XJ550 1981-1983 Mirrors
Discussion in 'XJ Technical Chat' started by Jenkins, Sep 27, 2017.
Tags:
  1. Jenkins
    Jenkins New Member
    Queensland
    Hi everyone,
    What’s the size of the mirror thread on a 550? 1981-1983 model. One of my threads has stripped. Going to try an tap it again.
    Thank you
    fixing mirror or mount?
    right side is lefthanded
    helicoil works nice if it is the mount
    Tap it for M10-1.25.
  3. kosel
    MInneapolis, MN
    The right or left mirror? Yamaha's right side mirror is reverse threaded.
    Jenkins likes this.
  4. a100man
    a100man Well-Known Member
    Bedford, UK
    Never understood that - you'd think it would be the other way around given the way the 'wind' would affect the rotation. I just tapped a 10 x 1.25 thread into my GPZ550 m/c fitted to my 'seca' and bought some universal mirrors that I believe are both RH thread.
    These .. http://www.ebay.co.uk/itm/10MM-Blac...torbike-Rear-View-Side-Pair-Bike/381487224761
  5. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    In case you contact something at speed, the mirror will (should) spin away (loosen) instead of break away (broken).
  6. XJ550H
    and it really works my headlight was flatened cluster smashed ignition key stem riped off right hand grip at 12:00 both mirrors folded in as designed and did not break.
  7. XJ550H
    see the adaptors that come with this set https://www.ebay.com/p/Universal-Mo...d=381487224761&_trksid=p2047675.c100005.m1851
  8. a100man
    Bedford, UK
