XJ650 carb tuning with the dreaded "pods"
Discussion in 'XJ Modifications' started by willierides, Oct 15, 2007.
  1. Nickembry
    Nickembry New Member
    Rock island, IL
  2. Nickembry
    Rock island, IL
  3. TheCrazyGnat
    Central PA
    It says the video is private.
  4. Nickembry
    Rock island, IL
  5. Eurotas
    Eurotas Member
    Edmonton
    Why not?
  6. Nickembry
    Rock island, IL
    Got it. Sorry for all the posts
  7. k-moe
    A dyno run can't tell you how a vacuum operated carb behaves at speed with pods, unless that dyno is set-up in a wind tunnel.
  8. k-moe
    Do a search for Pumba.
  9. k-moe
    Restricting airflow at less than WOT is the when. The same amount as the factory airbox is how much. THis isn't a guessing game. It's a matter of fluid dynamics, and the engineering work was already done almost 40 years ago. Feel free to play around though. Learning is fun :)
  10. k-moe
    Your idle is lumpy as hell. It shoud be sewing-machine smooth.
  11. Nickembry
    Rock island, IL
    That was the first start. Havent got it tuned yet
  12. Polock
    i think "sqlguy" did a micro squirt conversion
  13. Eurotas
    Eurotas Member
    Edmonton
    Do you know how that turned out for him?
  14. Eurotas
    Eurotas Member
    Edmonton
  15. k-moe
    Pumba
    I would not use, or try to adapt a kit meant for a single cyinder engine. It could work, but there are better solutions.
  16. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Enter this in Google:
    Site: xjbikes.com project shadow warrior
    User skylrk62 switches to a Microsquirt system. Also does a bunch of crazy mods to his xj. It's a pretty wild project.
  17. Eurotas
    Eurotas Member
    Edmonton
    They have four cyl kits avail...
  18. k-moe
    Well in that case......hmmm....... might be worth looking in to.
  19. Eurotas
    Eurotas Member
    Edmonton
    Yup! Comes with everything, so I don't have to go doing a pile of research like the other guy had to in order to find an intake manifold that fits. They have all the sensors, wiring, It's pretty much just plug and play! I'm waiting for them to get back to me.
  20. k-moe
    They have a minifold that fits your XJ, or do they make the kit to fit the factory intake boots?
  21. Eurotas
    Eurotas Member
    Edmonton
    They come in all different sizes, and I checked and they carry something like 30mm all the way up to 60mm
  22. Eurotas
    Eurotas Member
    Edmonton
    Do you know off hand what the size of the intake boots are? Pretty sure they're 50mm...
  23. Eurotas
    Eurotas Member
    Edmonton
    So this is the email I got back from them...decisions decisions....
    Hi,
    For your 4-cylinder engine, the key is the throttle body.
    We don't have the suitable throttle body for 4-cylinder.
    There are two methods to convert it,
    1)You find the suitable throttle body for 4 cylinders on the aftermarket or eBay, we provide the rest.
    2)We provide one big throttle body and 4x fuel injectors, you need to make the manifold, 1 inlet and 4 outlets, and install the fuel injectors on the manifold for each cylinder.
    ECU controls fuel only, you use the stock ignition system.
    The price is more than $1299.
    What do you think?
    Are there four carburetors? what's the size of each carburetor?
    And please tell us the ignition type and max rpm on the engine.
  24. TheCrazyGnat
    Central PA
    You'd really have to want EFI to throw down that much money! You might as well buy a bike with it already at that point, would be my thought. If you are doing it just for giggles though, and have the scratch just laying around, have a blast!
  25. Eurotas
    Eurotas Member
    Edmonton
    Hah I know right? I just thought it would be a cool idea. It would be a cool if they already had all this stuff pre made, but the fact that I'd have to make my own intake manifold, I dunno. I mean it would be fun and all, but for 1300$+, I dunno if it's worth the headache.
  26. TheCrazyGnat
    Central PA
    I think the project would only be viable if you were to cobble things together as SQLGuy did:
    Although I understand carbs can be a hassle, the time/effort that it would take to do all this would be more than it would take to do a few carb cleanings, church and all, I think. Sounds like it could be fun if you had an extra bike just laying around that you wanted to fool around with.
  27. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    This is a thing that I have long wondered.
