XJ650 Seca 1980 Not working right
Discussion in 'XJ Technical Chat' started by Gonçalo Melo, Dec 12, 2020.
  1. Gonçalo Melo
    Gonçalo Melo New Member
    Portugal
    Hello.
    I need help from this forum. I have a 1980 xj650 seca that has been giving me problems. Right now I have a lot of difficulty getting the bike to work and when that happens, working is not ideal. I already measured the ignicion coils and they were good, I changed the spark caps. The battery is fine and I replaced the fuse box, but it still doesn't work. Any suggestion?
    Thanks for everything
  2. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Sidestand switch, handlebar cutoff switch would be something to look at - you need a good clean feed to the coils.
    Once running if it is still not good can you confirm valve clearances are good? Then its carburettors - you will need to strip and clean.
    Gonçalo Melo likes this.
  3. Gonçalo Melo
    Portugal
    thanks.
    I will see all that ... I will start with the easiest and then the valves. Sometimes when I hit the rear brake the bike would shut down. Maybe it's an electrical problem. thank you again
  4. Franz
    Also change the fusebox if you have the original Yamaha one. The clips break that hold the glass fuses and they are old. Get a blade type fuse box.
  5. Gonçalo Melo
    Portugal
    I already changed the fuse box. Thanks
  6. Franz
    You need to test the battery when cranking the engine (testing under load) with a multimeter as you need ten volts to operate the transistors in the TCI unit. There are also small jets in the carburettor float bowls which supply extra fuel for cold starting. If these are blocked the fuel air mixture will not be rich enough when you operate the choke lever.
  7. k-moe
    Please add more detail to what the issues are. "Not working" could be due to literally anything.
    According to your post in another thread you have a starter issue. Is there anything else that isn't working right?
  8. Gonçalo Melo
    Portugal
    Sorry, I will try to explain it better.
    When I try to get the bike to work it shows great difficulty. But if I clean the sparks it starts to work more easily, but after a few minutes it shows great difficulties to keep working. When I take the sparks out again they are black and full of fuel. The battery is ok, the resistance of the spark coils are also within the values, I changed the spark caps (NGK xd05f), I also changed the fuse box. What can I see next? Thanks for all the help.
  9. Rooster53
    Good advice here ^^^
    Likely a good indication of excessive fuel from leaking float needle valves or improperly assembled carburetors. Be sure to check your oil level in the inspection window to be sure it is not too high from gas contamination - take a sniff of the oil to make sure it does not smell like gasoline. Don't continue to run the bike if the oil is contaminated with gasoline until the cause has been corrected and the oil changed.
    When I try to get the bike to work (run) it shows great difficulty (it cranks but it is hard to start). But if I clean the sparks it starts to work (run) more easily (better).
    Fouled plugs can be difficult to clean even when just fuel fouled, so if you haven't tried new plugs recently that would be in order, but odds are the carburetors likely need a refresh as suggested above.
    Some helpful links if you have not found them:
    https://www.xjbikes.com/forums/threads/the-information-overload-hour.27544/
    https://www.xjbikes.com/forums/threads/airhead-valve-adjustment-with-pics.14827/
    http://www.xj4ever.com/setting fuel levels.pdf
  10. Gonçalo Melo
    Portugal
    Sorry, for my English. I will check the carburetors.
    Thank you all
    Franz and Rooster53 like this.
  11. k-moe
    Your English is better than most native-speakers in the U.S.. No lie.
  12. Gonçalo Melo
    Portugal
    Hi. I think I have fuel in the oil. Does anyone have any useful advice. Thanks
  13. Franz
  14. k-moe
  15. Franz
    Good point I forgot about those.
  16. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Why would that make a difference? Fuel flow is fuel flow...float needles should always block. BTW my petcock had a bad diaphragm (rubberized coating worn to the mesh) and leaked out onto the carbs when running but still didn't allow gas to flow out to the fuel line with engine off like prime would. Maybe a tear would.
  17. Gonçalo Melo
    Portugal
    What should I do now? It is obvious that I must change the oil but in relation to the fuel that is in the combustion chamber? can i use the air compressor to blow the fuel out? Any idea?
  18. Minimutly
    West Wales, uk
    Pull the plugs and crank it. Maybe place a rag over the top first, and watch your eyes.
  19. k-moe
    Viton tipped needles age/harden and no longer seal. Rust or other detritus from the fuel tank can cause a needle to not seat. The washer or o-ring (depending on model) that seals the needle seat to the carb body can age and fail.
    Owners (and even shops) can set the float levels incorrectly. Floats can stick. The wrong float needles can be installed, causing them to bind in an open position. Floats can be installed upside down. etc, etc.
    In short, float needles do not always prevent fuel from overflowing into the engine, which is why overflow tubes were added to some carbs in the mid 80's by the carb manufacturers.
  20. Huntchuks
    East Rochester, NY
    OK, you interpreted my question wrong. Assuming the float needles are doing their job, the question is in regard to this: The only exception being a perforated vaccum diaphram in the petcock.
  21. Gonçalo Melo
    Portugal
    Hi.
    I tested the petcock and it looks good in all positions.
    I'm almost sure that I must have left the petcock in the prime position and that led to the entry of fuel for the oil. Tomorrow I will test the carburetors. What I thought was an electrical problem seems to be a mechanical problem. I just hope it is anything but pistons, that would be the death of the bike.
    Thank you all
  22. k-moe
    On the other side of the vacuum diaphram is the vacuum line. In the event that the diaphram is perforated, and the vacuum valve is not sealing properly (I left that part out, becuse..oops) then fuel will flow freely into the engine.
  23. k-moe
    Odds are that everything in the engine is fine. The worst outcome is connecting rods being bent, but that's not very common. It will happen if the situation isn't remedied and the engine kept running though.
    Gonçalo Melo and Franz like this.
  24. Gonçalo Melo
    Portugal
    Hello.
    I have already changed the oil and tested the carburetor by applying air pressure to the fuel pipe, and it looks like they are sealing well, however I will only be sure when it is working and the problem is gone. The battery seems to be fine, but it cannot give enough energy. When I turn on the lights, the turn signals don't work and the solenoid doesn't click. what do you think? Battery or something else?
    Thank you all
  25. Minimutly
    West Wales, uk
    Battery - but get yourself a digital meter, you're guessing without one.
  26. Gonçalo Melo
    Portugal
    I found the problem.
    Bad battery and bad starter terminal.
