XJ650 torque - motor mounts and drive to swingarm
Discussion in 'XJ Technical Chat' started by Jmkrull, May 19, 2018.
  1. Jmkrull
    Jmkrull Member
    Minneapolis
    so, the Haynes doesn’t seem to list these... looking if anyone knows the torque specs for the engine mount points and the swingarm to drive hub (4 nuts). Thanks!
  2. Polock
    just use the general specs for that size bolt. they should be in the book somewhere
    Jmkrull likes this.
  3. Jmkrull
    Jmkrull Member
    Minneapolis
    Ok, cool. Thanks!
  4. XJ550H
    engine mounting bolt front upper nut and front lower bolt 30.4 ft lbs
    rear nut 50.6 ft lbs
    engine mounting stay bolt qty 4 14.5 ft lbs
    final gear & rear arm M10 qty 4 30.4 ft lbs
