XJ550 not starting
Discussion in 'XJ Technical Chat' started by j_ham, Sep 5, 2022.
  1. j_ham
    j_ham Member
    DFW, Texas
    Time for another "my bike won't start" thread
    I've got an '82 XJ550 project bike I picked up a while back and have not been able to get it to start reliably. I occasionally get one cylinder to fire off but its not enough to get it going. On the extremely rare occasions it has started, when I rev the throttle it stays at 3k rpm for a good 15 seconds before coming back down. It also has a tendency to just slow down and stop. Here's everything I've gone through and looked at:
    Carburetors - bowls have been gone through and slide diaphragms have been checked. I know it's getting fuel because I smell it on the spark plugs and there is fuel in the YICS channel when I open it.
    Spark - Just replaced the plugs. I also checked that the coils are good, and they are reading at the popper ohms. I've also visually checked for spark on each cylinder and its all there.
    Valves - I went through all the valve shims and have made sure everything is within tolerance.
    Compression - Compression is admittedly a little low (about 95-100psi if I recall correctly, which I know is low, but I'd think would be enough to run. Its been a few months since I checked it, but I think those numbers are about right.)
    Cam Chain Adjustment - done
    Oil Change - done
    It may be worth noting that I've been trying to get it going without an air filter installed. I have one, but haven't installed it yet due to the bike not really running and my sometimes overzealous use of starting fluid.
    I really don't know what's wrong with it at this point. Any advice would be helpful.
  2. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Carb sync.
    Definitely at least do a bench sync and then get all the mix screws in the same turns as the one that's firing.
    Check that the mix screws have the spring and the o-ring and the little washer also... Don't lose em!
    Dry all the plugs, gas torch em, and give it a shot.
  3. Oblivion
    Oblivion Active Member
    Northeast Illinois
    Also I highly recommend not using starter fluid without an air filter in. Two things, you’ll be running leaner, which could explain the hanging revs and/or die out.
    The other is if you backfire, you can get a fire in the air box. I have, and it was not fun, with the thought of torching my child’s bedroom which was directly above the garage. If you do go filterless, have a fire extinguisher on standby. I’m glad I had one right by the garage door.
    Now anytime I’m messing around with an aux tank, starter fluid, anything like that, I make sure that extinguisher is within arms reach.
    Franz likes this.
  4. cds1984
    Yikes yes fire... Bad.
  5. Oblivion
    Northeast Illinois
    I've since learned from pilot training that that continuing to start/crank the engine should actually suck the fire into the intake and put out the flames, but that's a bit different with a literal firewall between you and the engine/fire. :D And cleaning up the extinguisher powder was a . . . bear.
  6. j_ham
    j_ham Member
    DFW, Texas
    I used to work at a Ford Model A/ Model T shop, and we always recommended running without air filters because of potential backfires. Solution was the same if they were running one and it caught fire: open the throttle and suck it in
  7. Oblivion
    Northeast Illinois
    It's been over 15 years since that fire, but I seem to recall the can of starter fluid itself specifically warned not to use the product without the filter in place due to risk of fire. Of course I only paid attention to that AFTER the scare. But that's just an old memory, don't have a can handy, and your mileage may vary. What I do know it I probably sprayed WAY too much fluid - filter or no.
