xj700x Engine seems hotter on left side
Discussion in 'XJ Technical Chat' started by dowski68, Dec 6, 2017.
  1. dowski68
    dowski68 Well-Known Member
    Medford, Oregon
    Anyway I have owned by xj for five years now and here lately, like thae last three months I have noticed hat the left side of the engine is running hotter or putting off more heat.
    I can tell this by the temp on my legs.
    Curious if I may have the fuel mixture incorrectly adjusted- Guess i am going to have to re due the fuel mixture settings.
    Any suggestions would be appreciated
    Dowski68
  2. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Do your plugs look the same on both sides? One or more cylinders might be running leaner. If so, pilot screw adjustment might help. But it could require pulling the carbs and checking everything. Could also be a leaking inner exhaust pipe.
  3. dowski68
    Medford, Oregon
    thanks I will give that a try this Friday as I have a Final Thursday.
  4. kosel
    MInneapolis, MN
    Double-check with a thermometer. I can't explain why, but wind flows differently on each side for me. My left pant leg always blows up, while my right just flaps gently in the 60 mph breeze.
  5. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I bought an inexpensive ($12 shipped from Hong Kong on the auction site) infrared temperature gun just for this reason. I can check to see if each cylinder/exhaust temps are similar.
  6. dowski68
    Medford, Oregon
    An infrared temp gauge sounds like a good idea while I can also use it for other items. :)
