Xj600 85 loom wire cut
Discussion in 'XJ Technical Chat' started by mark1911, Jun 19, 2020.
  1. mark1911
    mark1911 Member
    liverpool uk
    OK so picked up my relay and attempting to wire up the front of the bike so far
    I've got:
    Headlight: green,black, yellow
    Horn: pink and brown
    Main switch:red, brown blue
    Front brake switch: brown green and yellow
    Clutch switch: blue yellow and black and yellow
    Indicators: left and right chocolate and brown and dark green and brown.
    Who ever had the bike before me has cut a green/blue wire coming out of the speedo connector in pic below. But we're does it go?
  2. SQLGuy
    SQLGuy Well-Known Member
    Green/Blue may be for the side stand switch warning.
  3. mark1911
    mark1911 Member
    liverpool uk
    I think possibly they might off spliced the green wire with the blue wire running off it and attached it to one of the headlight wires. So that when you turn your switch your headlight automatically comes on without starting the engine would that make sense though? Thought as long as the switch was on you could operate your headlight without the engine running, or does the headlight only come on with the engine running.
  4. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    headlight comes on when ignition switch is on AND the headlight switch is on , engine doesn't need to be running
    there isn't a side stand warning on the 600
    stu
