XJ650RJ eBay Carburetor Bits
Discussion in 'XJ Technical Chat' started by Andius, Jan 26, 2021.
  1. Andius
    Andius Member
    Chicago, IL
    Hey all. I'm going through and cleaning the carburetors after a full disassembly. I came across an ebay listing that contained four carb gaskets, along with a number of internals. The current internals look pretty good, but not nearly as shiny. I bought it for the gaskets, but does it make sense to replace the Yamaha bits with the eBay bits, or hang onto them as backup parts? Or just recycle?
    Thanks!
  2. StahlMaster
    StahlMaster Active Member
    Southgate, Michigan
    I've done a few carburetor rebuilds. I used the original parts ALWAYS unless damaged or worn. I NEVER buy "kits" from e-bay (china). If they were from Japan, I'd consider it.
    hogfiddles and Brent NZ like this.
  3. Brent NZ
    Brent NZ Active Member
    Tauranga, New Zealand
    I couldn't agree more, the jets may look dull but they are unlikely to need replacement (maybe replace the needle jets). Swapping originals with anything other than high-quality components will generally be a backwards step.
    StahlMaster likes this.
  4. Andius
    Andius Member
    Chicago, IL
    Thanks both. I assumed that the case, but wanted some confirmation. I'll use the gaskets, o-rings as necessary, and I'll bag the metal bits as a just-in-case but assume I won't be using them.
  5. k-moe
    hogfiddles, Franz and Toomanybikes like this.
  6. Jetfixer
    I bought a full kit off of eBay...of course there were no butterfly shaft seals or fuel O rings ...but the kit was nice gaskets were good as well . Agree 100% xj4ever is your best bet though .
    Timbox likes this.
