xj wont go past 80k backfires around 4000 rpm ? any idea ?
Discussion in 'XJ Technical Chat' started by 650boy, Jun 18, 2009.
  1. 650boy
    650boy Member
    AB, City Of Champions
    the bike has sat for a while and studdered and hesitated around 4000rpm specially when you pulled back the throttle and asked for much more gas.
    i thought it need a good rip on the highway maybe it might clean it out, then i barely made it back !
    kept back firing ??
    thanks
    xj650
  2. SQLGuy
    SQLGuy Well-Known Member
    Re: xj wont go past 80k backfires around 4000 rpm ? any ide
    Sounds like another set of carbs in need of cleaning. The backfiring is probably because the mixture is way too lean - lean as in blocked passages in the carbs, rather than lean as in an adjusment issue.
