XJ650 won't stay running.
Discussion in 'XJ Technical Chat' started by maximxj650j, Aug 3, 2017.
  1. maximxj650j
    maximxj650j New Member
    Sacramento, CA
    Hey everybody I have a 1982 XJ650, It starts right up but won't stay running. I have played around with the idle adjust screw and it will work for a little bit but then back to the same old thing. Would syncing my carbs be the next best possible route? Thank you and appreciate any feedback!
  2. Toomanybikes
    Tsawwassen bc
    That may help, but have they been apart?
    Church of clean !!
  3. XJ550H
    do you use the choke to start it? and wait till the rpm starts to climb before you shut the choke off?
    how long have you had the bike ? are all the exhaust pipes getting hot?
  4. maximxj650j
    Sacramento, CA
    I do use the choke to start it, I let it warm up pretty long before taking choke away. After about 30 seconds with choke off rpms drop off and the bike dies. I have had the bike for 1 year. Exhaust temps are even across all four cylinders.
  5. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    Your carbs need a thorough cleaning....go to church.....your pilot jets are clogged ....that is why it dies after taking choke off....
    Your carbs must be taken apart all the way.....anything short of that.......you will be doing it again
  6. XJ550H
    do the rpms climb before you shut choke off?
    as @fiveofakind said the pilot jets are clogged they run the motor for the first 2k rpm and if they are clogged the main jets arn't in much better shape
    time to bite the bullet and clean the carbs
  7. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
  8. Jetfixer
    ^^^^+1 agree your carbs are in need of cleaning and Synching .... Ethonal does a number on carbs ...plugs up passages pretty quick , chances are when you pull float bowls it will be GREEN inside .
