XJ550 Seca crank breather pipe question
Discussion in 'XJ Technical Chat' started by Michael R, Nov 29, 2018.
  1. Michael R
    Michael R Member
    Seattle
    My current breather pipe from the case to airbox is very stiff and difficult to keep attached to airbox. I can’t seem to find new replacements. Chacal?
    Or, is there a later/different Yamaha equivalent that will work? Part number is 4g0-11166-00-00
  2. Toomanybikes
    Tsawwassen bc
    If @chacal can’t get one they are used in a few other bikes
  3. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    Its a breather pipe.... Find any hose that will fit the application and is resistant to oils. Replace as necessarry.
  4. Colin 85 700
    Thunder Bay, ON
    However, if it still fits and you can jam it in place, its OK just a pain in the ass
  5. k-moe
    Getting the bends right without kinking is a trick though.
  6. XJ550H
    look at hardware lots on ebay you may find one then sell the bits and pieces
  7. amiel1157
    amiel1157 Member
    Philippines
    Try bending using hot air blower SLOWLY massaging the hose to your liking..
    Michael R likes this.
  8. XJ550H
    see if you can find a spring to put inside it like they do for raidiator hoses
  9. LarryMc
    LarryMc Active Member
    Lakewood, WA
    The spring on the exterior or interior of the hose trick has worked for me on other bikes. As long as fluids aren't dependant on the hose having flow, your good. It's a breather.
    Colin 85 700 likes this.
