xj650 crankcase swap
Discussion in 'XJ Technical Chat' started by nablats, May 10, 2018.
  1. nablats
    nablats Member
    whitby
    I am replacing a cracked crankcase. is it ok to use the main bearing shells from my old engine cases in the new (old) cases I just bought, I don't mind buying new ones, I was thinking they will match the old crankshaft
    you have to look at the numbers on the case. info overload goes into it in depth. the bearings are color coded.
    The Information Overload Hour
  3. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    You might want to get some plastigauge to check you have somewhere near correct clearances rather than chancing it.
    cruiserlover and k-moe like this.
  4. XJ550H
    +1^^
    yes thats a lot of work to be wrong about fitment
