Xj1100 crank bearings measurement color
Discussion in 'XJ Technical Chat' started by Turbobob23, Jan 17, 2021.
  1. Turbobob23
    Turbobob23 Member
    Fredericton N.B. Canada
    Doing a rebuild with the manual but just can't figure out how to pick the right color bearing for which crank bearing. Any help would be very much appreciated
    You will also want to get a copy of the Factory Service Manual.
    Turbobob23 likes this.
  3. Turbobob23
    Turbobob23 Member
    Yes thanks. That's actually what I have. I bought it 27yrs ago when I first bought the bike.
  4. Turbobob23
    Turbobob23 Member
    After I posted I had more time to scroll and found the thread you quoted. My spare practice case did not have any markings on either 1/2 after splitting it. Hoping that's not the case when I split my rebuild case. Thanks for the help!
  5. k-moe
    Let me do some more looking. It may be that the 1100 was marked differently. It's also possible that your practice case was a replacement. Does the engine number look like its han-stamped?
  6. Turbobob23
    Turbobob23 Member
    No its the original case from this bike. Just doing a preliminary inspection on the motor being done , I can't yet see anything scratched anywhere on it either. The case is still together as Im waiting on my clutch tool to arrive before going further but the head and cylinder block is off so I can see into the case fairly well. Had a valve drop at idle and am concerned about the bearings being scored. Still have about a week of research to do before the tool arrives for me to proceed so any help in the meantime is greatly appreciated.
  7. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    I've got a PDF of the XJ1100 service manual if you need a copy but looking at the link k-moe posted it could be the same thing.
    Looking at the section regarding the crankshaft bearings it looks to me that the XJ1100 didn't have any numbers etched onto the cases but stamped onto the crankshaft and inside the cases at the side of the bearing housing.
    I could be wrong but hopefully not.
  8. Turbobob23
    Turbobob23 Member
    A PDF would be great! I don't see any stamped numbers anywhere i side or out of the cases unfortunately.
  9. FJ111200
    I can't see an email address in your profile. If you can see one in mine then send me your address.
    Don't want to post up in public.
    Franz and k-moe like this.
  10. Turbobob23
    Turbobob23 Member
    * send me your address.*
    Started a conversation in your inbox
