XJ650 Starting issues
Discussion in 'XJ Technical Chat' started by RideAlong420, Oct 10, 2025.
  1. chacal
    If using a factory style oil cooler, the ADAPTER PLATE attaches to the engine crankcase via a special UNION BOLT (which has external threads which screw into the crankcase, and internal threads that accept the finned filter cover (or, in your case, the threaded hollow stud which holds the spin-on flat plate).
    The adapter plate is going to add about 2-1/2" of additional projection (away from the engine, towards the header pipes) to the system.
    The threaded stud that we provide with the spin-on kit is not long enough to reach and secure both the spin-on plate and the adapter plate.......you must use the union bolt.
  2. RideAlong420
    RideAlong420 Active Member
    USA
    So the hollow stud will have to come out to be replaced with a union bolt, and it will take 2.5 inches more?
    Welp, I guess that will absolutely be a problem for the future. Everything seems fine for now but 1. I don't know if there is 2.5" of clearance with these headers, unless I can find a way to make these headers spread out 15mm wider (or get new headers made) 2. removing the bolt when everything is fine currently is absolutely something I am putting off till a later date.
  3. RideAlong420
    USA
    I took it for a 20 mile group ride tonight. I definitely need more practice. I feel like my center of balance is off compared to the Honda Rebel 250 I had started out on. With these euro bars, my stance is forward and I keep putting pressure on my right hand and it keeps falling asleep. It gets a little better if I sit up and let my back support me instead. I did some math and I've put on 150 miles on this since getting the bike.
    Couple comments:
    I swear that there is the whistling sound, around 5000 rpms, though I don't really ever get it above 5000 rpms in any gear (4000 in first gear and it sounds so unhappy and loud that I will move into second gear asap, also with the fact 1st gear does not move very fast...I wish you could go faster in first gear without the engine revving so high, because it feels a little like the Rebel, don't bother spending any time in 1st gear except from a stop), Usually I will get it to 5000, and shift into a higher gear instead so I can hover around 3-4k rpm. She's 44 years old and I wanna baby the hell out of her (7 years older than me). I hear this is normal, however.
    Since doing the valves back in June, which were out of spec, (6/8 of them needed to be decreased by 1 shim each, except Intake #4, needed to decrease by 3 shims!! When I checked the compression 1-3 were great, within 5psi of each other, but 4 was still quite low: 140.3 vs the highest, cylinder 1 at 152.7, a 12.4 psi difference, when max tolerance is 14psi. So technically it's okay, but that does stand out. A leakdown test was later done, and I was advised all of the cylinders across the board were under 10% and this was good, though I have no notes about where the, potentially, up to 9%? leakage was going... ) I hadn't ridden the bike between getting the bike back, except one time in a parade, and that's a bit too many distractions going on to really focus on the bike and how it's behaving.
    Anyways, now that I've had her back, I've put about 50 miles on her, and it's given me some time to think about how the bike feels and what noises she's making and what's expected, what's not expected, etc.
    She runs HOT, after the 20 mile ride you could feel the absolute heat radiating off her. It was about 82F with about 77-85% humidity, and we parked to talk and the bike was steaming. Either from cooking the air off the headers, and the humidity, or somehow from the cable lube I had tried to squirt a little bit down into the choke cable (rather unsuccessfully because I don't have that cable lube tool). I don't know if it's that's normal, with an air cooled bike, or if it's something more.
    She also still makes a sound that sounds like something is "spinning" in the engine. Is it the cam chain? I don't know. It has an automatic chain tensioner, which afaik you shouldn't have to adjust, but maybe you do? I saw a few light scrapes on the inside of the valve cover, which would make me think at some point in the past the chain got loose and hit the underside. When I was doing the valve adjustment, I checked the tension via very gentle back and forth eighth of a turn and pulling up on the chain with my fingers, it felt really tight.
