XJ750 motor mounts
Discussion in 'XJ Technical Chat' started by 50gary, Nov 9, 2019.
  1. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    I own an XJ 750 Maxim 1982, my question is; are the motor mounts the same as the other bikes in this broad category as the XS1100. I had an XS1100 and made some aluminum motor mounts to replace the rubber ones. That was a popular mod for the XS1100 to tighten up the chassis for improved handling. I did it on my big XS and liked the result. Just wondering?
    Cheers, 50gary
  3. k-moe
    City of Seven Hills
    The Seca 650 and 750 use solid mounts that press into the same holes that the Maxim mounts fit into. They are a direct swap, just be careful to support the mounting ears sufficnently when pressing the solid mounts in.
    FYI, I switched my Seca to rubber mounts (I have CTS, and needed to reduce felt vibration), and did not notice any reduction in handling.
    Simmy likes this.
