1. Dec 26, 2024: XJBikes.com server migration work has been is completed. Thank you for your patience. SnoSheriff
Wanted Xj700x carburetors
Discussion in 'For Sale, Trade/Swap, Wanted' started by suhdudesuh, Mar 13, 2024.
Tags:
  1. hogfiddles
    Pickups are under the left engine cover
  2. Thomas Rowell
    Thomas Rowell New Member
    Brandon FL
    Thank you. From the pictures can you tell what model that is? It is a 1985 xj700 maxim. I'm just trying to get parts for the bike. It was my first bike I had.
  3. hogfiddles
    Yes, as you said, it’s an xj700 Maxim.
    Its in pretty Sad shape right now, but it can be brought back with TLC.
    I recommend doing a carburetor rack rebuild, and get the valve clearances back into spec. That will go a long way in helping to get it back into good shape.
  4. Thomas Rowell
    Brandon FL
    Someone chopped up the wire harness real good. I had it stored at my dad's house. Now it turns over and tries to start but it doesn't have fire to the inside cylinders. Do you know where I can get the manual for that bike? I need a wiring diagram.
  5. hogfiddles
    Make sure your left coil is connected to to plug 1 (on your left, and plug 4 (on your right), and the right coil gets hooked to plug 2 ( inside left), and plug 3 (inside right).
    Now go one at a time ..... pull each plug and see if all 4 are creating spark.
