Xj650 KO model UK bike 27k on engine ?
Discussion in 'XJ Technical Chat' started by mike shannon, Dec 2, 2019.
  1. mike shannon
    mike shannon Member
    uk
    Hi
    Started to check compression today low 1982 KO engine 650 i8xj
    across the 4 cylinders here are two photos max an min psi as it has be lying for a year or two any ideas it turns over fine set rings do it and valves cleaned and regrind
    Mike
  2. jayrodoh
    jayrodoh YimYam
    Cleveland
    If it has been sitting it may have stuck rings etc. that need some oil or run time to get the compression back up.
    Have you checked the valve shims? If any are out of spec (tight) then it can affect your readings. I would start there before tearing anything down. 27k miles or m's is very low for these motors and I wouldn't expect anything serious to be wrong unless abused.
    Franz likes this.
  3. Franz
    Try the acetone automatic transmission fluid 50/50 mix a tiny amount in each cylinder to ease off the piston rings.
  4. mike shannon
    mike shannon Member
    uk
    Ah thank you I have used diesel in the past a spoon full per pot
    Will let you know
    Mike
  5. mike shannon
    mike shannon Member
    uk
    Hi happy new yeart all
    Did as Franz said left it a while as my Sealy heater was not working anyway
    Just tried the compression test to find
    Pressure
    No1 75psi. No2 100 psi
    No3 125psi. No4 115psi
    Second photo teaspoon off engine oil down no 1 cyclinder 215 psi
    Psi gauge is the push on to the plug hole not screwed in type which I have
    so may have to pop the head of valve seals
    Mike
  6. Franz
    Did you check your valve clearances as jayrodoh advised?
  7. mike shannon
    mike shannon Member
    uk
    Opps Ah no let me do that senior moment
  8. jayrodoh
    jayrodoh YimYam
    Cleveland
    That's good, you're looking for an increase which indicates it is most likely not a valve issue. You may just have some stuck rings that will break free/seal up once run for a bit.
    If the third picture is your actual set, the hose and brass adapters are for the spark plug threads. Nothing wrong with the rubber tip test if you can hold it firmly in place while turning motor over with the throttle held wide open.
    Franz likes this.
  9. mike shannon
    mike shannon Member
    uk
    Thank you no carbs on getting soda blasted
