XJ700 *EFI* The holy sh*t it is fast now mod!
Discussion in 'XJ Modifications' started by gennro, Jan 2, 2011.
  1. schooter
    Re: XJ700 Now with F1 engine from down under!
    <------- really wants to test drive
  2. Desinger_Mike
    Desinger_Mike Member
    Eastern Pennsylvania
    I HOPE you took good notes!!! 8)
    I just hope I can find the time this spring to mess with this along with the frankine engine project
  3. gennro
    gennro Member
    hhhhhhhhhhhhhhhhhhhh
  4. swguy270
    swguy270 Member
    Dude... I've been following this thread closely, and all I can say is WOW!! I wonder how that would look and run on my bike?
    http://www.xjbikes.com/Forums/viewtopic/t=28506.html
    You've got some serious skills man. What do you do for a living? NOMB, but just wondering.
  5. gennro
    gennro Member
    Tactical Aircraft Mechanic, thats my job.
  6. gennro
    gennro Member
    Just ordered a 4-1 MAC exhaust to replace that heavy factory restrictive crap.
  7. mpg87
    mpg87 New Member
    Exeter,Ontario
    Hey there Gennro, I just spent a delightful hour reading about the conversion. That would sure make my monster fly too and less likely to lean out a cylinder. That bike looks awesome! I can follow the build well, but would go crazy trying to make it work on my bike. Many kudos for the transformation.
    Mike
  8. uhoh
    uhoh Member
    BC, Canada
    Wow, any chance you're going to get this to a dyno and graph your gains?
    Awesome stuff!
  9. gennro
    gennro Member
    Prolly not.
  10. swguy270
    swguy270 Member
    Ah, ok. Things make a little more sense now. Lol
  11. RickCoMatic
    This build deserves to be featured in a Bike Magazine.
    I don't know how many people are capable of completing such a Technical oriented Mod; but the Motorcycle Community outside of our Forum would find the particulars of this project very interesting reading.
    Kudo's for letting us go along for the ride.
    Great project.
  12. gennro
    gennro Member
    Thanks Rick!
  13. gennro
    gennro Member
    Ordered 2' of 1.5" OD aluminum pipe and two 3" long 1.5" ID silicone couplers to build some longer runners for the throttle bodies to help smooth out the intake air and help with cylinder fill. This coupled with a good flowing exhaust should help a lot.
  14. Polock
    i'd like to hear how much the 4-1 pipe changes the mixture
  15. Gearhead61
    Gearhead61 Member
    Hattiesburg, MS / Tyler, TX
    This is sort of related... but where did you get those intake pipes? They look great!
  16. gennro
    gennro Member
    Those are just made from PVC pipe. I didn't like them at all so I took them off.
  17. gennro
    gennro Member
    Well I ordered a 28" dragbar with a 4" pull back. Also ordered some new grips with skulls on the ends.
  18. gennro
    gennro Member
    Update today. 2nd gear ate itself agian so I had to split the cases apart and replace the gear. Also decided to paint the engine black.
  19. schooter
    /acts like it's no big deal
    dude bro, you're awesome
  20. gennro
    gennro Member
    Thanks man!
    Motorcycle engines are cake to work on. The engine is back in the bike and finished painting. Just waiting for the paint to dry over night. Will have my 4-1 exhaust tomorrow so it will get the heat wrap and installed! The drag bas should be here this week along with some skull hand grips.
    I also won the auction for the XJ900 oil cooler, $44! So that will be here this week at sometime.
  21. schooter
    you gonna put some nice seats on it?
  22. gennro
    gennro Member
    I'm leaving the stock seats on. I recovered the front seat and now I am just waiting on the rear seat cover to get here. I like the stock seat it is pretty comfortable after I put some new foam in it.
  23. shnuffy
    shnuffy Member
    Guelph, Ontario
    Unreal project.
    I can only hope to someday have the skills and knowledge you have. It also sounds like you have a badass job too. I'm jelly.
  24. gennro
    gennro Member
    Few more pics.....