    When I brought this up to my mechanic friend, they suggested that it could be the camshaft and the valves and that it's just a noisy bike. Tonight, I came across a post here, to someone else, saying that when the valves are properly adjusted it "sounds like a sewing machine" and yeah, I guess it kinda sounds like that? Been a while since I thought about what a sewing machine sounds like but I guess so?
    I guess I'm just worried that it's a "bad" sound.
    Also, I'm not sure if it was the wind, or if it was the road or me, but as I was getting to 50-55mph the bike felt a little..."wobbly" not like a wobble of death or anything, I've seen those, just more like...floaty? My ex said she took it up to 70 and it positively rips, and says it behaves differently past 50 or so, compared to before 50, so maybe that's what I've experienced.
  4. RideAlong420
    USA
    I also liked that when I let my friend use my bike, to ride up and down the road to hear the noise I was hearing, they immediately revbombed the neighborhood. Me and my ex had a laff
  5. RideAlong420
    USA
    I checked this a couple days later after I wiped it all off, and I'm noticing what looks like oil around it again. The bike tends to just sit on it's kickstand, And this is on the right side, so the oil is leaning away. It's not leaking nearly enough to cause a puddle on the ground, it's probably like a pinch of oil, that hasn't yet made enough surface tension to drop on the ground.
    How would I fix this? Do I just tighten the Allen key thing here, or do I have to lay the bike on its left, unscrew it, and replace the o-ring on the opposite side? Or is it more involved than that?
  6. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Kick stand or the kick stand in small hole will be fine.
    I wouldn't tighten it, but remove and inspect. Over tightening will break the outer easily.
    If I could find one in my pile of bits and send a pic you'd understand but alas...
    Have a look at the third post down in this thread. It shows how the plug can break. https://xjbikes.com/forums/threads/oil-drain-plug-on-side-of-crankcase.73198
  7. RideAlong420
    USA
    Yeah I've been scouring the forums and my 80's official manual and it doesn't even reference it. Only information I can find about it is there is an o-ring, and it's a plug for the "oil gallery" and that Len (in 2008 anyways) thinks it's around at most 8ft lbs.
    I guess I'm asking for more specifics:
    1. what is it?
    2. how do I address it?
    3. what is the torque setting?
  8. Rayzerman
    Rayzerman Member
    Ontario Canada
    If it's an o-ring, nice and snug is good and the o-ring will keep it from backing out.
  9. Dan Gardner
    Minneapolis, MN
    Yes, it is an o-ring on a plug that plugs both ends of the oil gallery that is bored under the crankshaft.
    I would just make sure that it is not one of the crank seals leaking and finding its way out from under the crank side covers.
    it’s a 20mm hex so it can stand quite a bit of torque, but don’t go nuts. About 3 ugga duggas.
    if it is tight and you are not being deceived by some other leak, then it is pretty cheap and easy to replace that o-ring.
  10. chacal
    Now that's military-grade specific!
    cds1984 likes this.
  11. RideAlong420
    USA
    both crank side covers have brand new gaskets on them from Len, yes, even though the right side cover doesn't do anything. It's not seemingly leaking from that area, but I can check tomorrow. If the crank seal is leaking, what happens then? I believe that spot is "sealed"? tbh it is not leaking that much, just enough that I notice it's slightly "wet" and not enough that it's really getting on the ground. Like, mild condensation amounts, is what we're talkin about here.
    So I'm assuming without draining the oil, the procedure would be to buy new o-ring, lay bike down on it's left, use 20mm hex to unscrew it (carefully), replace oring, torque it to like maybe 3-5ft lbs and stand up the bike and check for leaks? Do I have that right?
  12. Dan Gardner
    Minneapolis, MN
    Yes, it should be pretty straightforward.
    You will lose some oil, but shouldn’t be too much.
  13. RideAlong420
    USA
    I actually went out and looked at the bike, the side cover itself is bone dry.
