XJ750 starts to turn over then clicks
Discussion in 'XJ Technical Chat' started by Shane G., May 4, 2017.
  1. Shane G.
    Shane G. New Member
    Maine
    I bought a Maxim xj750 back during the winter. When I bought her, she ran just fine. I took her out for the season and when I try to start her, she'll start to turn over then just starts clicking. The battery has a full charge and there is no corrosion build up on the starter or battery. Could I just have to replace the whole starter solenoid?
  2. Lightcs1776
    Lightcs1776 Active Member
    Upstate NY
    Have you checked the voltage drop when trying to start the bike? It may be that the batter is starting to go.
    Stumplifter likes this.
  3. Shane G.
    Shane G. New Member
    Maine
    I have not tried that yet, but I will
  4. XJ550H
    check acid levels bring up to level with distilled water charge and test standing voltage of battery the next day
  5. Toomanybikes
    Tsawwassen bc
    Did you have battery on a "Tender" over the winter?
  6. Craig B
    Craig B Active Member
    Ontario, Canada
    I sometimes have an issue with the starter relay. I just give it a wack and the starter spins up nice. Will need to change it one day.
    However if you give it a solid tap and your starter spins up then you have a good idea where to start looking.
  7. XJ550H
    try cleaning the starter button in the control. open it up and spray electric cleaner on it and lube with a little dielectric grease to prevent corrosion.
    Maine. I just picked up a couple of XJ750Maxims from Maine over the last 6 weeks
  8. Shane G.
    Shane G. New Member
    Maine
    Took mine apart and am currently working on cleaning. Was gonna try to post a link here to some pics of it but it won't let me. If you search for ElliotShane82 on imgur, I've got photos of the starter button taken apart for cleaning so you can see what I'm working with.
  9. XJ550H
    after 5 posts you can post photos and links.
    my controls were rough but the spray and cleaning lube brought them back to working order
