XJ650 sputtering after 30 min of riding?
Discussion in 'XJ Technical Chat' started by Jonas K, Apr 28, 2021.
  1. Jetfixer
    I have tried two different aftermarket petcocks ...both are on the shelf in a box ....have stock vacuum petcock in both Seca's
  2. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    This is about right, use original/repaired original or new old stock if possible....
  3. Jonas K
    Jonas K New Member
    Embarrass, Minnesota
    Installed new tires, new petcock and redid fuel lines this evening. Bike started right up, went for a quick 10 min ride on the highway and on twisty back roads and the bike ran excellent even after getting to higher rpms, used to be that if you went above 6000-7000rpm that afterwards the bike would start to hesitate and sputter. I took it to 9000 and afterwards didn’t notice any hesitation. Came back and changed the oil and filter for the first time. Also got my manual today so I found the right torque specs for everything.
    Felt like I accomplished a lot!
    I noticed the stock petcock has a much bigger port for the fuel to flow out of than the aftermarket one, the aftermarket is much smaller in total overall size as well.
    I definitely need to do some longer rides to see if the sputtering comes back. If so then I’m going I check the valve clearances, then next thing would be the ignition switch.
    Rooster53 likes this.
  4. Minimutly
    West Wales, uk
    Nice maxim, I'm struggling to like those "buckhorn" bars though.
  5. Jonas K
    Jonas K New Member
    I’ve been on the fence about keeping these bars or going back to the dirt bike bars that I used to have on it! Like the look of the flatter bar, but can’t beat the comfort of this
  6. XJ550H
    it hits his tank when he turns it
  7. XJ550H
    flat bars will require a different master cylinder then there is the issue of the cables and brake hose.
  8. Jonas K
    Jonas K New Member
    Just thought I’d give you guys an update on the bike. After putting the oem petcock on it leaked at the bolts, the old seals were basically non existent, so I ordered new ones and that fixed my problem.
    Since then I’ve put around 200 miles on the bike with no sputtering or hesitation.
    I really notice a difference in how easily it starts and how smooth it runs now.
    Thanks for the help guys!
    StarGeneral likes this.
  9. StarGeneral
    StarGeneral Active Member
    Oregon, USA
    Running into the same issues now on first startup. I also purchased one of the aftermarket style petcocks shown here and am having problems keeping the bike running more than 10 or so minutes. It pops and sputters after it warms and cannot run off choke. Seems like a fuel starvation issue with these aftermarket style petcocks. I'll try popping my OEM one back on later to see if it runs well again.
  10. Simmy
    message deleted.