    I can't really tell where it is coming from cuz it's not obvious. It's either coming from the gallery plug, or possibly from the bolt that is immediately next to it, the bolt on the bottom of the crankcase because it's a little oily/greasy near the cavity slightly behind the plug.
    Again, it's not obvious because it's not pooling. Everywhere else is bone dry. the only place I notice it collects is on that little raised cylinder immediately below the plug.
  14. cds1984
    Degrease it and check after each ride.
    Should become obvious.
  15. Rayzerman
    Rayzerman Member
    Ontario Canada
    Spray some foot powder on the area...... it will reveal the leak path.
  16. RideAlong420
    USA
    The bike didn't want to start... I had to put it on res and wiggle the bike back and forth, and then she started. I had tried slapping the carbs and checked the flow from the petcock, I turned it to prime and it started to leak around the petcock so I turned it back off and it stopped leaking immediately.
  17. Dan Gardner
    Minneapolis, MN
    This is the inside of the gallery plug. I’m not sure if you can tell from the photos, but the o-ring is pretty flattened and sacked out. If you told me this was leaking I would not be surprised at all. 40+ years is a long time- what do you expect?
    Also, the more I think about it I think I would take it up to 20~25 lbft and put some blue loctite on it. Just make sure it’s good and snug. If it fell out while you’re riding that would be a bad time.
    RideAlong420 likes this.
  18. Dan Gardner
    Minneapolis, MN
    Yes, these things have "buzzy" zone around 5,000-5,500 RPM. Must be some resonant frequency or something. That's normal. Mildly annoying, but normal.
    Yes, they are a bit noisy. Kind of like an old air cooled VW or Porsche. They say that it should sound like a sewing machine - so normal movement of gears and chains and whatnot. If there are things that sound bad like grinding or squealing then that might be a problem.
  19. RideAlong420
    USA
    I guess I never really experienced it before because the bike's valve clearance was way off the first time I rode it (not much, maybe an hour) and didn't know better. I did the valve clearance before the carbs got adjusted a few months ago and I've only put on maybe 160~ miles or so in total this year, 100 of those since the valve adjustment.
    I don't know if I need to adjust the automatic chain tensioner or not
  20. RideAlong420
    USA
    I found a person who rides an XS1100 in the area!! Super stoked
  21. RideAlong420
    USA
    Well I just got back from a ride, and she was acting really weird, having trouble idling.
    Turns out it looks like the oil seal behind the timing plate has failed. It's starting to leak past the gasket on that side
  22. RideAlong420
    USA
    See attachment
    I was riding and at times I noticed that my shifter felt slippery, and I found oil on my left boot after I got home. I had thought the rubber for the shifter came off. She was behaving weird in the last 10 minutes of my ride home, I'd go to shift into 2nd, and the neutral light would stay on, and I'd push it harder, and the neutral light went away and then I'd let up on the clutch. It would be fine otherwise. I'd get to an intersection, and she'd drop below 1050rpm with no choke (because she was warmed up enough, no point), as if she was going to die, so I would rev her a little bit, which usually fixes it, but it didn't, so I'd give her more choke, and she'd climb to 3000 rpms and I let off the choke and the rpms plummeted back down and potentially stall a few times, and I'd have to fight for her to stay alive, eventually opting to just have the choke on a little bit more than I wanted to.
    So I got home, parked the bike, talked with my friend who rode with me back from our biker hangout, went back to my bike, whipped out my phone and started looking all over to see if it was leaking from the right side oil gallery plug, which again, if there was a leak, it wasn't obvious. I moved to the left side of the bike and immediately noticed the bottom of the left cover was "wet" (weather was dry) and then noticed what you see in the attachment, and there was a few drops on the pavement.
