Xj550 dies after a few minutes
Discussion in 'XJ Technical Chat' started by HarryHale, Mar 6, 2015.
  1. HarryHale
    HarryHale New Member
    Auburn California
    My 83 maxim 550 will start but as it warms up the idle will race up high and then after a few minutes of that the throttle goes "spongey" and the bike putters out. Then it won't start back up for an hour or so. The carbs were recently cleaned well and tuned. The valves are in spec. Does anyone have any ideas?
  2. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    Had a similar issue a couple years ago. What setting is your petcock on? Mine needed a full rebuild... PRI would sometimes work, sometimes not, ON worked, but it only trickled gas... enough to make it around the block. RES worked fine.
  3. HarryHale
    Auburn California
    I replaced my petcock with a manual one about a year ago. When I pull the tank off and open up te petcock it flows out fine in the on position and the reserve position and shuts off fine in off.
  4. FtUp
    FtUp Well-Known Member
    pacific northwest
    pull the spark plugs and see what they look like. if they are black, you have a flooding issue. if they are white, you are not getting enough fuel. you may also want to check the plug wires and ends for shorting to ground.
    FU
  5. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Did this develop immediately after doing the carbs? Could also be an issue with float heights or needles. When it dies out, crack the bowl drain screws, bet they are dry
  6. 4nik8r
    4nik8r Active Member
    Ottawa, ON, Canada
    Check for the smell of unburnt gas at the exhaust. A overly rich condition worsens as the bike warms up, causing it to sputter and die. Sounds like the idle might be racing to use up that excess gas until it finally floods. Could be a float pin leak, a stuck enrichment circuit plunger, or something else but it sounds like a fuel issue. One issue with manual stopcocks is they don't prevent gas from leaking by a bad float pin if they are left on after the bike is shut down. If gas runs out of the carb or airbox if you leave the stopcock open, you have a bad float pin or seat.
  7. Polock
    open the gas cap when it starts sputtering out
  8. HarryHale
    Auburn California
    It was running perfectly for about 2 months after the carb clean. Then suddenly one morning it was hard to start and died when I got about 2 miles down the road. I just ran it again and couldn't get it to die but the idle was up high. I'll check the plugs.
  9. hogfiddles
    Also check your fuel line for bends, soft spots, internal collapse
  10. HarryHale
    Auburn California
    Fuel line looks good
  11. HarryHale
    Auburn California
    I did (roughly 3 weeks ago) accidentally flood the carbs by leaving the petcock on and leaving for a hike. But after just waiting about half an hour it started back up and ran fine up until about 3 days ago.
  12. HarryHale
    Auburn California
    I guess the other thing that is going on is I know the clutch is totally shot. I'm going to replace the plates but could the clutch have anything to do with this? Please forgive my ignorance. Haha
  13. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    Have you checked the valves shim clearance?
  14. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Possible failed petcock diaphram. Fuel is being sucked through the diaphram, through the vac hose and into the head. That's why the petcock works proper when it's not running. Imo rebuild the petcock and gas cap, replace or add a filter and replace the fuel and vac line if you haven't already.
    Gary H.