    Installed thew new drag bars. Along with the new 4-1 with heat wrap. Also put the bike back together for the most part. Nothing real exciting yet.
  25. Orange-n-Black
    Memphis Area
    Nothing real exciting yet? Are you kidding? That EFI conversion is one for the records.
  26. gennro
    gennro Member
    Wooooo more pics started the bike up to let the engine to get to full temp to help bake on the paint.
  27. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    Just looking at the header wrap, if you have access to safety wire and a set of safety wire pliers it would get rid of those hose clamps and clean up the look.
    Just a thought.
  28. gennro
    gennro Member
    I like the look of the clamps myself that why I bought stainless steel ones.
  29. infamousalias99
    infamousalias99 Member
    I had a couple questions, first, where did you get your 36-1 wheel, and also, on im using an 03 gxsr set of throttle bodies, what were the specs of the injectors? i cant find that information anywhere and i need it to set up my megasquirt system, let me know.
  30. mirco
    mirco Member
    LaGrange Ohio
    Unreal gennro! I am not usually a big fan of the mod and chopped look but what an A-1 job you have done! I am impressed, awed, amazed ... the words escape me. Nicely done!
  31. gennro
    gennro Member
    The 36-1 I bought off ebay and the injectors are 19lbs/hr.
  32. Ledicott96
    Ledicott96 Member
    North west England
    Would this work for any other XJs e.g. 550, 650, 750. I know the 700 is a 5 valve per cylinder as per the 2 valve per cylinder but was just wondering.
  33. FinnogAngela
    FinnogAngela Member
    Copenhagen, Denmark
    The XJ700 Maxim (without the "X") (as Gennro´s) has the "normal" 8 Valve aircooled XJ-engine.
    You´re referring to the XJ700/750 Maxim-X with water-cooled 20 valve engine.
  34. Ledicott96
    Ledicott96 Member
    North west England
    thanks for that a big help
  35. Maxim-X
    You have enough on your plate now young man, get your other bike done first! :roll: :roll:
    :twisted: :twisted: :twisted:
    Mebbe the next one ay! :D
  36. Ledicott96
    Ledicott96 Member
    North west England
  37. infamousalias99
    how did you attach the intake boots? did you use the stock ones or did you use the ones from the gsxr intake? i have both.
  38. gennro
    gennro Member
    the boots from the head to the throttle body? I used the xj700 ones.
  39. infamousalias99
    ok, ive been having a hard time fitting mine to the gsxr intake...
  40. Orange-n-Black
    Memphis Area
    Well gennro, looks like you got something going. :lol:
  41. darkfibre
    darkfibre Member
    Perth, Australia
    You wont fit them to 750 manifold boots, you need boots from the 700. Diameter and spacing is different.
    If you look up manifold boots on Lens XJ4EVER for sale section he has a good
    explanation of diferences.
  42. infamousalias99
    but they will fit the gsxr manifold to the xj750 motor?
  43. infamousalias99
    could you possibly point me towards that write up im having a hard time finding it
  44. darkfibre
    darkfibre Member
    Perth, Australia
    This explains the differences in intake manifolds.
  45. infamousalias99
    ohhh haha i have 2 xj 750 motors. i should be able to mix n match boots to fit
  46. infamousalias99
    worse comes to worse i make something that fits
  47. darkfibre
    darkfibre Member
    Perth, Australia
    Just check to see that you can stretch the boots enough as they are smaller.
    I have decided to ditch the original manifolds and make an aluminium manifold instead for mine.
  48. infamousalias99
    i was thinking about making one but cost and time to my senior design project limited me to a gsxr setup
  49. zap2504
    zap2504 Member
    Middletown, PA
    Is there any definitive word on whether or not the Suzuki GSXR intake manifolds will fit the XJ650/750 heads, since the injectors are 33mm and the 33mm XJ700 intake manifolds are NLA?
  50. gennro
    gennro Member
    A heat gun, some lube, and two ratchet straps will make anything fit. It is not just a slip on affair. It takes some work to slip the throttle bodies in.