    It would make sense that the oil seal behind the timing plate failed, though I haven't removed the side cover yet, it's very obviously leaking past the gasket. Oil getting into the timing plate components would also make sense why it was suddenly running poorly, making my shifter slippery, and getting oil on my left boot. I don't think oil and electricity work well together :p
    I was reading up on it and it sounds like nowadays, you don't have to split the case to fix this, since the newer oil seals don't have that "lip" that the old ones do. Correct me if I'm wrong, but it sounds like the steps would be:
    1. drain the oil
    2. remove the left side cover
    3. remove the timing plate (I am unsure if this means I will have to re-adjust the timing after or if I can just unscrew stuff to get at the oil seal and put it back...)
    4. carefully remove the oil seal with a pick or something?
    5. pop the new oil seal back in
    6. put the timing plate back
    7 . gently scuff the surface for the gasket and install a new gasket
    8. reinstall the left side cover
    9. refill the oil
    10. check for leaks
    or am I completely off base or am I missing something?
  23. cds1984
    I seriously doubt that would work.
    The seal is clamped between the cases.
    Check everywhere else.
    Oil flows backwards, make sure it isn't originating from your oil filter or something at the front.
  24. RideAlong420
    USA
    Gimme a minute to get on the ground and go out and look, but I'm pretty confident it's from the "crankshaft flange OIL SEAL". I'll take some more photos if I can.
  25. RideAlong420
    USA
    There is a video on the catalog that someone demonstrates, on an xj1100, digging out the old oil seal, and installing a new one.
    As you can see there's some like grease around the spin-on filter, but I don't see any active leaks.
    It almost looks like there is a little hole or a divot in one of the attachments where the oil is leaking from. It's really obvious to me that it's from this area, and some of the oil has flown back and got on the shifter and the bottom of the shifter cover
    I looked everywhere that I could around the front of the bike on both sides, and it's just this side.
  26. cds1984
    That is weird.
    That pic looks dry to me except the oil on the shifter of course.
    That divet is a drain hole. Oil wouldn't affect the sensors in there normally at all.
    Pull the cover and check before planning any other adventure with the crank seal I reckon.
    Gasket on that is to keep water/dirt out so not as hard core as oil.
  27. RideAlong420
    USA
    I'll do that tomorrow after work, it's midnight atm lol
    I'll make sure to post pictures here. I was waiting for my shipment from Len to remove the alternator cover, and clean the rotor surface and replace the brushes with new ones, and a new gasket there too. That's what I had planned on doing tomorrow after work...now I have a new thing to figure out.
    I should also pull the plugs and see if they got fouled again, that stalling behavior was very weird.
    cds1984 likes this.
  28. cds1984
    Last time I ended up with oil on the shifter like that it was the head gasket.
    But that was pretty obvious... Obviously!
  29. RideAlong420
    USA
    I promise I am not seeing oil from the head gasket, I've been checking around the valve cover, and all of the fins, which I have somewhat cleaned best I could with a little pokey brush thing, a few weeks back, and it looks bone dry.
    It seems it's "stopped" leaking at the moment, but there's an obvious oil spot on the ground where it was dripping.
  30. cds1984
    Indeed. You'd know if it was that, oil everywhere... Pants included!
    The little gear shifter seal leaks sometimes also.
    At any rate. Tomorrow!
  31. RideAlong420
    USA
    Looking at that video ( & ), I haven't been able to ascertain if you need to re-do the timing if you unscrew the timing plate to get at the oil seal. it looked like on the XJ1100 he just unscrewed the middle screw, and then the two screws holding it on.
    I guess I would assume that after you replace the oil seal, you just screw it back on...but??? I don't know for sure. Does anyone know with a modicum of confidence?
    also: I will pull the plugs and look at them to see their color, but I have a side question: if they do end up being fouled again, that's probably a carb issue, right? Could it be from running the enrichment circuit longer than the bike wants you to? Usually I don't have to crank the enrichment circuit to get the bike to start at all, or if I do I might just move the choke ever so slightly that it's obvious it is "on" because the revs go up, and after a few minutes of riding/idling I turn it off (my usual process is to 1. put helmet on 2. turn bike on 3. as it's idling I put my glasses on and gloves and back it out of my parking spot 4. pull out of the parking lot in 1st gear only. once I get about 500-1000 feet down the main road I shut it off) I don't think I'm rushing the bike this way.
