert for the stock round headlight, but no other moutning hardware. Rifle still sells complete replacement hardware kits for these for $48.00 or so; you may be able to talk them into selling you just a partial kit for less, or just fabricate them yourself.
    This is a very high quality fairing and is in very nice shape. A couple of very small scratches in the paint on the right side. VERY Small.
    NOTE: due to the size of this item the discounted shipping offer does not apply to this panel!
    $150.00
  32. Grynen
    Grynen Member
    Holland Landing
    Hey Hey I installed my new spin on filter and new air filter. You are the man.. Hey can you send me some info on the 82 xj650 wire harness as well please.
  33. chacal
    Thanks Grynen! ........I send you a PM.
  34. Phil
    Phil Member
    Hi Len,
    Got the latest parts order from you and everything is great. Fast service too! I don't know how you do it but I'm darned glad you do.
    Thanks,
    Phil
  35. schmuckaholic
    California
    He doesn't sleep. Ever. :D
    As are we all. He's not only a parts supplier and a good guy, but a copy editor for those carb writeups I've been doing.
  36. IB_XJ700Xer
    IB_XJ700Xer New Member
    work
    Hi Len,
    Made my order and looking forward to using the Colortune! Man, I can't wait! I'm sure it will be here in no-time just like always!... Thanks again for being so helpful. You always come through!
    I can tell by all the posts, and it is no surprise, that you have made a lot of people happy while working on there bikes... There is not an easier guy to work with!
    Thanks!...
    IB
  37. chacal
    Thanks S & B.....!
  38. taz65
    taz65 New Member
    paris, ar
    Hey chacal
    Hot D---- this guy is fast , and not only that the parts look great . I sent payment either monday or tuesday and the parts made it the house by friday the same week.
    cant wait to get further along on my 82 xj 750 maxim and order some other parts that i need.
    prices were more than fair especially after watching some stuff on ebay go for way over what chacal priced.
    THIS GUY ROCKS FOR ALL THE XJ COMMUNITY.
    THANKS AND LOOK FORWARD TO DOIN BUSINESS AGAIN.
    THE TAZ :D
  39. chacal
    Nick----thanks! Always glad to help.
    I guess I can put another notch in my lower fork tubes, another happy rider!
  40. nailr
    nailr New Member
    I'm looking for a backrest to fit a 1986 Yamaha Maxim 750-x. Is my only option to try and find an original or would something else fit?
  41. uncebanyo
    uncebanyo Member
    Boulder, CO
    Chacal is the MAN.
    Got my parts quick!
    Thanks Chacal. Not sure what I would do without you!
  42. chacal
    Hey unce.......you're welcome!
  43. gurgietrueshot
    gurgietrueshot Member
    Kansas
    I'm looking for gauges for an 82 650 Seca. Really all I need is the tach and a mounting bracket if you have one.
  44. CaptInsanoX
    CaptInsanoX New Member
    Chacal, got the boots, manifold bolts and manual. Thanks again for all the help figuring out everything I needed and for the quick service. You are by far the best parts supplier I have dealt with! I look forward to giving you more of my hard earned cash!
    Duane
  45. CaptInsanoX
    Three days to ship and I have my new jets! Thanks Chacal, you're the man! Pleasure doing business with you!
    Duane
  46. chacal
    Hey guys, thanks! I appreciate your business.
    Gurgie, sorry but I can't be of any help to you ont he 650 Seca gauges at the present time.
  47. Hyperion
    Hyperion Member
    Netherlands
    chacal,
    What do you ask for a new Petcock for 750 Seca?
    and what will it cost to ship this to europe??
    thanx in advance ;)
  48. Jberg
    Jberg New Member
    Newmarket, Ontario, Canada
    chacal,
    I received the chains etc. much earlier than expected (just didn't have a chance to post earlier). Thanks!
  49. chacal
    Thanks Jberg, glad to hear that Canada Post is doing their job well!
    Hyperion, I sent you a PM on the petcock information.
  50. one2dmax
    one2dmax Member
    I second the service he offers. Very quick shipping. Thanks!
