Xj650rj growel
Discussion in 'XJ Technical Chat' started by Carl LaFong, May 19, 2021.
  1. Carl LaFong
    Carl LaFong Member
    ontario
    Trouble. In paridise?
    When I decelerate from 3000rpm in top gear I get a grinding sound. Does not seem to happen in other gears. Not. A sharp sound more of a growel. Normal or......
    Tranny, universal, rear end gear?
    only have driven this bike for 900km not sure what is normal for these.
  2. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    No, it's not normal for them to growl. These are the sweetest sounding engines out there when right.
    You need to look at exhaust, main stand rattling, check your driveshaft uj and oil in the final drive, anything further and you probably need to take it to someone who knows the model - I wouldn't be stripping anything unless you know.
  3. Carl LaFong
    Carl LaFong Member
    ontario
    Just wondering. Put New tires on and rear pinch bolt not tight. 're tourqued main rear nut and pinch bolt. Question: could this give me my growl, not having rear wheel installed right. Universal looks okay, pulled back rubber boot. Will ride today.
  4. Minimutly
    West Wales, uk
    Yes it could, won't do your splines any good either.
  5. Carl LaFong
    Carl LaFong Member
    ontario
    Rode it today.
    seems okay, maybe wishful thinking?
    put rubber stop on main stand it was
    metal on metalof
    love this thing 3500 to 5000 rpm!
  6. jayrodoh
    jayrodoh YimYam
    Cleveland
    5k? Get it up closer to 9k and report back!
    Simmy likes this.
  7. Carl LaFong
    Carl LaFong Member
    ontario
    Take it easy on the old guy 77 and still biken.
    Lots of bold bikers but no old bold bikers!!
    great site great info
    Dan Gardner, jayrodoh, Franz and 2 others like this.
  8. Carl LaFong
    Carl LaFong Member
    ontario
    Rode today and noticed that growl sound only in top gear when you back off from 3000rpm. Do not think final drive the issue. Maybe high gear is cut different so it is noisy ?
    Changed the main stand bracket used rubber to deaden vibration.
    maybe I am not used to a4 c cyl machine, raised on singles and twins!
  9. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Growl... on backing off from 3000RPM, so pretty low RPM.
    Sounds funky.
    I can't imagine the sound, but in the drivetrain the things that make noise are the clutch basket bearing or basket assembly mainly (if they have issues), especially if the uni-joint is in good shape.
    No help, sorry, weird one to be sure.
  10. Franz
    Mine had a growel at low rpm. Would have been at high rpm too but couldn't hear it with the airflow and my helmet on. I suspect the bearing in the clutch basket. When l took the clutch cover off l could move the basket side to side. Big needle roller bearing behind the clutch basket nut. New bearing noise disappeared.
  11. Franz
    Mine sounded like this Suzuki.
  12. Carl LaFong
    Carl LaFong Member
    ontario
    Update
    been riding often. When I back off in any other gear other than top gear no noise. From 3 to 4000 rpm. When on centre stand and spin rear wheel by hand nothing weird.
