XJ750 Battery sensor
Discussion in 'XJ DIY How-To Instructions' started by IdahoSecaFan, May 18, 2018.
  1. IdahoSecaFan
    IdahoSecaFan New Member
    Idaho
    Hi ya'll. I replaced the old, deader-than-a-doornail battery with a new, sealed battery for my '81 750 Seca. The bike, when new, had a sensor/probe that you placed into the 3rd (2nd?) cell near the positive terminal of the battery which was your battery sensor for the warning light on the control cluster. A previous owner of this bike removed that sensor (no idea why) and now, with a new sealed battery in there, the warning light for the battery and the brake flashes every time I start my bike until I press the warning button on the cluster. Any ideas for fixing or bypassing the warning light when a sealed battery is installed?
  3. Rooster53
    Welcome to XJbikes and a great read to get started:
    https://www.xjbikes.com/forums/threads/the-information-overload-hour.27544/
    If you are getting the "BRK" warning be sure to check the fluid level in the master cylinder. The "BRK" warning is an alert for low fluid level in the master cylinder.
    If you decide to build your own bypass for the battery monitor the 6.2K resistor is the best value.
  4. IdahoSecaFan
    Idaho
    I appreciate the feedback, thanks!!
