XJ700X Valve Synch
Discussion in 'XJ Technical Chat' started by MaxRodax, Sep 26, 2017.
  1. MaxRodax
    MaxRodax New Member
    Rochester hills, Michigan
    I am for the very first time checking my valves; after rotating the engine by hand ( left side) and matching the "T" with the witness mark; I get my sprockets with a severe offset. Please see picture attached. I will start with the easy question; is this normal?
    The book says that I need to line up the sprocket punch with the cam cap line on both.
    Please advice; I will check clearances after timing is resolved. Synch.jpg 20170926_120058.jpg
    Are you positive that the #1 piston is at top dead center of the compression stroke?
  3. XJ550H
    is there a punch mark on the camshaft? not the sprocket.
    reread instructions
  4. XJ550H
    first step of cams
    upload_2017-9-26_13-14-5.png upload_2017-9-26_13-14-56.png upload_2017-9-26_13-15-34.png see the holes in the sprocket?
  5. MaxRodax
    MaxRodax New Member
    I verified the T mark 360 degrees and the punch marks are not even visible.
    I checked the camshaft and the side with no clear sprocket alignment has a decent shaft alignment on the IN3 side; I couldn't clearly see the 2 side. I'll try again tomorrow before work. Thanks!
  6. Quixote
    Quixote Active Member
    Victoria, BC, Canada
    You can safely ignore the punch marks on the sprocket unless you remove the sprocket from the camshaft. They are just there to tell you which bolt holes not to use if you are re-installing the sprockets on the cam.
    The important punch marks are the ones on the cam itself, which you see when you look straight down like in the most recent picture you posted. Those ones should line up with the center of the cam cap. And in that last picture, it looks like it does.
    Assuming that your bike has been running reasonably well, your cam timing must be pretty much correct. If it was off by even one tooth it would run like crap, if at all.
    MaxRodax likes this.
