XJ700 will not start after winter (not accu issue)
Discussion in 'XJ Technical Chat' started by lechski91, Mar 6, 2023.
  1. lechski91
    lechski91 New Member
    Netherlands
    Hi all,
    As in the topic, my XJ700S (1986 model, build year 1985) will not start.
    To give some background - it has a fairly new accu and that is not the issue. It is cranking and makes quite "healthy" starting noise, but the engine will not start.
    To provide some background and history (I am a newbie, so please consider this when reading below):
    - The bike worked well last summer, last time I rode it was in October and it was working well
    - I left the bike for winter (Netherlands, it does not get below freezing often, never lower than -5 Celsius)
    - It was filled in with 95 Benzine containing up to 10% bio-ethanol (I know, it is an issue...)
    - I left the fuel valve on Priming (yes, a mistake too)
    Based on my reading so far, it might be an issue with ethanol clogging the fuel hose and/or the carburateurs. The electrics in the bike worked well before winter and I doubt it should be the cause of the problem.
    Any advice on how to proceed?
  2. Fuller56
    Fuller56 Well-Known Member
    It would appear that you are going to learn how to remove and clean carburetors. And change the oil and filter. There is a thread here called the Church of Clean that you can search for that will explain what you will need to do to your carburetors. The oil change because the gasoline will have over flowed from the carburetors through the open valves (some of them are open all the time) and into the crankcase contaminating and diluting the oil. None of the needed work is terribly difficult but it is fairly specific as to what needs to be done. Almost all of us here have done it at some time. Welcome to the forum, all the help you will need to get your XJ up and running.
    Old5fifty likes this.
  3. Fuller56
  4. lechski91
    Netherlands
    Hi Fuller 56,
    Thank you for your reply! Been a while since I received such a friendly answer at any forum :)
    I will review the linked information and provide a progress update when I find time go get to the dirty part of the work. Thanks again!
  5. XJ650inTexas
    XJ650inTexas Active Member
    Dallas
    Since it hasn't been sitting too long you might try draining the fuel tank and carburetor bowls (fingers crossed the screws aren't seized) then add fresh fuel with some sort of cleaning additive. Squirt a little fuel or starting spray into the airbox and give it a go.
  6. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    If you try draining the tank and carbs, I would suggest that when you refill with fresh gas that you let some of it drain through the carbs just to be sure to get any bad gas out of the carbs and fuel lines. Ethanol has a tendency to absorb moisture so you probably have some water in the system. That's one of the main reasons why boats use non-ethanol gas.
  7. Jetfixer
    Welcome to the forum . When ever my bike is off the road for winter , I fill tank up and add a 50/50 mix of Stabil and Marvel Mystrery oil usually 16ounces , I run this till i can smell the oil in the exhaust and shut it down . One thing you can try is to pull the tank , use a large syringe fill it with acetone and Marvel squirt it down the fuel line , it may take several application , till the float bowls are full. Let this sit for an hour or so , next drain the float bowls into a container. Close drain screws reinstall your tank open petcock to the on position, wait a few minutes till bowls refill, now put choke to full on position and see if bike will start.
  8. Old5fifty
    Old5fifty New Member
    Minnesota
    It’s always a good plan to store with no alcohol gas. If not available then try to find a product for stabilizing the gas over winter. In America we use Stabil or similar. You could try to find a product called SeaFoam. Add it to the gas in the tank and crank the motor for a few seconds. Let it sit for a couple days and try to start it again. The run/stop button is in the on position I assume.
  9. lechski91
    Netherlands
    Hi all!
    New season, new issues with my lovely 1986 XJ700.
    Last season went in the end without having the need to clean the carbs. I used the bike quite a lot.
    However, in October the bike needed to be parked in the garage since one of the front shock absorbers started leaking hydrolic oil , so I decided to perform a thorough front fork rebuild.
    I took my time and succeeded, but the bike has not been in use for those few months.
    Current issue: The bike does not start again. This time it seems to an issue with ignition system. There is no spark on either of the 4 cables when tested with and without spark plugs.
    The electrical starting system seems to work as intended - I can hear it operating and see the rotations on the tachometer.
    Question: where do I start with identifying the problem? I watched a bunch of videos and based on the scheme I can perform all checks APART FROM checking the first step: checking entire ignition connection. Please, consider that even though since owning the bike my understanding of bike mechanics has increased drastically, the electric circuit is still a bit opaque to me and it has been a while since I played around with those during my bachelors studies.
    Where do I start? What do I do to find the faulty parts? It might be simply a disconnected plug BUT how do I find it? If it is the master fuse, how do I find it too?
    Any help would be greatly appreciated.
    Additional details:
    The bike worked quite well until October 2023
    - Since then it was parked in an underground garage with stable temperature
    - In the meantime, due to my stupidity when working on the front fork, it fell on the side once. No damage resulted from the fall, just a bit of spilled gasoline. But the current problem might be related.
    - I attempted to start the bike a few times with a fully charged battery and sufficient petrol, always fails (as described, no spark, but the electrics starter system works)
    - I tested the ignition system like that:
    Overall
    I want to perform a full ignition system check according to the scheme below, but I don’t know how to start.
    Thanks in advance for all of the help! You guys have been incredibly helpful so far and made me learn an immense amount of skills.