    I don't know if it is related to the oil leaking or not, but on my way back besides the weird shifting issues I noticed on my way back (clutch pulled in fully, move shift toe up, neutral light comes on, stays on, I don't let go of the clutch and I move my toe harder and the light goes away, then I let out the clutch and it's fine. It wasn't doing this behavior on the ride down, but it was doing it more often on the ride back.) as I was pulling to an intersection the bike acts like it's spluttering, idle is going down, so I give it some more fuel via enrichment, the rpm climbs up, I lower it a little bit and the rpms drop rapidly. Cue this back and forth, behavior, and eventually I just leave the choke up higher to keep it from dying, and turning the choke off once I get into second gear.
    I've also noticed some weird behavior lately with this bike, I was in first gear and in a parking lot and I went over some crappy pavement and the bike kinda "clunked" a bit while going over the holes and when this happened it was like the power of the bike dropped almost instantly, though it didn't stall. It wasn't like just letting go of the throttle because of "oops I rode over a big bump" it was like the bike just lost power delivery? I was able to get it back in both instances but...
    The other thing I was noticing on the way back, I would downshift and the engine braking would kick in, and I would engine brake as I was coming to a stop and I felt something "rubbing" I wasn't sure what it was, when I noticed it I pressed and released the rear brake and the front brake to make sure I wasn't accidentally engaging them, but that wasn't the issue.
  32. RideAlong420
    USA
    Yep. Definitely behind this timing plate
    So I guess the answer is it's going to involve redoing the timing. I suppose I could try to mark off the exact placement of where that spinning part, is located, But that doesn't sound like the right way to do things.
  33. RideAlong420
    USA
    Rotor is dirty but otherwise the brushes look good. You can see the wearmark on the existing brushes, so I'm going to probably just clean the rotor and hold onto the brushes for later
    I don't see any leaks here, so I don't think I have to disassemble the alternator to replace anything (yet)
  34. RideAlong420
    USA
    Actually in looking at this, wouldn't the way to do this be to hand rotate the engine till it is exactly top dead center, for timing plate, And then to remove the pickup coil assembly?
    As long as the timing plate doesn't move while you're unscrewing the Allen bolt, it should just be a matter of putting the timing plate back where it was?
  35. Simmy
    The crankshaft is keyed for the timing rotor
  36. RideAlong420
    USA
    Right, I'm saying that based on the attachments I posted, which are based on the manual, that looks to be the instructions on how to uninstall the timing plate and reinstall it. So as long as I follow those directions it should be fine right?
  37. RideAlong420
    USA
    Upon further research it looks like I have missed a step; to verify the timing after removing the timing plate assembly, doing the oil seal removal and reinstall, and reinstalling the timing plate back to TDC, I'm gonna have to remove the valve cover and rotate the engine by hand to check the dots on the camshafts to make sure those match up with the TDC mark with the pointer. UGH. I hate having to remove the tank lol
  38. cds1984
    You can't really go wrong. The pin in the crank goes in the reluctor and the plate has very little play on the mount screws.
  39. RideAlong420
    USA
    Hrm.
    All my shops are weeks out. Maybe I can do it on my own then?
    I'm noticing another problem on top of all this, so as I'm looking at everything, I decide to pull the plugs. The technician said that all the plugs were looking good, but based on its weird behavior the other night, I wanted to see. Plugs one, two and four, are somewhat sooty, but not oily. Plug number three, looks a little bit too white for me, but I showed it to a bunch of other techs, and they said that it looks almost perfect. The bike is currently not starting, but I think I've tried so many times that it has discharged the battery and I need to charge it back up.