    Why do all the FI setups on bikes use separate throttle bodies, where cars use the manifold with one TB and multiple injectors? Seems like the single TB would be a lot easier.
  28. Eurotas
    Eurotas Member
    Edmonton
    I think it would definitely be a challenge but not impossible. I would just try and adapt a different intake manifold off of a different bike rather than using a car.
  29. Eurotas
    Eurotas Member
    Edmonton
    I like your thinking, I would probably go with a single throttle body as well. I should ask them to sponsor me lol.
  30. k-moe
    $1200 will almost buy you a brand-new set of Khein carbs with intakes, jetted and ready to go.
  31. k-moe
    There are performance advantages to using individual throttle bodies/ carbs. Have a look at any Ferrari engine. Not a single-carb/TB setup to be found.
    There are cost advantages to using a single throttle body/ carb. Have a look at almost every Harley Davidson, and your car (assuming that it doesn't have a prancing horse on the hood).
  32. Eurotas
    Eurotas Member
    Edmonton
    What's so great about these carbs vs efi?
  33. k-moe
    More time riding, less time spent with initial tuning. You can get cable operated ones as well. Then you can run pods without having a flat spot.
  34. Eurotas
    Eurotas Member
    Edmonton
    I live near mountains. So I thought that might be an issue with carbs...
  35. k-moe
    Not really. It depends on the carb, how they are set up, and what the altitude difference is. It's a bigger issue for motorcycles with narrow powerbands (like 2-strokes).
    CV carbs tend to do a better job of compensating for altitude changes than cable-operated slide carbs.
    Eurotas likes this.
  36. TheCrazyGnat
    Central PA
    Interesting! So the lower air pressures slows the flow of air through the carb, preventing the mixture from getting too lean?
  37. k-moe
    Sort of, except it keeps things from getting too rich. Lower air pressure (more importantly less oxygen per cc of air) effectively increases the amount of fuel in the mix.
    CV carbs have their limits, just like any other carb, it's just that those limits are bit more broad (this is part of why there were (to my knowledge) no high-altitude jet kits provided for the XJ series.
    The CV carbs fitted to aircraft have an altitude compensator that broadens the range of air pressures where it can deliver a good fuel/air mix.
    Eurotas and TheCrazyGnat like this.
  38. Eurotas
    Eurotas Member
    Edmonton
    On a side note guys, what type of ignition system do these bikes use? What is the max RPM, and how many pulses per revolution?
  39. XJ550H
    redlines at 9500k, ( which can be exceeded)
    it is a wasted spark ignition plug fires every time the cylinder comes up
    1000 rpm 1000 fires per cylinder
    tci ignition Transistor control ignition
    not cdi ignition
    edit red line value for correctness
  40. k-moe
    Redline is 9,500 RPM for all models, not just the 550.
  41. Eurotas
    Eurotas Member
    Edmonton
    So you're 100% sure it's TCI?
  42. TheCrazyGnat
    Central PA
    It is absolutely TCI, all XJ's came that way. A lot of online sellers mistakenly label them as CDI.
  43. XJ550H
    only if the manual is wrong;)
    TheCrazyGnat likes this.
  44. Eurotas
    Eurotas Member
    Edmonton
    So it is indeed a tci eh. That doesn't use a pickup coil does it? How does tci work? I'm not familiar with that.
  45. Eurotas
    Eurotas Member
    Edmonton
    Hah Nevermind I see the pickup coil there in the wiring schematic!
  46. Eurotas
    Eurotas Member
    Edmonton
    Also do you know off hand how many pulses per revolution? I'm trying to give the appropriate info to the efi people to see what they can build for me.
  47. XJ550H
    pickups trigger the TCI to fire 2 pick up coils 2 pulses to the tci box per rev.
    the ignition coils fire on both spark plugs that they feed
    pickups are mounted at the end of crank shaft on a plate
    as the pointer passes past each pick up it triggers it sending a signal to the tci
    pickups are magnetic.
  48. Eurotas
    Eurotas Member
    Edmonton
    That's the exact info I was looking for, thanks!
  49. k-moe
    If you start the EFI project, please start a thread. I've got (almost) a Virago that has no carbs, so I'd be interested in seeing your results and difficulties before I decide on what to do with it.
    Reed7742 likes this.
  50. Eurotas
    Eurotas Member
    Edmonton
    Yeah, but I just wanna see what kind of pricing they shoot at me first.
