xj550 starter motor
Discussion in 'XJ Technical Chat' started by murray9982, Jan 13, 2021.
  1. murray9982
    murray9982 New Member
    Hi , have a guy here in Oz rebuilding an xj550 and needing a new starter motor . As I have a few xj900 ones , I was wondering if they would fit the 550 , cheers , Murray
  2. hogfiddles
    Nope— you need the [ 550 starter]. 650/700/750/900 starter [ is different].
  3. murray9982
    Hi Hogfiddles , you state that I need the 650/700/750 /900 starter motor , I stated that I have a couple of the 900 ones , not sure why your negative reply . I know the 650 to 900 are the same but have had no experience with the 550, cheers
  4. chacal
    The XJ550 starter motors are completely different than the XJ650-900 motors, and will not interchange / cannot be mounted on the XJ650 - 900 engines.....they simply will not bolt up (the mounting systems are completely different!
  5. murray9982
  6. hogfiddles
    My bad… It was too late at night, and my brain was foggy, And I did not notice that the phone had not recorded the rest of my statement. Let me try again.
    XJ 550 – you need an xj 550 starter
    XJ900 - You can use the 650/700/750/900 starter