    The oil filler smells like oil, and does not smell burnt.
  40. RideAlong420
    USA
    Side question:
    Looks like the alternator gasket goes "behind" the wires that come out of the stator. Trying to figure out how I'm supposed to replace the gasket for the alternator. I assume I'll have to pull the stator out, put the gasket on, then replace the stator?
    Can I do this without removing the starter motor, or do I have to do that too?
    I also assume I should disconnect the battery before touching the stator or any components inside.
  41. RideAlong420
    USA
    Based on some youtubes I watched, looks like the stator is routinely stuck within the alternator housing, but as long as I can gingerly remove the stator without bending the wires too much, I should be able to slip the new gasket behind it and put it back on. I didn't see an oil leak so I don't believe the rotor needs to get pulled (though the inside of the cover has a few black splotches on it from...something?), just need to clean the rotor surface and put everything back. I do want to polish the alternator cover while it's off, however. I guess I could replace the JIS screws because I hate those things, but not sure how much I care right now about that lol. Might be something I bother with when I actually replace the brushes but they have TONS of material. I'll take a toothbrush to the brushes and a microfiber cloth.
    if I have to pull the starter motor to get the stator off though, I'm gonna be annoyed, because if I have to pull the starter motor then I'll do a rebuild of it and clean that too.
  42. RideAlong420
    USA
    Unrelated, to all of this, I got new LED lights for my tail light (4w each for "engaged brake" and 1w for running, so 8w when braking and 2w when just riding), and my license plate (1.82w), they are bright as ****, love it. I plugged them in and tested them and they worked. I think the original lights are probably OEM bulbs too. I may want to replace the rubber gasket for the taillight some day, it was a bit dilapidated. Not sure where that is in the catalog, though. (it's the rubber backing that is like a dust/water seal for the refractor on a Maxim tail light)
    I opted to not get a flashing tail light because that's illegal in my state. Same with a strobing headlight.
    Also the OEM headlight was pretty dim (sealed unit) but it was working, but I end up driving a lot at night, so I got a new LED headlamp (45w/30w). Thankfully it plugs right in. It's about the same depth as the existing sealed lamp, but a little wider because of the heatsink, but so far hasn't melted any of the wires back there. Besides the obvious benefit of it being drastically brighter (Internet claims it's comparable to a 80-100w lamp, and my friend saw me pulling up the other day and was like "that can't be her, it's too bright") the cable is positioned "on the side" rather than directly pointing towards the rear of the headlamp assembly, making it less of a pain to fit with all the other cables. Literally just plug and play, which was exactly what I was hoping for. I took the old lamp out of the assembly, and found out one of the two screws holding it on the sides (there are three, 1 goes to a long screw w/ a spring into a plastic T, that will probably have to be replaced or ideally replaced with a metal fitting because, what the ****, plastic degrades and the screw is just going to chew up the plastic) is JIS (and semi stripped) and the other got converted to a flathead at some point.
    I also have further evidence that this bike was dropped at some point in the 80's, and likely slid and bumped into something (assuming low speed), because the lamp assembly has a spot where it's dented (it's no longer perfectly circle, and has scratch marks). Add into that the screw is changed, means this headlight probably got replaced once in the past already. What would be the best way to "round" this outer chrome assembly? It's not so terrible I can't use it, but I don't want it to stay like that forever.
    In any case that saves me about 6.18w+6w/19w & 10w/5w or about 17w less power usage across the board, which is great. The only complaint is I feel bad about changing her face up a little bit. I like the classic lens refractor.
    cds1984 likes this.
  43. RideAlong420
    USA
    Was fiddling with the bike, and trying to figure out why she wasn't starting. She would turn over but not actually engage. I was completely flummoxed.
