Wanted Xj700x carburetors
Discussion in 'For Sale, Trade/Swap, Wanted' started by suhdudesuh, Mar 13, 2024.
Tags:
  1. suhdudesuh
    suhdudesuh New Member
    Greensboro md
    I’m looking for a set of carbs for my 86 700x. I got this bike pretty cheap and the guy before has mutilated the jets trying to get them out.
  2. Fuller56
    Fuller56 Well-Known Member
    @hogfiddles , you're up Dave! Hogfiddles should be along any minute. If he doesn't add to this thread you can start a conversation with him.
  3. hogfiddles
    I’m here :)
  4. Roy Ash
    Roy Ash New Member
    Desha Ar 72527
    How much you willing to pay for a good set
  5. Thomas Rowell
    Thomas Rowell New Member
    Brandon FL
    I've got a set. Just text me back, as a matter of fact I have a 1985 xj700 just needs TLC.
  6. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Do you have the chromed, plastic "5 Valve" carb side covers to get rid of?
  7. hogfiddles
    That would depend on how little you’re willing to sell one for…
  8. Thomas Rowell
    Brandon FL
    I'm in Tampa FL. The shipping would be a lot. But what would u be comfortable spending?
  9. Thomas Rowell
    Brandon FL
    I have the hole bike I will sale you.
  10. Huntchuks
    East Rochester, NY
    Let's see it.
  11. Thomas Rowell
    Brandon FL
    Ok I'll have to see how that works on here. I actually have 2 of them. I'll see what I can do. Just remember that I'm in Tampa FL.
  12. hogfiddles
    Carb racks only cost about $20-25 +\- to mail.
  13. Thomas Rowell
    Brandon FL
    Ok, these came off of a 1983 xj750.
  14. Thomas Rowell
    Brandon FL
  15. Thomas Rowell
    Brandon FL
    I have a pair of factory carbs on a 1985 xj700 maxim. I would rather sale you the hole bike. It has a wiring problem. A little work and it would be back to the street.
  16. Thomas Rowell
    Brandon FL
  17. hogfiddles
    That’s not a maximX, and the carbs won't interchange. The XJ750 rack will not interchange, either. The X takes Mikuni carburetors and the ones shown are hitachi carburetors. The XJ750 carb rack is also different than the xj700 rack even though they are also hitachi.
  18. Thomas Rowell
    Brandon FL
    Ok, what make is the one in the picture? For some reason I only get fired on the outside cylinders but no fire on the inside cylinders. If I could figure that part out it would start up and run. Do you think you can help me out?
  19. hogfiddles
    Read what I said.
    As far as only the two outside fires, and I'm assuming you mean when it was on the bike, that points to a coil failure (or pickup failure).....the right coil goes to cyl 2&3. Left coil goes to 1&4.
  20. Thomas Rowell
    Brandon FL
    Ok where is the pickup located on the bike.
  21. hogfiddles
    Pickups are under the left engine cover
  22. Thomas Rowell
    Brandon FL
    Thank you. From the pictures can you tell what model that is? It is a 1985 xj700 maxim. I'm just trying to get parts for the bike. It was my first bike I had.
  23. hogfiddles
    Yes, as you said, it’s an xj700 Maxim.
    Its in pretty Sad shape right now, but it can be brought back with TLC.
    I recommend doing a carburetor rack rebuild, and get the valve clearances back into spec. That will go a long way in helping to get it back into good shape.
  24. Thomas Rowell
    Brandon FL
    Someone chopped up the wire harness real good. I had it stored at my dad's house. Now it turns over and tries to start but it doesn't have fire to the inside cylinders. Do you know where I can get the manual for that bike? I need a wiring diagram.
  25. hogfiddles
    Make sure your left coil is connected to to plug 1 (on your left, and plug 4 (on your right), and the right coil gets hooked to plug 2 ( inside left), and plug 3 (inside right).
    Now go one at a time ..... pull each plug and see if all 4 are creating spark.
