XJ600 engine in xj550 frame.
Discussion in 'XJ Modifications' started by Stephen James Whiting, Apr 24, 2022.
  1. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    I have never welded anodized aluminum. Most of my welding was in manufacturing, not repair work. I assume you could sandblast it but if the aluminum is smooth you would also destroy that and have a mat finish.
  2. tobar
    tobar Member
    england
    so as Huntchuks states Acetone wont strip anodising....
    but if welding mounts on to an alu swingarm, clean down to bare alu beforehand with some chemical that will
  3. AndyH64
    AndyH64 Member
    Redcar, North Yorkshire, England
    @tobar the mounts are nearly ready, but my mig throw a wobbler today, the wire feed isn't playing ball-so I need a new on, wire feed that not a new mig.
    Would wet and dry paper remove anodising, with the chemical we all have...good old fashioned elbow grease? Just a thought.
    I am also preparing a build thread for my Radian/XJ/FJ600 and various Suzuki parts cafe racer/restomod project, more soon.
    Cheers Andy
    tobar and Simmy like this.
  4. Huntchuks
    East Rochester, NY
    Use an angle grinder or die grinder with sandpaper. I think the only thing that can remove an anodize finish is mechanical. Only clean where you will weld.
    tobar likes this.
  5. Kickaha
    New Zealand
    You can take it to a place that does plating/anodising and they can chemically strip it, I had a from rim done on my IT200, took maybe 10-15 minutes
  6. AndyH64
    AndyH64 Member
  7. tobar
    tobar Member
    england
    @AndyH64 ...yep looking forward to it...i should do a thread too
  8. AndyH64
    AndyH64 Member
    @tobar yeah get thread started, I look forward to seeing you on my build thread. The more the merrier
    Cheers Andy