    Battery reads 12.9
    nothing in the airbox for debris, filter looks good. doesn't start when removing the filter and pinning the throttle.
    choke doesn't make a difference
    very certain spark is good, 1/2/4 are a little sooty and 3 I'm told looks almost perfect (looks lean to me)
    (might be out of order but I believe this is 1/2 [they were basically the same], 4, and 3)
    (if they look too small, open them on vimeo directly)
    I was scratching my head so I was gonna move onto something else and get it on the service stand, and unfortunately I lost balance of the bike and it tipped over on it's right slowly, nothing serious, the crash guards weren't even scuffed. I stood her up, grumpy at myself for losing my balance and noticed that something was pissing out of a tube on the bottom. I traced it to the airbox drain hose. It smelled like gas. Tipping over the bike for 10 seconds should not have caused that to leak, but good to know the drain hose isn't clogged!
    I smell the oil filler, smells like oil. No gas.
    On a lark, since I was having a strong feeling like this may be a stuck float, or a fueling issue, not spark, not battery, not dirty rotor in the alternator or starter motor, or solonoid issue, and certainly not compression, I tried starting the bike. She started!
    But she doesn't idle. You can fight with her to try and stay alive but she doesn't stay alive no matter what you do.
    I look at the inline fuel filter, and there's some shmutz in there. I have no idea what it is.
    the floats SHOULD be set correctly, but I think there's two things happening:
    while this debris doesn't appear to be blocking anything, I think I should remove the in-line filter and spray out whatever is there.
    I'm also tempted to pull the carbs and spray some carb cleaner in every hole I can find. However there is a wrinkle:
    I can't break the rack. I don't have the means to reset the carb settings, so no adjusting the brass idle screws (which have an o-ring at the bottom of the cavity), no touching the sync screws, and I have no means to set the fuel levels. I think the problem is that there is some debris that got into the carbs, and I want to spray the crap out of whatever holes I can (probably the pilot jet is clogged, is my assumption)
    Is there a "safe" way to clean the carbs, without breaking the rack, without the carb cleaner causing damage to the idle jet o-rings, without causing damage to the fuel pipe o-rings, without causing damage to the throttle shaft seals? Which holes should I blast specifically?
    ALL of the rubber components in the carbs currently are a few months old, from Len.
  44. RideAlong420
    USA
    Also I was replacing the destroyed grommets on my Headlight Stay and look at what the P.O. did.
    Yes that looks like the screw threads are welded in there, and the other hole is drilled out.
    at least they left the collets, I guess
  45. cds1984
    Stick the petcock on prime, wait a minute, then check each carb to see if there is fuel by opening the drain screw. The carb cleaner is more for fuel varnish and caked on stuff anyway. Not really applicable after a rebuild.
  46. RideAlong420
    USA
    If I set the petcock on prime, there is currently fluid in the fuel line, The petcock will start to leak.
  47. cds1984
    That makes it difficult. But you still need full bowls for the bike to run properly.
  48. RideAlong420
    USA
    What I'm saying is I think the floats are stuck.
    The bike dumped some fuel and it went from not starting at all to actually attempting to start.
    I think what's happening is if I set it to prime then the fuel doesn't have anywhere to go, so then starts to leak out of the petcock.
    I've tried turning it on for a few seconds and I don't really see a difference.
  49. cds1984
    That isn't how it's meant to work.
    Test to see if the bowls have fuel. If not then and you have fuel flow then your right.
    Tap the bowls with a screwdriver, or something, to vibrate the internal bits and it will realign internally the floats and needle so the valves open or close.
    I've had that situation twice after a carb rebuild once stuck open once stuck closed. Both times the tapping trick got it all working properly.
  50. RideAlong420
    USA
    Yeah I've been trying that, I get like a little screwdriver and gently tap the side of the carbs, or I use my hands on each side of the carb rack, or I sit on the bike and I shake it back and forth, which worked one time the other day.
    I'll take another crack at it tomorrow
    Ah I just had an idea, one of those electric back massagers, poke the carb rack with it and that might do the trick
    cds1984 likes this.
