XJ700 Carb Setup Question
Discussion in 'XJ Technical Chat' started by 78dave, Jan 16, 2018.
  1. 78dave
    78dave New Member
    Columbia, MO
    Ok, I think I have a good idea of setting up these carbs. I read that some set the first one manually setting the float level and then come back and do a fluid test. Then they have the reference point for the other three carbs. My question is when you do a fluid test do you perhaps use an old float bowl gasket rather than compressing a new one and if you are out of spec having to undue the bowl and then recompress the same new gasket.
  2. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I just checked all the floats with a homemade gauge and then did the wet setting. It took several times to get them set correctly. I used the same gaskets from start to finish. Be sure there are no air bubbles in the tubing when you take the readings. Also, after I got them set I let them sit for 10-15 minutes and rechecked them just to make sure the needles were not leaking. I also set mine 1 mm below the target setting, but still within the specified range.
  3. k-moe
    The gaskets don't compress much, and they swell up once the gas hits them.
  4. 78dave
    78dave New Member
    Columbia, MO
    Thanks guys. I may get back with more questions
  5. 78dave
    78dave New Member
    Columbia, MO
    Tabaka, my Hitachci 33's have a 1mm setting. Pretty much I guess the bowl is brim full. Not a lot of allowance here for +/-
  6. tabaka45
    Brunswick, Georgia
    Yep. Mine are at 2 mm.
