XJ400 engine noise
Discussion in 'XJ Technical Chat' started by Bigmacke, Nov 23, 2020.
  1. Bigmacke
    Bigmacke New Member
    Sweden
    Hello, i recently bought a 1982 Yamaha XJ400, when getting it home i noticed that it made a weird clunking/ticking noise from the engine, some guys told me to check the valve clearance, i did and 2/8 valves were too tight so it shoulden't be the valves that are making the noise.
    The bike has a pretty rough idle and plug 1 & 2 are kinda white while plugs 3 & 4 are black after just starting the bike up a few times.
    I appreciate all the help i can get!
    I am new to the forum, not sure how to upload the video ("The uploaded file does not have an allowed extension") and i can't post the link to my reddit thread.
  2. Yammaat
    Yammaat Active Member
    Netherlands
    Seems a carbcleaning/readjustment could be in order to start with.
  3. a100man
    a100man Well-Known Member
    Bedford, UK
    Turn the idle up. If it sounds better then it could be primary chain clatter which is fairly common I think. Also make sure cam chain is tensioned.
  4. hogfiddles
    Check the exhaust collar nuts
