XJ variant horsepower
Discussion in 'XJ Technical Chat' started by LarryMc, Mar 26, 2018.
  1. LarryMc
    LarryMc Active Member
    Lakewood, WA
    Im hoping someone can verify the following:
    FZ600=54hp or 56hp/ Bs30 carbs /120 max speed
    YZ600=59hp or 66hp / Bs30 carbs / 125 max speed
    Fj600 =69hp or 72hp / BS32 carbs /130
    Max speed
    Info regarding specs is all over the place. If you have a solid source for the data please include a link
  2. LarryMc
    Lakewood, WA
    Following up on this, in case your interested, I finally found some reliable data.
    I've changed what is applicable the other stuff is good.
    FZ600 = 68hp
    YX600 = 66hp
    FJ600 = 72hp
  3. Kickaha
    New Zealand
    I would be very surprised if the FJ600 had anything close to 72hp even at the crank
  4. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    apparently ,according to my little book , the fj600 is the same engine as my xj600, and indeed is 72hp.
    stu
  5. a100man
    a100man Well-Known Member
    Bedford, UK
    72 bhp is the widely touted figure, however there appears to be some scepticism (not least from our experienced antipodean member) as to how this 40% uplift (from the 550)was achieved with a 70cc uplift and bigger carbs/valves..
    ..Just sayin'
  6. k-moe
    Numbers are useless without context.
    What type of dyno was used?
    How many runs, and were the numbers averaged?
    Was the test engine blueprinted (even factories do this)?
    Did the PR department fudge the numbers?
  7. XJ550H
    i have little widgets that will boost your horsepower by up to 5% so if you add on 20 of them it will boost your horsepower upto 100%:confused:
  8. LarryMc
    Lakewood, WA
    The numbers are copied from the reviews for each bike from Cycle World. It's Yamahas "claimed" horsepower which I believe is estimated on an average at the crank. So subtract 5% - 15% because of drive mechanism loss and contributing other factors to get a closer value.
    The numbers for these bikes are all over the place.
    If someone has a source for better data. Please share it.
  9. Kickaha
    New Zealand
    As a comparison a very well put together but fairly stock engined Post classic race bike CBX 550 (which are actually 572cc and 4 valve, 30mm carb) was run on a dynojet dyno here and got 57 rwhp, Honda claimed 65hp @10,000, I'd be surprised if the XJ/FJ had more than that
    If I ever get around to putting the 600 motor in my shed somewhere in my 550 frame I might find out, it'd be nice to find Yamaha were right
  10. bensalf
    yorkshire ,england
    are the widgets for sale.;)
    stu
  11. LarryMc
    Lakewood, WA
    Upon further investigation, I guess the standard drive trane vs crankshaft horsepower loss is 20% on chain driven bikes and 25% on shaft driven bikes.
    15% loss between the crank and rear hub then another 5% loss from the rear tire.
    I got the calculation figure from the Factory Pro website. Evidentally, the 20% loss figure is used as an average industry standard figure.
    XJ550=50hp-20%=40 hp
    YX600 =66hp-20%=52.8 hp
    FZ600 =68hp-20%=54.4 hp
    FJ600 =72hp-20%=57.6 hp
